HOW TO SEAL TINY LEAK IN 1993 WL BLACK WATER TANK?
01-29-2006, 06:59
Howdy, Forumites.
We discovered a tiny leak in our coach's black water tank. :-& :-& I have created a photo album in the Photos section entitled Pearce 1993 BWT with photos of the location of the leak. We DON'T KNOW the composition of the tank so are not sure as to what material to use to seal this leak. Jack has used some RTV to try to seal the leak. He will check it daily to see if the RTV has fixed the problem. It looks as though the tank has been repaired before in this same area but we don't know for sure. Suggestions, ideas and recommendations would be much appreciated in helping us solve this problem. We feel that we should be able to go 5-7 days before having to dump the BWT. :-? Thanks, Liz Regards, Jack and Liz Pearce Fulltiming in a 1993 Wanderlodge WB40 Homesick Texans in SE. FL [Non-text portions of this message have been removed] |
01-30-2006, 05:56
Your use of RTV may hold up...if it does, your done! But if you
have further problems, i can recommend a product i have found often at hardware & marine stores...Starbright/West Marine Epoxy Putty Stick. Comes in a tube, you cut off what you need, knead it for a minute, stick it on, mould it, and in a while, it hardens like stone! As such, it is not a good gasket material, but a good plug or used to fill. I have used it for my a black tank leak (just a slow drip near a fitting, perhaps a rock hit) and it has held up great for over a year. I just cleaned the area up with sandpaper and used it. I always keep some handy, it stores well. frank 85fc33 Woodbridge, va. --- In WanderlodgeForum@yahoogroups.com, "Jack and Liz Pearce" > > Howdy, Forumites. > We discovered a tiny leak in our coach's black water tank. :-& :- & I have created a photo album in the Photos section entitled Pearce 1993 BWT with photos of the location of the leak. We DON'T KNOW the composition of the tank so are not sure as to what material to use to seal this leak. Jack has used some RTV to try to seal the leak. He will check it daily to see if the RTV has fixed the problem. It looks as though the tank has been repaired before in this same area but we don't know for sure. Suggestions, ideas and recommendations would be much appreciated in helping us solve this problem. We feel that we should be able to go 5-7 days before having to dump the BWT. :-? > > Thanks, > Liz > Regards, > Jack and Liz Pearce > Fulltiming in a 1993 Wanderlodge WB40 > Homesick Texans in SE. FL > > > > > > [Non-text portions of this message have been removed] > |
01-30-2006, 06:24
I always attempt to fix a problem on my coach the best way possible
so it is restored to its original or better condition. On my 1982 FC35 the black and grey water tanks are fiberglass. I had a small leak at the output of the black water tank and since the connections were over 20 years old, decided to cut them off and start from scratch again. On my tanks the outputs were heavy PVC female screw connectors that were still clean and tight so I just replaced everything from there to the outlet of the ABS pipe and added electrical dump valves. On your 1993 Jack I would call Bennie at BB and ask him what your tanks are made of. If they are fiberglass then you have a relatively easy fix. If they are some form of plastic then that is easily fixed also. There are plastic welding kits that you can buy that will make a weld every bit as good as the original. The plastic rods to weld with come in a variety of types and are easily purchased. I happen to have a rather expensive Leister triac welder that I was fortunate to have purchased new at a flea market. http://www.hotairtools.com/plastics.htm If you do have some type of plastic tanks this might help you. http://www.hometown.aol.com/newimageplas...ngrod.html good luck tom warner 1982 FC35 Vernon Center,NY At 12:56 PM 1/30/2006, you wrote: >Your use of RTV may hold up...if it does, your done! But if you >have further problems, i can recommend a product i have found often >at hardware & marine stores...Starbright/West Marine Epoxy Putty >Stick. Comes in a tube, you cut off what you need, knead it for a >minute, stick it on, mould it, and in a while, it hardens like >stone! As such, it is not a good gasket material, but a good plug >or used to fill. I have used it for my a black tank leak (just a >slow drip near a fitting, perhaps a rock hit) and it has held up >great for over a year. I just cleaned the area up with sandpaper >and used it. I always keep some handy, it stores well. > >frank >85fc33 >Woodbridge, va. > >--- In WanderlodgeForum@yahoogroups.com, "Jack and Liz Pearce" > > > > > Howdy, Forumites. > > We discovered a tiny leak in our coach's black water tank. :-& :- >& I have created a photo album in the Photos section entitled Pearce >1993 BWT with photos of the location of the leak. We DON'T KNOW the >composition of the tank so are not sure as to what material to use >to seal this leak. Jack has used some RTV to try to seal the leak. >He will check it daily to see if the RTV has fixed the problem. It >looks as though the tank has been repaired before in this same area >but we don't know for sure. Suggestions, ideas and recommendations >would be much appreciated in helping us solve this problem. We feel >that we should be able to go 5-7 days before having to dump the >BWT. :-? > > > > Thanks, > > Liz > > Regards, > > Jack and Liz Pearce > > Fulltiming in a 1993 Wanderlodge WB40 > > Homesick Texans in SE. FL > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > >---------- >YAHOO! GROUPS LINKS > > * Visit your group > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. > * > * To unsubscribe from this group, send an email to: > * > odgeForum-unsubscribe@yahoogroups.com > > * > * Your use of Yahoo! Groups is subject to the > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > >---------- |
01-30-2006, 13:53
Howdy, Tom.
> On your 1993 Jack I would call Bennie at BB and ask him what your > tanks are made of. If they are fiberglass then you have a relatively > easy fix. If they are some form of plastic then that is easily fixed > also. There are plastic welding kits that you can buy that will make > a weld every bit as good as the original. The plastic rods to weld > with come in a variety of types and are easily purchased. I happen to > have a rather expensive Leister triac welder that I was fortunate to > have purchased new at a flea market. > http://www.hotairtools.com/plastics.htm > > If you do have some type of plastic tanks this might help > you. http://www.hometown.aol.com/newimageplas...ngrod.html > > good luck OK. I'll call Bennie. Thank you so much for your detailed reply. ![]() Much obliged, Liz Regards, Jack and Liz Pearce Fulltiming in a 1993 Wanderlodge WB40 Homesick Texans in SE. FL [Non-text portions of this message have been removed] |
01-30-2006, 13:58
Howdy, Frank.
>>>--- In WanderlodgeForum@yahoogroups.com, "fwernlein" > > Your use of RTV may hold up...if it does, your done! But if you > have further problems, i can recommend a product i have found often > at hardware & marine stores...Starbright/West Marine Epoxy Putty > Stick. Comes in a tube, you cut off what you need, knead it for a > minute, stick it on, mould it, and in a while, it hardens like > stone! As such, it is not a good gasket material, but a good plug > or used to fill. I have used it for my a black tank leak (just a > slow drip near a fitting, perhaps a rock hit) and it has held up > great for over a year. I just cleaned the area up with sandpaper > and used it. I always keep some handy, it stores well.>>> OK, thanks for the reply. I will definitely have to find out what the tank is made of. Regards, Liz Regards, Jack and Liz Pearce Fulltiming in a 1993 Wanderlodge WB40 Homesick Texans in SE. FL [Non-text portions of this message have been removed] |
