Power Steering and Hydraulic Engine Cooling Fan
11-14-2005, 07:39
I'm wondering how often others change the Power Steering and Hydraulic
Engine Cooling Fan oil and filters. The BB book calls for every engine oil change (yearly or 20,000 miles). -- Curt Sprenger 1987 PT38, Anaheim Hills, Calif. |
11-14-2005, 08:21
Hi Curt:
I doubt that those fluids (30wt oil) are changed on that regular of a schedule. There are 2 filters in the reservoir tank and available from Napa. The yearly change seems a bit much to me as it is a closed loop system and un like the engine or gen set oil change schedule, the power steering and fan motor oil does or should not get as much contamination. the 20,000 or even 30,000 miles seems to me, to be the better rule of thumb for the changes though I am sure that many of the Coaches have not been changed since leaving the Factory, just perhaps added to. Ralph At 11:39 AM 11/14/2005 -0800, you wrote: >I'm wondering how often others change the Power Steering and Hydraulic >Engine Cooling Fan oil and filters. The BB book calls for every engine >oil change (yearly or 20,000 miles). > >-- >Curt Sprenger 1987 PT38, Anaheim Hills, Calif. > > > > > > >Yahoo! Groups Links > > > > Safe travels, Ralph and Charolette Fullenwider Ralph's RV Solutions, Duncan, Oklahoma http://home.swbell.net/rlf47/index.htm |
11-14-2005, 13:25
Thanks Ralph. I'm thinking the oil/filters have never been changed.
Might be a good thing to do sometime soon. Curt Sprenger 1987 PT38, Anaheim Hills, Calif. Ralph L. Fullenwider wrote: > Hi Curt: > > I doubt that those fluids (30wt oil) are changed on that regular of a > schedule. There are 2 filters in the reservoir tank and available from > Napa. The yearly change seems a bit much to me as it is a closed loop > system and un like the engine or gen set oil change schedule, the power > steering and fan motor oil does or should not get as much contamination. > the 20,000 or even 30,000 miles seems to me, to be the better rule of > thumb > for the changes though I am sure that many of the Coaches have not been > changed since leaving the Factory, just perhaps added to. > > Ralph > > At 11:39 AM 11/14/2005 -0800, you wrote: > >I'm wondering how often others change the Power Steering and Hydraulic > >Engine Cooling Fan oil and filters. The BB book calls for every engine > >oil change (yearly or 20,000 miles). > > > >-- > >Curt Sprenger 1987 PT38, Anaheim Hills, Calif. > > > > > > > > > > > > > >Yahoo! Groups Links > > > > > > > > > > Safe travels, > > Ralph and Charolette Fullenwider > Ralph's RV Solutions, Duncan, Oklahoma > http://home.swbell.net/rlf47/index.htm > > > > SPONSORED LINKS > Recreational vehicles > <http://groups.yahoo.com/gads?t=ms&k=Recr...vehic\ les&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=U\ sed+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzhn_O\ bWmSYTw> > Wanderlodge > <http://groups.yahoo.com/gads?t=ms&k=Wand...2=Wan\ derlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recrea\ tional+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLPj9U0JvqYQ> > Automotive maintenance > <http://groups.yahoo.com/gads?t=ms&k=Auto...;vehi\ cles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=\ Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pmy34\ cC1O9CxA> > > Recreational vehicle dealer > <http://groups.yahoo.com/gads?t=ms&k=Recr...ional\ +vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deale\ r&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_XahaeY\ HfELr6o72IW1A> > Used recreational vehicles > <http://groups.yahoo.com/gads?t=ms&k=Used...onal+\ vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer\ &w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km4L-\ kXbDI4ZSadEw> > Automotive radiators > <http://groups.yahoo.com/gads?t=ms&k=Auto...ehicl\ es&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Us\ ed+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgTnMq\ _4GlXA> > > > > ------------------------------------------------------------------------ > YAHOO! GROUPS LINKS > > * Visit your group "WanderlodgeForum > <http://groups.yahoo.com/group/WanderlodgeForum>" on the web. > > * To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of > Service <http://docs.yahoo.com/info/terms/>. > > > ------------------------------------------------------------------------ > |
11-14-2005, 13:42
Curt,
