Entry door weather seal
02-09-2010, 12:17
My entry door weather seal is shot, pieces starting to fall off.
A search turned up a thread by Stephen Birtles in August about some M450 door seals he had acquired, and there was an open question about what else they might work for. I called him, and they are definitely not right for my coach. So the starting point is to describe what I have. I couldn't get a picture to show it adequately, so I'm trying a drawing instead. There are two "wipers" with a shorter one that goes in to the frame and a longer one that contacts the edge of the frame: See the drawing here: http://www.arcatapet.net/image/doorseal.jpg First question: has anyone found a replacement for these? Second question: is this the same as your coach/year/model? If so, are you in need of replacement? The second question(s) are important if there is no answer to the first one. Enough demand and Stephen can probably get something made. Don Bradner 90 PT40 "Blue Thunder" My location: http://www.bbirdmaps.com/user2.cfm?user=1 |
02-09-2010, 12:38
Don
Back when I replaced the one on my SP36, Holland Motor Homes in San Diego had a whole roll of it.(500ft. I think)
Also you may look at the Orr & Orr catalog.
Fred & Jeanne Hulse
02-09-2010, 15:25
I have none of the original seal left and would take some. It looks like a seal based on your drawing would work on mine.
Rick and Marilyn Davis
1993 WBSA
Loudon, TN
From: Don Bradner To: WanderlodgeForum@yahoogroups.com Sent: Tue, February 9, 2010 6:17:49 PM Subject: [WanderlodgeForum] Entry door weather seal My entry door weather seal is shot, pieces starting to fall off. A search turned up a thread by Stephen Birtles in August about some M450 door seals he had acquired, and there was an open question about what else they might work for. I called him, and they are definitely not right for my coach. So the starting point is to describe what I have. I couldn't get a picture to show it adequately, so I'm trying a drawing instead. There are two "wipers" with a shorter one that goes in to the frame and a longer one that contacts the edge of the frame: See the drawing here: http://www.arcatape t.net/image/ doorseal. jpg First question: has anyone found a replacement for these? Second question: is this the same as your coach/year/model? If so, are you in need of replacement? The second question(s) are important if there is no answer to the first one. Enough demand and Stephen can probably get something made. Don Bradner 90 PT40 "Blue Thunder" My location: http://www.bbirdmaps. com/user2. cfm?user= 1 |
02-09-2010, 19:08
I used some that I found at O'reilly's 5 yrs ago now. Still sealing just fine.
2000LXI in SPI --- In WanderlodgeForum@yahoogroups.com, "Don Bradner" > > My entry door weather seal is shot, pieces starting to fall off. > > A search turned up a thread by Stephen Birtles in August about some M450 door seals he had acquired, and there was an open question about what else they might work for. I called him, and they are definitely not right for my coach. So the starting point is to describe what I have. I couldn't get a picture to show it adequately, so I'm trying a drawing instead. There are two "wipers" with a shorter one that goes in to the frame and a longer one that contacts the edge of the frame: > > See the drawing here: http://www.arcatapet.net/image/doorseal.jpg > > First question: has anyone found a replacement for these? > > Second question: is this the same as your coach/year/model? If so, are you in need of replacement? > > The second question(s) are important if there is no answer to the first one. Enough demand and Stephen can probably get something made. > > Don Bradner > 90 PT40 "Blue Thunder" > My location: http://www.bbirdmaps.com/user2.cfm?user=1 > |
02-10-2010, 15:22
This looks like the same cross section that my door is sealed with. I need to
replace mine at this time. I sure would be interested if you find a source. Eric Perplies 96 PT-42 |
02-10-2010, 16:55
If there is a source it apparently would have to be one of the old-line BB
dealers like Holland or Bleakley. Consensus seems to be that changing to a bulb-type seal is better than stock - the stock is a bit too thick and requires door slamming to close. Randy says he uses the double-d channel and separates it to use one side. Since I'm unlikely to be around an HD or Lowes for several months I ordered this one this morning: http://www.amazon.com/gp/product/B000HE7YQM On 2/11/2010 at 3:22 AM Eric wrote: >This looks like the same cross section that my door is sealed with. I >need to replace mine at this time. I sure would be interested if you find >a source. > >Eric Perplies >96 PT-42 |
02-11-2010, 00:52
02-15-2010, 08:11
A final report on the door weatherseal:
After putting a new bushing (bought locally, but this is the same Help 38424: http://www.fixthisride.com/showproductde...d_id=87524 ) on the door striker bolt and moving the bolt as far inward as possible while still getting a good, relatively easy, latch, the http://www.amazon.com/gp/product/B000HE7...ss_product d-profile weatherstrip used on the long edge pulled in tight enough to make a good seal. I was not satisfied with the seal at the top or bottom, so I salvaged enough good pieces of the original to do both. A complete piece taken from the long edge for the top, and a single-splice piece for the bottom. The original adhesive was double-sided foam tape, which was not difficult to remove from the rubber and then use a new piece of the same. I did not contact any of the old-line Wanderlodge dealers to see if they have any of the original seal or not. Someone suggested that Holland in San Diego might, and Stephen Birtles thought Bleakley might. If anyone does find some there are are probably several here who would like to know who, and how much it cost. This is a link to a picture of the cross-section, as a supplement to my original line drawing. http://www.arcatapet.net/image/weatherstrip.jpg Don Bradner 90 PT40 "Blue Thunder" My location: http://www.bbirdmaps.com/user2.cfm?user=1 |
02-15-2010, 11:57
Hi Don
Perfect post on your weatherstrip project............................
I sure wish you were my neighbor!!...................................
I may have some of that weatherstripping that was the Original stuff soon,but I want to be certain it is right before offering it.
Fred & Jeanne Hulse
02-15-2010, 13:31
Great! Let me know if/when you get it.
On 2/15/2010 at 4:57 PM Fred Hulse wrote: >Hi Don >Perfect post on your weatherstrip project............................ >I sure wish you were my neighbor!!................................... >I may have some of that weatherstripping that was the Original stuff >soon,but I want to be certain it is right before offering it. >Fred & Jeanne Hulse >Morristown Arizona >1997 Wanderlodge WLWB41 |
