Probably an easy question for most
01-21-2006, 12:53
I just bought an '95 42 ft. Bird and I tried to empty the black tank
and it won't open. The manual says to open it manually with a tool that evidently I didn't get with the coach. How can I empty it? Thanks in advance. |
01-21-2006, 16:21
Hi ?????,
We like to sign our messages here with name, type coach, and location. I had a '95 WBDA until today when we traded for a new Alpine. Had the same problem until I bought the new valves from Randy Dupree. I used a large screwdriver to pry them. once you get them started, they would open. Just make certain that you have the air pressure up. The new valves work without the need to pry. George Lowry '06 Alpine Apex - formerly '95 WBDA 4203 Spearfish, SD - Now in Quartzsite, AZ for a few days. moolah_85224 wrote: > I just bought an '95 42 ft. Bird and I tried to empty the black tank > and it won't open. The manual says to open it manually with a tool > that evidently I didn't get with the coach. How can I empty it? Thanks > in advance. > > > > > > > > Yahoo! Groups Links > > > > > > > > -- No virus found in this outgoing message. Checked by AVG Free Edition. Version: 7.1.375 / Virus Database: 267.14.19/231 - Release Date: 1/16/2006 |
01-21-2006, 23:07
Good Morning George & ?????,
I just wanted to remind you that Randy recently sold his Dupree Products Inc. to Jeff Miller and Jeff is still supplying our dump valve needs, his phone number is 1-616-355-9811 the web site is still the same, just a different owner. Check out; http://www.dupreeproducts.com/ "REMEMBER SEPTEMBER 11, 2001" John Finn '82 35FCRB BLUEBIRD WANDERLODGE TO VISIT THE "FINN'S INN EXPRESS" REMODELING ADVENTURE GO TO; http://www.pbase.com/image/24977457 ALSO VISIT THE: Wanderlodge Owners Group Forum http://autos.groups.yahoo.com/group/wanderlodge/ '66 SUPERIOR / IH 392 GAS V8 32' PUSHER "FOR SALE" SEE THE OLD COACH AT: http://www.pbase.com/image/26052733 HOPKINS, SOUTH CAROLINA /////////////////////////////////////////////////////////////// --- In WanderlodgeForum@yahoogroups.com, George Lowry wrote: > > Hi ?????, > > We like to sign our messages here with name, type coach, and location. > I had a '95 WBDA until today when we traded for a new Alpine. Had > the same problem until I bought the new valves from Randy Dupree. I > used a large screwdriver to pry them. once you get them started, they > would open. Just make certain that you have the air pressure up. The > new valves work without the need to pry. > > George Lowry > '06 Alpine Apex - formerly '95 WBDA 4203 > Spearfish, SD - Now in Quartzsite, AZ for a few days. > > moolah_85224 wrote: > > > I just bought an '95 42 ft. Bird and I tried to empty the black tank > > and it won't open. The manual says to open it manually with a tool > > that evidently I didn't get with the coach. How can I empty it? Thanks > > in advance. > > > > > > > > > > > > > > > > Yahoo! Groups Links > > > > > > > > > > > > > > > > > > > -- > No virus found in this outgoing message. > Checked by AVG Free Edition. > Version: 7.1.375 / Virus Database: 267.14.19/231 - Release Date: 1/16/2006 > |
01-22-2006, 03:46
On my coach there is a silver, flat metal bar that is screwed onto
the side wall of the grey water tank compartment. The compartment that has your valve opening controls. At the end of the bar, there is a 90 degree angle, the about another 2" length and a half moon cut-out at the end. You use this to Pry up the stuck valve. If you don't have one, then as George said, use a big screwdriver. Air up your coach, and open the valve switch. Gentle prying will open the valve. Once open, you need to lubricate it up. And it doesn't help just to spray lubricant on the shaft. And don't do that!!! That is not where it sticks. If you go to the wanderlodge owners online site, I have a excellent pictorial on how to remove and replace, or just lubricate the valves. It is under the article section, sub-category repair and maintenance. You may need new valve paddles, and those can be purchased from Jeff Miller at the Dupree site that John listed. good luck William Jensen 1993 PT40 WBWL Deerfield Beach, FL |
01-22-2006, 03:58
--- In WanderlodgeForum@yahoogroups.com, "William Jensen"
> > On my coach there is a silver, flat metal bar that is screwed onto > the side wall of the grey water tank compartment. The compartment > that has your valve opening controls. At the end of the bar, there > is a 90 degree angle, the about another 2" length and a half moon > cut-out at the end. You use this to Pry up the stuck valve. If > you don't have one, then as George said, use a big screwdriver. > Air up your coach, and open the valve switch. Gentle prying will > open the valve. > > Once open, you need to lubricate it up. And it doesn't help just to > spray lubricant on the shaft. And don't do that!!! That is not > where it sticks. If you go to the wanderlodge owners online site, I > have a excellent pictorial on how to remove and replace, or just > lubricate the valves. It is under the article section, sub-category > repair and maintenance. You may need new valve paddles, and those > can be purchased from Jeff Miller at the Dupree site that John > listed. > > good luck > > William Jensen > 1993 PT40 WBWL > Deerfield Beach, FL > Thanks to you both. Can you give me a link to the Wanderlodge owneres online site? |
01-22-2006, 04:09
--- In WanderlodgeForum@yahoogroups.com, "moolah_85224" <moolah@m...>
wrote: > > --- In WanderlodgeForum@yahoogroups.com, "William Jensen" > > > > > On my coach there is a silver, flat metal bar that is screwed onto > > the side wall of the grey water tank compartment. The compartment > > that has your valve opening controls. At the end of the bar, there > > is a 90 degree angle, the about another 2" length and a half moon > > cut-out at the end. You use this to Pry up the stuck valve. If > > you don't have one, then as George said, use a big screwdriver. > > Air up your coach, and open the valve switch. Gentle prying will > > open the valve. > > > > Once open, you need to lubricate it up. And it doesn't help just to > > spray lubricant on the shaft. And don't do that!!! That is not > > where it sticks. If you go to the wanderlodge owners online site, I > > have a excellent pictorial on how to remove and replace, or just > > lubricate the valves. It is under the article section, sub-category > > repair and maintenance. You may need new valve paddles, and those > > can be purchased from Jeff Miller at the Dupree site that John > > listed. > > > > good luck > > > > William Jensen > > 1993 PT40 WBWL > > Deerfield Beach, FL > > > > Thanks to you both. Can you give me a link to the Wanderlodge owneres > online site? > Forgot, Tom Merriman Chandler, AZ |
01-22-2006, 14:11
> Thanks to you both. Can you give me a link to the Wanderlodge owneres > online site? > www dot wanderlodge dot us visit as a guest. Join when you want. William Jensen 1993 PT40 WBWL Deerfield Beach, FL |
