Water Leak In Bedroom, drat!!
04-17-2010, 11:20
Howdy, Y'all.
We are parked at the Lone Star Corral park in Dhanis, TX., still.
I was wondering why the carpet on my side of the bed felt a little damp. Hmmm. So I pulled it up and found a wet plywood floor. OH NO!!! Jack and I removed the bedding, let the air out of the Sleep Number mattress and removed it to the bathroom. Jack opened up the bed box and we found water near the water heater, and more toward the drivers' side wall. Anyway, we are drying out that area with multiple fans and we hope that we can find the source of the leak. Drat!!
Some comforting words would sure be appreciated.
Jack and Liz
1993 WBWL
Dhanis, TX for now
04-17-2010, 11:32
Liz, are you on shore or water pump?
83PT40
Wanderlodge
Weatherford, Tx 817-475-3991
--- On Sat, 4/17/10, Elizabeth wrote:
Subject: [WanderlodgeForum] Water Leak In Bedroom, drat!!
Date: Saturday, April 17, 2010, 6:20 PM
Howdy, Y'all.
Jack and Liz
1993 WBWL
Dhanis, TX for now
04-17-2010, 12:33
Liz, my leak was from theseries of CPVC (or is it PV?)(anyway, the graystuff)fittings going tothe water heater. If yours is like mine, cut all that mess out starting from the brass fitting at the heater, back to a pointa foot or so on thepipe runningalong side the bed. Glue a 3/4" male fitting on thepipe run. Then join withatwo foot length of 3/4" stainless flex line purchased from a plumbing supply house. It has the 3/4"female fittings on it already.They are proud of it, running $20 or so each, but it can't be kinked and allows you to run itaround the obstructions. I couldn't find it at Homey Despot. Ask for house water heater connection piping. While at it, I did
both the incoming and outgoing lines. Sorry for the cumbersome description. I have pics somewhere, but am on the road at the moment.
Rick Davis
1993 WLSA
Loudon, TN (at BATB-Myrtle Beach)
Sent: Sat, April 17, 2010 7:32:22 PM
Subject: Re: [WanderlodgeForum] Water Leak In Bedroom, drat!!
83PT40
Wanderlodge
Howdy, Y'all.
Jack and Liz
1993 WBWL
Dhanis, TX for now
04-17-2010, 12:34
Rick Davis
1993 WLSA
83PT40
Wanderlodge
Howdy, Y'all.
Jack and Liz
1993 WBWL
Dhanis, TX for now
04-17-2010, 13:35
Shore.
--- In WanderlodgeForum@yahoogroups.com, Ernie Ekberg
> Ernie Ekberg
> 83PT40
> Wanderlodge
> http://www.ernieekbergflooring.net
> --- On Sat, 4/17/10, Elizabeth jacklizpearce@... wrote:
> From: Elizabeth jacklizpearce@...
> Â
> Howdy, Y'all.
fans and we hope that we can find the source of the leak. Drat!!Â
> Jack and Liz
> 1993 WBWL
> Dhanis, TX for now
04-18-2010, 03:34
Howdy, Rick.
Thanks for the reply.
--- In WanderlodgeForum@yahoogroups.com, Rick Davis wrote:
> Liz, my leak was from theÂseries of CPVC (or is it PV?)(anyway, the grayÂstuff)Âfittings going toÂthe water heater. If yours is like mine, cut all that mess out starting from the brass fitting at the heater, back to a pointÂa foot or so on theÂpipe runningÂalong side the bed. Glue a 3/4" male fitting on theÂpipe run. Then join withÂaÂtwo foot length of 3/4" stainless flex line purchased from a plumbing supply house. It has the 3/4"Âfemale fittings on it already.ÂÂThey are proud of it, running $20 or so each, but it can't be kinked and allows you to run itÂaround the obstructions. I couldn't find it at Homey Despot. Ask for house water heater connection piping. While at it, I did both the incoming and outgoing lines. Sorry for the cumbersome description. I have pics somewhere, but am on the road at the moment.
> Rick Davis
> 1993 WLSA
I found the pics that you posted on the WOG and copied them to my computer. Thanks again,
Liz
Jack and Liz
1993 WBWL
Dhanis, TX for now
04-18-2010, 05:24
Hello Liz,
I also had the same problem with a 94 WB. I decided to put a Heater bypass in at
the time of the repair.
By the way what is a WOG?
Thanks
Nelson Slinkman 94 40wb
Westminster, Md
--- In WanderlodgeForum@yahoogroups.com, "Elizabeth" wrote:
> Howdy, Rick.
> > Liz, my leak was from the series of CPVC (or is it PV?)(anyway,
> the gray stuff) fittings going to the water heater. Â
> fitting at the heater, back to a point a foot or so on the pipe
> running along side the bed. Glue a 3/4" male fitting on theÂ
> pipe run. Then join with a two foot length of 3/4"
> the 3/4" female fittings on it already.  They are proud of
> it around the obstructions. I couldn't find it at Homey
> Despot. Ask for house water heater connection piping. Â
> road at the moment.
> > Rick Davis
> > 1993 WLSA
> Liz
> Jack and Liz
> 1993 WBWL
> Dhanis, TX for now
04-18-2010, 10:56
Howdy, Nelson.
Thanks for your reply.
WOG is another Blue Bird group online. Wanderlodge Owner Group.
Regards,
Liz
1993 BB
Dhanis, TX
--- In WanderlodgeForum@yahoogroups.com, "nelsons" wrote:
> Hello Liz,
> I also had the same problem with a 94 WB. I decided to put a Heater bypass in at the time of the repair.
> Thanks
> Westminster, Md
Jack and Liz
1993 WBWL
Dhanis, TX for now
