90 SP36 downshifting
06-27-2005, 01:16
I just returned from a 500 mile trip in my BB and everything was fine
except that the transmission did not downshift correctly on long steep hills. If the hill was steep enough the coach would almost stall unless I pressed down on the accelerator quickly. Come to think of it when accelerating from a stop the upshifts seem to occur very close together also. If there is a simple fix I will attempt it myself, otherwise I need to find someone close to Akron, Ohio to make the adjustment/repairs. (The trans. econ/pwr switch was on pwr). |
06-27-2005, 01:45
> I just returned from a 500 mile trip in my BB and everything was fine > except that the transmission did not downshift correctly on long steep > hills. If the hill was steep enough the coach would almost stall > unless I pressed down on the accelerator quickly. > Come to think of it when accelerating from a stop the upshifts > seem to occur very close together also. If there is a simple fix I > will attempt it myself, otherwise I need to find someone close to > Akron, Ohio to make the adjustment/repairs. (The trans. econ/pwr > switch was on pwr). I do not know tht much about ZF transmissions but it sounds like the Transmission speed sensor may have a problem and/or the tranny shift points need to be reset. Look in Your ZF literature for a close service center. Barring that a truck tranny service center.Sorry I can not be of more help. |
06-27-2005, 02:14
What you experienced may be normal unless this represents a change
from your prior experience on this coach. I just came back from a trip in my 89SP in which I encountered a long hill that I often drive. I started the hill at 70 MPH but was soon down to 25 with much black smoke out of the exhaust. The transmission does not have a downshift switch like a car that is activated by pushing the pedal to the floor. In fact I have found that when RPMs drop you can get it to downshift by backing off on the pedal. Also hit the lower shift selector buttons, this will not force a downshift and you cannot damage the transmission by doing this because the computer has the final say. What it does do is keep the transmission in the lower gears once it does downshift. You can then keep the revs up but be ready to hit the next button up when the engine gets up to 2,800 RPMs. If you still have concerns take it to ZF at Vernon Hills outside Chicago to have them check it out. In general this is a bulletproof unit and they know exactly what they are doing. They can also re-program your PROM for an update that was done a number of years ago that changes shift points. They will also explain how best to operate the transmission. The only thing you can easily adjust is the throttle position sensor (or do they call it the load sensor). Check your ZF literature. Also call ZF, they are very helpful. Overall it is frustrating to see RPMs drop so low and have the engine lug but that tends to be the nature of the beast. --- In WanderlodgeForum@yahoogroups.com, "williamcharrison" > I just returned from a 500 mile trip in my BB and everything was fine > except that the transmission did not downshift correctly on long steep > hills. If the hill was steep enough the coach would almost stall > unless I pressed down on the accelerator quickly. > Come to think of it when accelerating from a stop the upshifts > seem to occur very close together also. If there is a simple fix I > will attempt it myself, otherwise I need to find someone close to > Akron, Ohio to make the adjustment/repairs. (The trans. econ/pwr > switch was on pwr). |
