Sporlan Valve??
09-08-2005, 08:22
Sporlan Valve??
stephen birtles sells the sporlan valves, as i purchased a couple from him
a month ago. ernie-83pt40 in montana [Non-text portions of this message have been removed] |
09-08-2005, 11:40
Sporlan Valve??
When I use my water pump/fresh water tank, I get water that spits out
of the exterior hose hook-up compartment. Is this indicative of the Sporlan valve needing to be rebuilt? Does anyone on the forum sell this kit. I realize I can get it from BB, but I'd like to support the forum members. Steve Harrie '86 PT38 St. George, UT |
09-08-2005, 11:58
Sporlan Valve??
Hi Steve:
Congrats on your Coach. The unit where you hook up your shore water is actually a pressure regulator and should seal like an anti back flow valve when shore water is disconnected. I would replace the regulator. Now then, having said that, you do not have to replace the whole housing, that is a major bear to get to on a PT for sure. If you look at the regulator ( shore water input) you should see 2 small holes 180 degrees from each other on both side of the regulator. Using a large set of snap ring pliers you can unscrew the innards of the regulator, then do the same on the new one and just screw the new regulator back into the old housing, 10 minute job and done. The Sporlan valve does get a build up on the diaphragm from time to time and just needed to be taken apart, carefully and cleaned up. I use a pocket knife to scrape the white build up off the diaphragm and re assemble. No big thing really. Remove the coil on the top of the Sporlan valve, remove 4 screws and it is in your hand, be careful though, it is spring loaded so remove the top of the valve slowly. Also pinch off the hose between the valve and fresh water tank, no sense of having to mop up allot of water while your doing this. Safe travels, Ralph and Charolette Fullenwider Ralph's RV Solutions, Duncan, Oklahoma http://home.swbell.net/rlf47/index.htm At 11:40 PM 9/8/2005 +0000, you wrote: >When I use my water pump/fresh water tank, I get water that spits out >of the exterior hose hook-up compartment. > >Is this indicative of the Sporlan valve needing to be rebuilt? > >Does anyone on the forum sell this kit. I realize I can get it from >BB, but I'd like to support the forum members. > >Steve Harrie >'86 PT38 >St. George, UT > > |
09-09-2005, 08:20
Sporlan Valve??
>...pressure regulator and should seal like an anti back flow valve
when shore water is disconnected. Thanks Ralph, I did like you suggested and it popped right out. Unfortunately no one in ST. George has anything like this regulator. I Googled it, searched Camping World, etc and couldn't find it. Stepen do you carry it? From a picture I saw, it is a Flojet Water Pressure Regulator # 01750-245A. Steve Harrie '86 PT38 |
09-09-2005, 10:29
Sporlan Valve??
Steve:
BB # 3959772 I bought 2 of them last year at RIV and they were not that much from Bluebird. Safe travels, Ralph and Charolette Fullenwider Ralph's RV Solutions, Duncan, Oklahoma http://home.swbell.net/rlf47/index.htm At 08:20 PM 9/9/2005 +0000, you wrote: > >...pressure regulator and should seal like an anti back flow valve >when shore water is disconnected. > >Thanks Ralph, I did like you suggested and it popped right out. >Unfortunately no one in ST. George has anything like this regulator. > >I Googled it, searched Camping World, etc and couldn't find it. > >Stepen do you carry it? From a picture I saw, it is a Flojet Water >Pressure Regulator # 01750-245A. > >Steve Harrie >'86 PT38 > > |
