Front upper dash TV
11-07-2005, 01:46
Front upper dash TV
If I remember right the TV was just held in with the straps. You can take
the front off with some screws in the side brackets & take the TV out the front. I needed to do this anyway because I wanted to fasten my Flat screen to the front. Don 89 SP 36' Butler, PA Is, the TV connected(screwed)to the plywood base it sits on? I am trying to replace it. Have already took off metal strap over tv. Also does the tv come out the rear with base attached, or through the front? [Non-text portions of this message have been removed] |
11-07-2005, 04:42
Front upper dash TV
Is the TV connected(screwed)to the plywood base it sits on? I am
trying to replace it. Have already took off metal strap over tv. Also does the tv come out the rear with base attached, or through the front? |
11-07-2005, 04:48
Front upper dash TV
--- In WanderlodgeForum@yahoogroups.com, "ED GARDELS"
wrote: > > Is the TV connected(screwed)to the plywood base it sits on? I am > trying to replace it. Have already took off metal strap over tv. Also > does the tv come out the rear with base attached, or through the front? > Forgot to mention its a 89sp. |
11-07-2005, 04:48
Front upper dash TV
11-07-2005, 05:04
Front upper dash TV
Hi Ed,
It would help if you would sign your posts and indicate what model you have so that we can response more accurately. For instance, if you are talking about the backup monitor/TV in an 83 PT, the answer is that the monitor is connected to the upper dash housing by four screws around the front of the monitor. Disconnect high power cable and lift out. So, what model are you talking about? And, is it the TV/backup monitor or a separate TV? Thanks, Mike Bulriss 83 PT40 "Stagecoach" - For Sale - with Financing! 91 PT40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "ED GARDELS" wrote: > > Is the TV connected(screwed)to the plywood base it sits on? I am > trying to replace it. Have already took off metal strap over tv. Also > does the tv come out the rear with base attached, or through the front? > |
11-07-2005, 06:11
Front upper dash TV
--- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@y...>
wrote: > > Hi Ed, > > It would help if you would sign your posts and indicate what model you > have so that we can response more accurately. For instance, if you > are talking about the backup monitor/TV in an 83 PT, the answer is > that the monitor is connected to the upper dash housing by four screws > around the front of the monitor. Disconnect high power cable and lift > out. So, what model are you talking about? And, is it the TV/backup > monitor or a separate TV? > > Thanks, > SORRY about not signing, I noticed my mistake as soon as I sent it. (89sp) and I guess its probably the OVERHEAD dash. Imnew at this as Ive only had my bb for a few months(2 trips). Dont know much about it, I readthe forum and trial and error.see msg 6340 for signing.Thanks for the reply. ED GARDELS 89SP ARLINGTON, TEXAS > > Mike Bulriss > 83 PT40 "Stagecoach" - For Sale - with Financing! > 91 PT40 "Texas Minivan" > San Antonio, TX > > > --- In WanderlodgeForum@yahoogroups.com, "ED GARDELS" > wrote: > > > > Is the TV connected(screwed)to the plywood base it sits on? I am > > trying to replace it. Have already took off metal strap over tv. Also > > does the tv come out the rear with base attached, or through the front? > > > |
11-07-2005, 06:11
Front upper dash TV
11-07-2005, 06:50
Front upper dash TV
Ed, you are close by. You going to the Boerne rally? Ernie-83pt40 in Weatherford
