1998 Lxi Fuel Sending Unit Access
02-17-2021, 11:41
Does anyone know if the fuel gauge sending unit can be accessed without dropping the 300-gallon fuel tank?
02-17-2021, 12:02
RE: 1998 Lxi Fuel Sending Unit Access
I would say yes. My 96 has an access plate in bay 2 on the driver's side. Remove the access plate and the sender is right there.
02-28-2021, 09:43
I will take a look, thank you.
04-02-2021, 23:25
Any luck?
I have only one panel that I can see and it is in the third bay streetside above the Aquahot. Unfortunately BB installed the high amperage AC junction box to it and it will have to be removed before I can determine if this is the access. Might look in this location on yours. As mine is a 41' things may be a little different. '98 41' LXI |
