leveling jack question
02-02-2006, 15:59
Hi
I crack a fitting that goes into the top of the rear leveling jack, ( do ask it
is a long story)
i removed the bad fitting. got a new one my question is do i fill the jack with
fluid or how do I
bleed the air out? or do I ?
if you are wondering I had a peice of railroad tie I have used for over a year
to dispurse the
weight & the dam thing split sending the jack forward! what a noise glad I
wasn't under the
bird,,, another lesson learned
-guy smalley
86 pt 40
02-02-2006, 23:57
I believe it calls for Dextron II (now III) ATF fluid, not power steering
fluid. That's what I've been using....
Kevin Mc
YL CA
86 38 PT
02-03-2006, 01:08
no bleeding. activate the jack normally. it will take a minute for the
system to replace the air with power steering fluid, but when it does, your
done.
dandarst86fc35rbhuntleyil.
>From: "guysmalley"
>Subject: [WanderlodgeForum] leveling jack question
>Date: Fri, 03 Feb 2006 03:59:55 -0000
>Hi
>ask it is a long story)
>with fluid or how do I
>year to dispurse the
>wasn't under the
>-guy smalley
>86 pt 40
02-03-2006, 08:19
Didn't know that...you learn something everyday!!
KM
02-03-2006, 08:33
In my experience power steering fluid equals ATF.
>From: krminyl@...
>Subject: Re: [WanderlodgeForum] leveling jack question
>Date: Fri, 3 Feb 2006 11:57:10 EST
>Kevin Mc
>YL CA
>86 38 PT
