Bay Height
11-24-2005, 17:31
Bay Height
Does anyone have the inside height dimensions for the storage bays? Is
there one with a greater height? I'm looking at the possibility of having to install a wheelchair and storage lift, probably a Harmar like this one on eBay: Item 5637491431 Thanks! Dave In Oklahoma Getting closer... |
11-25-2005, 01:11
Bay Height
Iwould talk to the people at Bluebird. They have a lot of experience
installing lifts and handicap appliances on various buses and coaches Stephen 77fc35 --- In WanderlodgeForum@yahoogroups.com, "Dave" wrote: > > Does anyone have the inside height dimensions for the storage bays? Is > there one with a greater height? > > I'm looking at the possibility of having to install a wheelchair and > storage lift, probably a Harmar like this one on eBay: Item > 5637491431 > > Thanks! > > Dave > In Oklahoma > Getting closer... > |
11-25-2005, 02:06
Bay Height
Check out the Newell at mrolivers.com, it may
give you some ideas. Bill 91pt40 norcal ----- Original Message ----- From: Stephen Birtles To: WanderlodgeForum@yahoogroups.com Sent: Friday, November 25, 2005 5:11 AM Subject: [WanderlodgeForum] Re: Bay Height Iwould talk to the people at Bluebird. They have a lot of experience installing lifts and handicap appliances on various buses and coaches Stephen 77fc35 --- In WanderlodgeForum@yahoogroups.com, "Dave" wrote: > > Does anyone have the inside height dimensions for the storage bays? Is > there one with a greater height? > > I'm looking at the possibility of having to install a wheelchair and > storage lift, probably a Harmar like this one on eBay: Item > 5637491431 > > Thanks! > > Dave > In Oklahoma > Getting closer... > SPONSORED LINKS Recreational vehicles Wanderlodge Automotive maintenance Recreational vehicle dealer Used recreational vehicles Automotive radiators ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] |
11-25-2005, 02:48
Bay Height
I have seen and be in the Newell at Mr. Olivers and it is mobility impaired
equipped and seemed, on casual inspection, to be in good condition. The only thing that I now recall about it is that it had a lift in the shower; I'm sure theres much more. Wallace Craig 95WLWB42 Azle, Tx Bill Goss Check out the Newell at mrolivers.com, it may give you some ideas. Bill 91pt40 norcal ----- Original Message ----- From: Stephen Birtles To: WanderlodgeForum@yahoogroups.com Sent: Friday, November 25, 2005 5:11 AM Subject: [WanderlodgeForum] Re: Bay Height Iwould talk to the people at Bluebird. They have a lot of experience installing lifts and handicap appliances on various buses and coaches Stephen 77fc35 --- In WanderlodgeForum@yahoogroups.com, "Dave" wrote: > > Does anyone have the inside height dimensions for the storage bays? Is > there one with a greater height? > > I'm looking at the possibility of having to install a wheelchair and > storage lift, probably a Harmar like this one on eBay: Item > 5637491431 > > Thanks! > > Dave > In Oklahoma > Getting closer... > SPONSORED LINKS Recreational vehicles Wanderlodge Automotive maintenance Recreational vehicle dealer Used recreational vehicles Automotive radiators ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] Yahoo! Groups Links --------------------------------- Yahoo! Music Unlimited - Access over 1 million songs. Try it free. [Non-text portions of this message have been removed] |
11-25-2005, 04:51
Bay Height
If you plan on modifying a coach like a bird or Newell you should
contact the factory. The sides of these coaches act as a truss inplace of frame rails. Stephen B gives good advice because the engineering has been done and replocating a proven retrofit is less expensive then cutting a critical structural component. Even replacing two side by side windows with one large window can cause a structure failure. I am sorry you have a need for a modified coach but happy that there are many modifications on the market that make things accesable. Gregory O'Connor 94pt40 Romoland CA --- In WanderlodgeForum@yahoogroups.com, Wallace Craig > > I have seen and be in the Newell at Mr. Olivers and it is mobility impaired equipped and seemed, on casual inspection, to be in good condition. The only thing that I now recall about it is that it had a lift in the shower; I'm sure theres much more. > Wallace Craig > 95WLWB42 > Azle, Tx > > Bill Goss > Check out the Newell at mrolivers.com, it may > give you some ideas. Bill 91pt40 norcal > ----- Original Message ----- > From: Stephen Birtles > To: WanderlodgeForum@yahoogroups.com > Sent: Friday, November 25, 2005 5:11 AM > Subject: [WanderlodgeForum] Re: Bay Height > > > Iwould talk to the people at Bluebird. They have a lot of experience > installing lifts and handicap appliances on various buses and coaches > Stephen 77fc35 > > --- In WanderlodgeForum@yahoogroups.com, "Dave" > wrote: > > > > Does anyone have the inside height dimensions for the storage bays? Is > > there one with a greater height? > > > > I'm looking at the possibility of having to install a wheelchair and > > storage lift, probably a Harmar like this one on eBay: Item > > 5637491431 > > > > Thanks! > > > > Dave > > In Oklahoma > > Getting closer... > > > > > > > > > SPONSORED LINKS Recreational vehicles Wanderlodge Automotive maintenance > Recreational vehicle dealer Used recreational vehicles Automotive radiators > > > -------------------------------------------------------------------- ---------- > YAHOO! GROUPS LINKS > > a.. Visit your group "WanderlodgeForum" on the web. > > b.. To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > -------------------------------------------------------------------- ---------- > > > > [Non-text portions of this message have been removed] > > > > > > Yahoo! Groups Links > > > > > > > > > > > > --------------------------------- > Yahoo! Music Unlimited - Access over 1 million songs. Try it free. > > [Non-text portions of this message have been removed] > |
