Freedom today?
07-06-2011, 22:41
Freedom today?
Hello everyone:
Am in hopes of freedom today from this Hospital. Started having digestive
problems on the 1st and have been in Hospital since the 4th. As it turned I had
an inflamed gall bladder with 5 stones that needed surgery. One of the stones
were so large it had to be cut in half than all removed yesterday. Am feeling
fine, save for being sore as all get out.
Charolette had been shuffling back and forth from home to here. At least I went
into the Hosp in Duncan and not Lawton.
Am in hopes for release to home base this morning.
Safe travels, Ralph &
Charolette Fullenwider
'84 FC35 "Ruff Diamond"
Duncan, Oklahoma
Sent via BlackBerry by AT&T
07-06-2011, 22:57
Freedom today?
good to hear you are close to home
88 PT40
817-475-3991
--- On Thu, 7/7/11, Ralph wrote:
Subject: [WanderlodgeForum] Freedom today?
To: "Wanderlodge Forum"
Date: Thursday, July 7, 2011, 5:41 AM
Hello everyone:
Am in hopes of freedom today from this Hospital. Started having digestive problems on the 1st and have been in Hospital since the 4th. As it turned I had an inflamed gall bladder with 5 stones that needed surgery. One of the stones were so large it had to be cut in half than all removed yesterday. Am feeling fine, save for being sore as all get out.
Charolette had been shuffling back and forth from home to here. At least I went into the Hosp in Duncan and not Lawton.
Safe travels, Ralph & Charolette Fullenwider
Duncan, Oklahoma
07-07-2011, 03:00
Freedom today?
Ha Ralf did you start feeling bad before or after you got off the phone with me
on the 1st? Good luck and heal up quick.
Bob Loomas
1985 pt 36
Harahan La
--- In WanderlodgeForum@yahoogroups.com, "Ralph" wrote:
> Hello everyone:
> Duncan, Oklahoma
07-07-2011, 06:19
Freedom today?
Glad you are out and O.K.
> Hello everyone:
> Duncan, Oklahoma
07-08-2011, 13:20
Freedom today?
Ralph, Good luck on your recovery you can't say that you were never stoned in your lifetime!!!, by the way was it you thathooked up a CPAP in your Bird. Can you if it was you send that hook up to me. I was thinking that I would hook up to the small reading spot lamp in the bedroom with a small converter and just plug in to that. The CPAP takes 5.0 amps what do you think. When using the inverter it takes about 3.5 hrs to auto start the generator... I sleep longer than that since the using CPAP
Scooter 2000XL Ocqueoc, MI
Date: Thu, 7 Jul 2011 15:00:20 +0000
Subject: [WanderlodgeForum] Re: Freedom today?
Ha Ralf did you start feeling bad before or after you got off the phone with me on the 1st? Good luck and heal up quick.
Bob Loomas
1985 pt 36
Harahan La
--- In "WanderlodgeForum@yahoogroups.com", "Ralph" wrote:
> Hello everyone:
> Duncan, Oklahoma
07-08-2011, 13:29
Freedom today?
Will send the info back channel, Al. And the CPAP runs along with a small box fan off the inverter I put in, all night plus, on our 6 12vdc batts and hardly a drop in overall volts in the AM.
Ralph
Safe travels, Ralph Charolette Fullenwider
Duncan, Oklahoma
Date: Fri, 8 Jul 2011 20:20:13 -0500
To:
Subject: RE: [WanderlodgeForum] Re: Freedom today?
Bob Loomas
1985 pt 36
Harahan La
> Hello everyone:
> Duncan, Oklahoma
07-08-2011, 16:31
Freedom today?
You might want to check your machine. My
CPAP also has a 12vdc connection and doesn use anywhere near 5 amps. The fuse
in the adapter is 3AMP and it is fast acting so the CPAP probably pulls about
half of that.
- Chuck
Wheeler-
From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Ralph
Sent: Friday, July 08, 2011 8:29
PM
To: Wanderlodge Forum
Subject: Re: [WanderlodgeForum]
Re: Freedom today?
Will send
Ralph
Safe
Duncan, Oklahoma
Sender: WanderlodgeForum@yahoogroups.com
Date: Fri, 8 Jul
2011 20:20:13 -0500
To:
ReplyTo: WanderlodgeForum@yahoogroups.com
Subject: RE:
Bob Loomas
1985 pt 36
Harahan La
"Ralph" wrote:
> Hello everyone:
> '84 FC35 "Ruff D iamond"
> Duncan, Oklahoma
07-09-2011, 11:10
Freedom today?
BOB:
When u commin down under to visit us?? Bring ur Bird over.
Regards,
Hank
> Bob Loomas
> 1985 pt 36
> Harahan La
> > Hello everyone:
> > Duncan, Oklahoma
07-09-2011, 11:21
Freedom today?
Thnaks for the info. Do you have a cigerette lighter in the bedroom that you plug into?
The 5.0amp is stated on the bottom of the unit.The CPAP provider was of NO help on this subject.
Sorry for dumb questions but ........when youy plug in what batteriery are you using? or where did you pick uip the DC power in the bedroom?
Scooter 2000LX Ocqueoc, MI
Date: Fri, 8 Jul 2011 23:31:04 -0500
You might want to check your machine. My CPAP also has a 12vdc connection and doesn use anywhere near 5 amps. The fuse in the adapter is 3AMP and it is fast acting so the CPAP probably pulls about half of that.
- Chuck Wheeler-
Sent: Friday, July 08, 2011 8:29 PM
Subject: Re: [WanderlodgeForum] Re: Freedom today?
Ralph
Duncan, Oklahoma
To:
Bob Loomas
1985 pt 36
Harahan La
> Hello everyone:
> Duncan, Oklahoma
07-09-2011, 11:59
Freedom today?
My FC has a DC outlet in the bedroom on
the wall near the closet. The DC cord for the CPAP will reach it from the bed.
Chuck Wheeler-
1982 FC 31SB
Fort Worth TX (HOT!)
WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Al Scudder
Sent: Saturday, July 09, 2011 6:22
PM
To:
wanderlodgeforum@yahoogroups.com
Re: Freedom today?
that you plug into?
- Chuck
Wheeler-
PM
Re: Freedom today?
Ralph
Duncan, Oklahoma
Date: Fri, 8 Jul
2011 20:20:13 -0500
To:
Subject: RE:
Bob Loomas
1985 pt 36
Harahan La
"Ralph" wrote:
> Hello everyone:
> Am in hopes for release to home base thi s morning.
> Duncan, Oklahoma
