Low air buzzer stays on
09-06-2005, 06:44
After I air up the the low air light and buzzer stays on. I drove it
home(40 miles) and the buzzer and light never went off. Any help would
be appreciated. We have a 86PT38.
Many Thanks,
Rick Mcintire
86PT38 Patillo,Tx
09-06-2005, 07:31
Rick,
On my 81 there is a switch at the auxilliary tank with one wire that got
corroded after years of use and when replaced fixed the problem. It was
located right at the outlet for the tank and was an easy repair about $10.00
for the switch. Be sure the air is out of the tank before trying to
replace. Thaks for keeeping us up-dated on Stephen and Patty.
Chet Geist
1981 FC33, Austin, Texas
-----Original Message-----
[mailto:WanderlodgeForum@yahoogroups.com]On Behalf Of ricmcintire
Sent: Tuesday, September 06, 2005 1:45 PM
Subject: [WanderlodgeForum] Low air buzzer stays on
Many Thanks,
Rick Mcintire
86PT38 Patillo,Tx
radiators
YAHOO! GROUPS LINKS
c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service.
09-06-2005, 07:43
What do the front and rear air gauges indicate?
tom
1982 FC35
Vernon Center,NY
>Many Thanks,
>Rick Mcintire
>86PT38 Patillo,Tx
09-06-2005, 07:53
-Chet, Thank you for the info. I will check it out tonight. Buzzer
drove me crazy on the home Saturday night.
Thanks,
Rick Mcintire
86PT38
Patillo,TX Fulling timing on the ranch
-- In WanderlodgeForum@yahoogroups.com, "Chet Geist"
> Rick,
that got
It was
about $10.00
to
> Chet Geist
drove it
would
> Many Thanks,
> Rick Mcintire
> 86PT38 Patillo,Tx
maintenance
Automotive
> radiators
> YAHOO! GROUPS LINKS
of
> Service.
09-06-2005, 08:19
Hi Rick,
Our prior 86PT40 was wired so that the low air light
and buzzer also "lit and buzzed" when a jack was not
fully retracted (or when a jack switch was defective).
Don't want to send you down the wrong trail but it
might not be too hard to start the engine, examine the
dash air gauge, drop a jack or two, and see if any
additional buzzers and/or lights become lit.
Also, if I recall correctly, the annoying buzzer
control breaker was located in the #1 position (top
left) of the inside front panel just ahead of the
passenger seat where it can be pulled temporarily so
as not to drive you nuts while you drive; the buzzer
will stop and the dash light will remain on.
John Suter
> off. Any help would
> Many Thanks,
> Rick Mcintire
> 86PT38 Patillo,Tx
Do You Yahoo!?
http://mail.yahoo.com
09-06-2005, 08:25
Rick:
There are a couple of switches that mount on the front axle and
the tag axle that activate the light and buzzer. I had the same
problem the other day, but it straightened itself out. Call Ralph and
he can tell you exactly what to look for. You might just have some
dust in this switch.
Moderator
--- In WanderlodgeForum@yahoogroups.com, "ricmcintire"
would
> Many Thanks,
> Rick Mcintire
> 86PT38 Patillo,Tx
09-06-2005, 09:39
-Tom, The main air gauge shows 120 psi and the tag shows about 70 to
75 psi.
Thanks for any help
Rick Mcintire
-- In WanderlodgeForum@yahoogroups.com, Tom Warner
> tom
> 1982 FC35
> Vernon Center,NY
would
> >Many Thanks,
> >Rick Mcintire
> >86PT38 Patillo,Tx
09-06-2005, 09:41
Ron, Thanks for the info. I will check those switches. I do get a
lot dust out in the country. Tried to call Ralph and no answer, will
try tonight.
Rick Mcintire
86PT38 Patillo,Tx.
-- In WanderlodgeForum@yahoogroups.com, "ronmarabito2002"
> Rick:
some
> Moderator
drove it
> would
> > Many Thanks,
> > Rick Mcintire
> > 86PT38 Patillo,Tx
09-06-2005, 09:42
How about the front gauge air pressure Rick?
tom
>75 psi.
>Thanks for any help
>Rick Mcintire
> > tom
> > 1982 FC35
> > Vernon Center,NY
>would
> > >Many Thanks,
> > >Rick Mcintire
> > >86PT38 Patillo,Tx
>SPONSORED LINKS
ObWmSYTw>Recreational
>vehicles
anderlodge
4cC1O9CxA>Automotive
>maintenance
YHfELr6o72IW1A>Recreational
>vehicle dealer
-kXbDI4ZSadEw>Used
q_4GlXA>Automotive
>radiators
>YAHOO! GROUPS LINKS
> * Visit your group
Wanderl\
09-06-2005, 14:05
If u are unable to get your answer from one of these guys, give a call to Bennie
Collier at BB. He will have the answer for you. His # is 800-992-6337
ricmcintire wrote:After I air up the the low air light
Many Thanks,
Rick Mcintire
86PT38 Patillo,Tx
SPONSORED LINKS
Recreational vehicles Wanderlodge Automotive maintenance Recreational vehicle
dealer Used recreational vehicles Automotive radiators
YAHOO! GROUPS LINKS
Do You Yahoo!?
