air system wn40
04-11-2011, 02:26
air system wn40
Hello All
I have a 1990 wb40 I have a air system in i that allow you to pump up the system without running the motor for some reason it will not let build up pressure I here it leaking under the front wheel area. I looked in the book and it says it need to get to 65 psi which this pump dose not it gets about 50 psi this is also the pump that will also allow you to work the the waist air switches anyway I hooked up another air pump inline as soon as it hits the 65 psi the air leek goes away and then I can even fill the air bags anyway my question is the air pump in the couch is that normal to only get to 50 psi?? Jamie Brandt 1990 wb40 florida email jamiebrandt@ymail |
04-11-2011, 02:39
air system wn40
Jamie,
My 91 on-board electric air pump builds up to 90psi. I would assume that the 90 model should be similar, but perhaps someone with a 90 model will respond. I know Steve Gureasko has a 90 but he is traveling today, headed home from the LSB rally, and may not see your message for a while. Which air pump do you have that is built in? Perhaps there is a rebuild kit available. Sounds like it is time for a rebuild. FWIW, MIke Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "Jamie" > > Hello All > I have a 1990 wb40 I have a air system in i that allow you to pump up the system without running the motor > for some reason it will not let build up pressure I here it leaking under the front wheel area. > I looked in the book and it says it need to get to 65 psi which this pump dose not it gets about 50 psi this is also the pump that will also allow you to work the the waist air switches > anyway I hooked up another air pump inline as soon as it hits the 65 psi the air leek goes away and then I can even fill the air bags > anyway my question is the air pump in the couch is that normal to only get to 50 psi?? > > Jamie Brandt > 1990 wb40 > florida > email jamiebrandt@ymail > |
04-11-2011, 02:53
air system wn40
Jamie,
Fix that air leak, and I bet all will be fine. I had one of the two air dump control valves leaking slightly...the coach would not air up using the on-board compressor. It would build pressure using both the on-board and the engine compressor (engine running of course). I replace the leaking valve and the on-board compressor is again doing its job. ÃÂ Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA "curtsprenger@gmail.com" On Mon, Apr 11, 2011 at 7:39 AM, mbulriss <"mbulriss@yahoo.com"> wrote:
04-11-2011, 03:30
air system wn40
I concur that an air leak can prevent it from airing up. Been there, done that. Roger Webb 91WL Cedar Rapids, IA
On Apr 11, 2011, at 9:53 AM, Curt Sprenger <"curtsprenger@gmail.com"> wrote:
04-11-2011, 05:03
air system wn40
Yes, same pump and same 90psi on the '90.
Don Bradner 90 PT40 "Blue Thunder" My location: http://www.bbirdmaps.com/user2.cfm?user=1 On 4/11/2011 at 2:39 PM mbulriss wrote: >Jamie, > >My 91 on-board electric air pump builds up to 90psi. > >I would assume that the 90 model should be similar, but perhaps someone >with a 90 model will respond. I know Steve Gureasko has a 90 but he is >traveling today, headed home from the LSB rally, and may not see your >message for a while. > >Which air pump do you have that is built in? Perhaps there is a rebuild >kit available. Sounds like it is time for a rebuild. > >FWIW, > >MIke Bulriss >1991 WB40 "Texas Minivan" >San Antonio, TX > > > >--- In WanderlodgeForum@yahoogroups.com, "Jamie" >> >> Hello All >> I have a 1990 wb40 I have a air system in i that allow you to pump up >the system without running the motor >> for some reason it will not let build up pressure I here it leaking >under the front wheel area. >> I looked in the book and it says it need to get to 65 psi which this >pump dose not it gets about 50 psi this is also the pump that will also >allow you to work the the waist air switches >> anyway I hooked up another air pump inline as soon as it hits the 65 psi >the air leek goes away and then I can even fill the air bags >> anyway my question is the air pump in the couch is that normal to only >get to 50 psi?? >> >> Jamie Brandt >> 1990 wb40 >> florida >> email jamiebrandt@ymail >> > > > > >------------------------------------ > >Yahoo! Groups Links > > > |
04-11-2011, 07:21
air system wn40
Thanks All
I will try t fix the leak I'm not crazy about going under there but what can you do Thanks Jamie Brandt 1990 Wb40 Florida |
04-11-2011, 07:34
air system wn40
one more question
should I hear any air at all |
04-11-2011, 10:37
air system wn40
With the on-board compressor running, and if you have good hearing, you might hear the air leak. I suggest using soap/water in a spray bottle. Good luck and be careful.
ÃÂ Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA "curtsprenger@gmail.com" On Mon, Apr 11, 2011 at 12:34 PM, Jamie <"jamiejbrandt@yahoo.com"> wrote:
04-11-2011, 12:59
air system wn40
No air should be leaking. It might only be a stuck valve. When you find the
source, try tapping it if it is a valve. R.E. (Ron) Marabito, Dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, "Jamie" > > one more question > should I hear any air at all > |
04-11-2011, 15:39
air system wn40
Any chance it is under the dash (parking brake)?
On 4/11/2011 at 7:21 PM Jamie wrote: >Thanks All >I will try t fix the leak >I'm not crazy about going under there but what can you do >Thanks >Jamie Brandt >1990 Wb40 >Florida > > > >------------------------------------ > >Yahoo! Groups Links > > > |
