Generator Muffler
01-11-2006, 05:34
Post: #21
Generator Muffler
I need some ideas on a muffler for my Onan. I have a 5.5 gas Onan
that needs a new muffler. I contacted a muffler shop, and the guy said he could fit one, and probably nay muffler with the right size pipes would work. I want something that is quiet, and wonder if, indeed, anything from a small car would work? Jack Smith 1973FC31 SoCal --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > Brian, The more you muffel the more you create backpressure load and > heat. I bet they used the quietest setup for the time. My 94pt has > a kubota diesel on the gen set. I installed a aftermarket > scrubbermuffler (required to do demolition within a building for > sound and exhaust gas) on a kubota diesel in a tractor and burnt the > wireloom and melted my airfilter. > Gregory O'Connor > 94pt40 Romoland CAlifornia > > --- In WanderlodgeForum@yahoogroups.com, "Brian Gatley" > wrote: > > > > My mechanic has found that the generator muffler needs to be > replaced. > > He indicated that it is a muffler that he is not familiar with and > was > > wondering if there is a special muffler needed to replace the > existing > > muffler. I asked if we could just use a standard muffler that > would fit > > the space and he indicated that I would want to get a quieter > muffler > > with a little more packing than just a standard one. > > > > > > > > Any thoughts on what to replace it with? Is there a source for > > replacing with the existing model? > > > > > > > > Brian Gatley > > > > 93 WLWB PT40 > > > > Bend, OR > > > > > > > > [Non-text portions of this message have been removed] > > > |
01-11-2006, 12:15
Post: #22
Generator Muffler
Jack, I have used a muffler designed for a VW beetle, the kind that replaces the
stock dual exhaust with a single muffler that went across the rear of the car, it was very quiet. On another gas Onan, I used a muffler from a Thermoking diesel truck refrigeration unit, also very quiet. No problems with either. Bottom line is automotive mufflers work very well, but if you want quiet without the unwanted heat and backpressure Gregory mentioned, always use a muffler with a larger physical size than the original unit. In fact I would use the largest muffler I could fit, just make sure it is a reverse flow unit, not straight thru, and the exhaust will be the quietest part of your generator. Scott Peatross '87 PT40 Jack & Donna Smith I need some ideas on a muffler for my Onan. I have a 5.5 gas Onan that needs a new muffler. \ [Non-text portions of this message have been removed] |
User(s) browsing this thread: 12 Guest(s)