I change my hydraulic oil every 20,000 miles including the 3 (there are 3 in my '85 anyway) filters inside the tank and the external filter. The external filter is about $85 and the internal filters are about $8 ea(there are 3 of them). Change the engine oil and filter every 5,000 miles. If the change is procrastenated beyond 5,000 miles, it'll start using a quart in 1,000 miles. If changed in 5,000 miles maybe use 1 or 2 quarts depending on use, high speed or hot temps will cause slightly more useage. Jay Darst 85PT40 Springfield, IL --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > Thanks Ralph. I'm thinking the oil/filters have never been changed. > Might be a good thing to do sometime soon. > > Curt Sprenger 1987 PT38, Anaheim Hills, Calif. > > > > Ralph L. Fullenwider wrote: > > > Hi Curt: > > > > I doubt that those fluids (30wt oil) are changed on that regular of a > > schedule. There are 2 filters in the reservoir tank and available from > > Napa. The yearly change seems a bit much to me as it is a closed loop > > system and un like the engine or gen set oil change schedule, the power > > steering and fan motor oil does or should not get as much contamination. > > the 20,000 or even 30,000 miles seems to me, to be the better rule of > > thumb > > for the changes though I am sure that many of the Coaches have not been > > changed since leaving the Factory, just perhaps added to. > > > > Ralph > > > > At 11:39 AM 11/14/2005 -0800, you wrote: > > >I'm wondering how often others change the Power Steering and Hydraulic > > >Engine Cooling Fan oil and filters. The BB book calls for every engine > > >oil change (yearly or 20,000 miles). > > > > > >-- > > >Curt Sprenger 1987 PT38, Anaheim Hills, Calif. > > > > > > > > > > > > > > > > > > > > >Yahoo! Groups Links > > > > > > > > > > > > > > > > Safe travels, > > > > Ralph and Charolette Fullenwider > > Ralph's RV Solutions, Duncan, Oklahoma > > http://home.swbell.net/rlf47/index.htm > > > > > > > > SPONSORED LINKS > > Recreational vehicles > > <http://groups.yahoo.com/gads? t=ms&k=Recreational+vehicles&w1=Recreational+vehicles&w2=Wanderlodge& w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recr eational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzh n_ObWmSYTw> > > Wanderlodge > > <http://groups.yahoo.com/gads? t=ms&k=Wanderlodge&w1=Recreational+vehicles&w2=Wanderlodge&w3=Automot ive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recreational+v ehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z- 8HJdysB3QLPj9U0JvqYQ> > > Automotive maintenance > > <http://groups.yahoo.com/gads? t=ms&k=Automotive+maintenance&w1=Recreational+vehicles&w2=Wanderlodge &w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+rec reational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pm y34cC1O9CxA> > > > > Recreational vehicle dealer > > <http://groups.yahoo.com/gads? t=ms&k=Recreational+vehicle+dealer&w1=Recreational+vehicles&w2=Wander lodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Use d+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_Xah aeYHfELr6o72IW1A> > > Used recreational vehicles > > <http://groups.yahoo.com/gads? t=ms&k=Used+recreational+vehicles&w1=Recreational+vehicles&w2=Wanderl odge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used +recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km 4L-kXbDI4ZSadEw> > > Automotive radiators > > <http://groups.yahoo.com/gads? t=ms&k=Automotive+radiators&w1=Recreational+vehicles&w2=Wanderlodge&w 3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recre ational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgT nMq_4GlXA> > > > > > > > > ----------------------------------------------------------------- ------- > > YAHOO! GROUPS LINKS > > > > * Visit your group "WanderlodgeForum > > <http://groups.yahoo.com/group/WanderlodgeForum>" on the web. > > > > * To unsubscribe from this group, send an email to: > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of > > Service <http://docs.yahoo.com/info/terms/>. > > > > > > ----------------------------------------------------------------- ------- > > > |
11-19-2005, 14:43
Does anyone have a source for the "O" ring that fits the high pressure filter