-----Original Message----- From: ED GARDELS To: WanderlodgeForum@yahoogroups.com Sent: Mon, 07 Nov 2005 18:11:33 -0000 Subject: [WanderlodgeForum] Re: Front upper dash TV --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@y...> wrote: > > Hi Ed, > > It would help if you would sign your posts and indicate what model you > have so that we can response more accurately. For instance, if you > are talking about the backup monitor/TV in an 83 PT, the answer is > that the monitor is connected to the upper dash housing by four screws > around the front of the monitor. Disconnect high power cable and lift > out. So, what model are you talking about? And, is it the TV/backup > monitor or a separate TV? > > Thanks, > SORRY about not signing, I noticed my mistake as soon as I sent it. (89sp) and I guess its probably the OVERHEAD dash. Imnew at this as Ive only had my bb for a few months(2 trips). Dont know much about it, I readthe forum and trial and error.see msg 6340 for signing.Thanks for the reply. ED GARDELS 89SP ARLINGTON, TEXAS > > Mike Bulriss > 83 PT40 "Stagecoach" - For Sale - with Financing! > 91 PT40 "Texas Minivan" > San Antonio, TX > > > --- In WanderlodgeForum@yahoogroups.com, "ED GARDELS" > wrote: > > > > Is the TV connected(screwed)to the plywood base it sits on? I am > > trying to replace it. Have already took off metal strap over tv. Also > > does the tv come out the rear with base attached, or through the front? > > > Yahoo! Groups Links [Non-text portions of this message have been removed] |
11-07-2005, 08:47
Front upper dash TV
Ernie, Glad you made it back home ok. Are you going to make it to the rally? What day are you leaving if you are? We are leaving on the 1st of December.Tell Brenda hi for us. Best Regards, Rick & Terri Mcintire 86PT38 Patillo,Tx - In WanderlodgeForum@yahoogroups.com, erniecarpet@a... wrote: > > Ed, you are close by. You going to the Boerne rally? Ernie-83pt40 in Weatherford > > -----Original Message----- > From: ED GARDELS > To: WanderlodgeForum@yahoogroups.com > Sent: Mon, 07 Nov 2005 18:11:33 -0000 > Subject: [WanderlodgeForum] Re: Front upper dash TV > > > --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@y...> > wrote: > > > > Hi Ed, > > > > It would help if you would sign your posts and indicate what model > you > > have so that we can response more accurately. For instance, if you > > are talking about the backup monitor/TV in an 83 PT, the answer is > > that the monitor is connected to the upper dash housing by four > screws > > around the front of the monitor. Disconnect high power cable and > lift > > out. So, what model are you talking about? And, is it the > TV/backup > > monitor or a separate TV? > > > > Thanks, > > > SORRY about not signing, I noticed my mistake as soon as I sent it. > (89sp) and I guess its probably the OVERHEAD dash. Imnew at this as > Ive only had my bb for a few months(2 trips). Dont know much about > it, I readthe forum and trial and error.see msg 6340 for > signing.Thanks for the reply. > ED GARDELS 89SP > ARLINGTON, TEXAS > > > > > Mike Bulriss > > 83 PT40 "Stagecoach" - For Sale - with Financing! > > 91 PT40 "Texas Minivan" > > San Antonio, TX > > > > > > --- In WanderlodgeForum@yahoogroups.com, "ED GARDELS" > > > wrote: > > > > > > Is the TV connected(screwed)to the plywood base it sits on? I am > > > trying to replace it. Have already took off metal strap over tv. > Also > > > does the tv come out the rear with base attached, or through the > front? > > > > > > > > > > > > > > Yahoo! Groups Links > > > > > > > [Non-text portions of this message have been removed] > |
11-07-2005, 10:17
Front upper dash TV
--- ED: I have a 90SP36 and put in a 20 inch LCD TV and highly
recommend it. made a metal frame etc. recommend a 24 in LCD with the speaker ON the bottom..It will fit..u can get a 24 inch for what I paid for 20 Inch.... regards, Hank Hannigan 90SP36 In WanderlodgeForum@yahoogroups.com, "ED GARDELS" wrote: > > --- In WanderlodgeForum@yahoogroups.com, "ED GARDELS" > wrote: > > > > Is the TV connected(screwed)to the plywood base it sits on? I am > > trying to replace it. Have already took off metal strap over tv. > Also > > does the tv come out the rear with base attached, or through the > front? > > > Forgot to mention its a 89sp. > |
User(s) browsing this thread: 13 Guest(s)
