ARO Step control valve
11-14-2010, 07:18
Chuck. I replaced the valve on my 83 PT with Alfa valve from Grainger. Had to make minor change in mounting but easy to install. Hope this helps.
Alfa A2125D 012-D
Flow valve 42J85-1
12volt coil 2G503-2
Paul Downey
Versailles Ky
In a message dated 11/14/2010 6:19:30 P.M. Eastern Standard Time, cwheeler@... writes:
11-14-2010, 11:19
We developed a bad leak in the ARO step - Has anyone found any parts to rebuild - Or does any one have an old valve around - Or, lastly, does anyone have a part We head north for the holidays and in very - Chuck 1982 FC 31SB |
11-14-2010, 13:06
We have step control valves
Stephen 97 bmc 37 dupree Procucts --- In WanderlodgeForum@yahoogroups.com, "Chuck Wheeler" > > We developed a bad leak in the ARO step control valve during our trip last > weekend. The spool valve was easy to rebuild using "O" rings from the > faucet section of ACE hardware (3/4" X 1/8" thick - $0.29 each). The problem > is that the rubber on the back port of one of the pilot air valves is bad so > there is a leak when it is energized. There used to be kits available for > these valves but I can't find any since IR bought ARO. > > - Has anyone found any parts to rebuild one of these valves lately? > > - Or does any one have an old valve around that I could buy for parts? > > - Or, lastly, does anyone have a part number for a valve that would replace > the current one? (ARO Part#5840-2929-02) > > > > We head north for the holidays and in very cold weather even a small leak > creates problems. > > > > - Chuck Wheeler- > > 1982 FC 31SB Fort Worth TX > |
11-14-2010, 13:46
Chuck,
I also replaced both the step and generator valves with the A212SD012 valve assembly. Bought them from Stearns Corp. in Houston cost about $120.00, but that was in 2006. I had trouble with one of them and got a repair kit, primarily the spool valve, from Applied Industrial Technologies here in Austin. Cost was $32.00 in 2008. Applied has an office in Dallas (972-506-0612) and Arlington (817-649-3094). Their catalog lists A212SD--- valves, but only in 120 volt and 24 volt. Hope this is of some value to you.
Chet Geist
1981FC33
Austin, Texas
11-14-2010, 14:15
Thanks Paul! I’ll give it a - Chuck 1982 FC 31SB From: Chuck. I replaced the valve on my 83 PT Alfa A2125D 012-D Flow valve 42J85-1 12volt coil 2G503-2 Paul Downey In a message dated 11/14/2010 6:19:30
11-15-2010, 00:39
11-15-2010, 00:41
11-15-2010, 02:34
Ernie, The cylinder is easy to rebuild. There is - Chuck 1982 FC 31SB From:
11-15-2010, 05:39
11-15-2010, 14:46
Stephen, Do you have more information? - - - - Chuck 1982 FC 31SB From: WanderlodgeForum@yahoogroups.com We have step control valves Stephen 97 bmc 37 dupree Procucts --- In "WanderlodgeForum%40yahoogroups.com", "Chuck Wheeler" > > We developed a bad leak in the ARO step control valve during our trip last > weekend. The spool valve was easy to rebuild using "O" rings from the > faucet section of ACE hardware (3/4" X 1/8" thick - $0.29 each). The problem > is that the rubber on the back port of one of the pilot air valves is bad so > there is a leak when it is energized. There used to be kits available for > these valves but I can't find any since IR bought ARO. > > - Has anyone found any parts to rebuild one of these valves lately? > > - Or does any one have an old valve around that I could buy for parts? > > - Or, lastly, does anyone have a part number for a valve that would replace > the current one? (ARO Part#5840-2929-02) > > > > We head north for the holidays and in very cold weather even a small leak > creates problems. > > > > - Chuck Wheeler- > > 1982 FC 31SB > |