for this system? Was able to get the element, the $85 one, but can't find the proper Parker "O" ring. BB said they don't have it. I took the old one and tried to duplicate it. Installed one that was as close as the eye could determine but it starting leaking after a couple of thousand miles. Any help would most appreciated. Dick Hayden - '87 PT38 ----- Original Message ----- From: Jay Darst To: WanderlodgeForum@yahoogroups.com Sent: Monday, November 14, 2005 6:42 PM Subject: [WanderlodgeForum] Re: Power Steering and Hydraulic Engine Cooling Fan Curt, I change my hydraulic oil every 20,000 miles including the 3 (there are 3 in my '85 anyway) filters inside the tank and the external filter. The external filter is about $85 and the internal filters are about $8 ea(there are 3 of them). Change the engine oil and filter every 5,000 miles. If the change is procrastenated beyond 5,000 miles, it'll start using a quart in 1,000 miles. If changed in 5,000 miles maybe use 1 or 2 quarts depending on use, high speed or hot temps will cause slightly more useage. Jay Darst 85PT40 Springfield, IL --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > Thanks Ralph. I'm thinking the oil/filters have never been changed. > Might be a good thing to do sometime soon. > > Curt Sprenger 1987 PT38, Anaheim Hills, Calif. > > > > Ralph L. Fullenwider wrote: > > > Hi Curt: > > > > I doubt that those fluids (30wt oil) are changed on that regular of a > > schedule. There are 2 filters in the reservoir tank and available from > > Napa. The yearly change seems a bit much to me as it is a closed loop > > system and un like the engine or gen set oil change schedule, the power > > steering and fan motor oil does or should not get as much contamination. > > the 20,000 or even 30,000 miles seems to me, to be the better rule of > > thumb > > for the changes though I am sure that many of the Coaches have not been > > changed since leaving the Factory, just perhaps added to. > > > > Ralph > > > > At 11:39 AM 11/14/2005 -0800, you wrote: > > >I'm wondering how often others change the Power Steering and Hydraulic > > >Engine Cooling Fan oil and filters. The BB book calls for every engine > > >oil change (yearly or 20,000 miles). > > > > > >-- > > >Curt Sprenger 1987 PT38, Anaheim Hills, Calif. > > > > > > > > > > > > > > > > > > > > >Yahoo! Groups Links > > > > > > > > > > > > > > > > Safe travels, > > > > Ralph and Charolette Fullenwider > > Ralph's RV Solutions, Duncan, Oklahoma > > http://home.swbell.net/rlf47/index.htm<http://home.swbell.net/rlf47/indexhtm> > > > > > > > > SPONSORED LINKS > > Recreational vehicles > > <http://groups.yahoo.com/gads?<http://groups.yahoo.com/gads?> t=ms&k=Recreational+vehicles&w1=Recreational+vehicles&w2=Wanderlodge& w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recr eational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzh n_ObWmSYTw> > > Wanderlodge > > <http://groups.yahoo.com/gads?<http://groups.yahoo.com/gads?> t=ms&k=Wanderlodge&w1=Recreational+vehicles&w2=Wanderlodge&w3=Automot ive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recreational+v ehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z- 8HJdysB3QLPj9U0JvqYQ> > > Automotive maintenance > > <http://groups.yahoo.com/gads?<http://groups.yahoo.com/gads?> t=ms&k=Automotive+maintenance&w1=Recreational+vehicles&w2=Wanderlodge &w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+rec reational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pm y34cC1O9CxA> > > > > Recreational vehicle dealer > > <http://groups.yahoo.com/gads?<http://groups.yahoo.com/gads?> t=ms&k=Recreational+vehicle+dealer&w1=Recreational+vehicles&w2=Wander lodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Use d+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_Xah aeYHfELr6o72IW1A> > > Used recreational vehicles > > <http://groups.yahoo.com/gads?<http://groups.yahoo.com/gads?> t=ms&k=Used+recreational+vehicles&w1=Recreational+vehicles&w2=Wanderl odge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used +recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km 4L-kXbDI4ZSadEw> > > Automotive radiators > > <http://groups.yahoo.com/gads?<http://groups.yahoo.com/gads?> t=ms&k=Automotive+radiators&w1=Recreational+vehicles&w2=Wanderlodge&w 3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recre ational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgT nMq_4GlXA> > > > > > > > > ----------------------------------------------------------------- ------- > > YAHOO! GROUPS LINKS > > > > * Visit your group "WanderlodgeForum > > <http://groups.yahoo.com/group/WanderlodgeForum<http://groups.yahoo.com/group/Wa\ nderlodgeForum>>" on the web. > > > > * To unsubscribe from this group, send an email to: > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of > > Service <http://docs.yahoo.com/info/terms/<http://docs.yahoo.com/info/terms/>>. > > > > > > ----------------------------------------------------------------- ------- > > > ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum<http://groups.yahoo.com/group/WanderlodgeForum>" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service<http://docs.yahoo.com/info/terms/>. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] |
