New file uploaded to WanderlodgeForum
02-19-2006, 04:36
Post: #61
A neat write-up of a common story from when we were all newbies or
wannabes and for many of us, before these help forums existed. Thanks for posting it. Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, WanderlodgeForum@yahoogroups.com wrote: > > > Hello, > > This email message is a notification to let you know that > a file has been uploaded to the Files area of the WanderlodgeForum > group. > > File : /BB to date.doc > Uploaded by : fwernlein > Description : Newbee & Wannabes....read this. > > You can access this file at the URL: > http://groups.yahoo.com/group/Wanderlodg...20date.doc > > To learn more about file sharing for your group, please visit: > http://help.yahoo.com/help/us/groups/files > > Regards, > > fwernlein > |
03-13-2006, 15:08
Post: #62
Hello,
This email message is a notification to let you know that a file has been uploaded to the Files area of the WanderlodgeForum group. File : /Jac Page1.jpg Uploaded by : wanderlodge3208 <share@...> Description : Jacobs Retarder Instruction Manual You can access this file at the URL: http://groups.yahoo.com/group/Wanderlodg...0Page1.jpg To learn more about file sharing for your group, please visit: http://help.yahoo.com/help/us/groups/files Regards, wanderlodge3208 <share@...> |
03-13-2006, 16:02
Post: #63
Hello,
This email message is a notification to let you know that a file has been uploaded to the Files area of the WanderlodgeForum group. File : /Jacobs Retarder Manual/Jac CoverSM.JPG Uploaded by : wanderlodge3208 <share@...> Description : Front Cover You can access this file at the URL: http://groups.yahoo.com/group/Wanderlodg...nual/\ Jac%20CoverSM.JPG To learn more about file sharing for your group, please visit: http://help.yahoo.com/help/us/groups/files Regards, wanderlodge3208 <share@...> |
03-13-2006, 16:24
Post: #64
FWIW, this is for a retarder, not the Jake brake.
There are four types or means of auxiliary braking available and at least three have been used on the BB WL. The Jake Brake was originally developed by the Jacob's Machine Co. It is correctly called an engine brake because it changes the timing of the exhaust valves to utilize the engine compression for braking. The Exhaust brake was originally developed by Pac Brake of Canada. It is basically a butterfly valve that closes the exhaust causing greater back pressure which gives a braking effect. The Telma Retarder, pictured here as the Jacob's retarder, is a magnetic device that uses magnetic field to reduce the rotational speed of the drive shaft. The transmission retarder, which is available on Allison transmissions, is basically a torque converter working backwards. The braking effect is dissipated as heat. The first three, and I believe the fourth also, have had their patents expire which means that anyone can produce these items and there are several companies that produce more than one of these items. Jacob's is one of these companies. Ernie is looking for information on the Jake or engine brake. . George Lowry '06 Alpine Apex - Formerly '95 WBDA 4203 Spearfish, SD - Last day at Wilderness Lakes TTN, CA WanderlodgeForum@yahoogroups.com wrote: > Hello, > > This email message is a notification to let you know that > a file has been uploaded to the Files area of the WanderlodgeForum > group. > > File : /Jacobs Retarder Manual/Jac CoverSM.JPG > Uploaded by : wanderlodge3208 <share@...> > Description : Front Cover > > You can access this file at the URL: > http://groups.yahoo.com/group/Wanderlodg...nual/\ Jac%20CoverSM.JPG > > To learn more about file sharing for your group, please visit: > http://help.yahoo.com/help/us/groups/files > > Regards, > > wanderlodge3208 <share@...> > > > > > > > > > > Yahoo! Groups Links > > > > > > > > |
03-13-2006, 19:27
Post: #65
Thanks to Stephen for uploading that file. George is correct, I need the
engine brake retarder schematics. Ernie-83pt40 in Louisiana [Non-text portions of this message have been removed] |
03-14-2006, 00:58
Post: #66
Scott- the jacobs engine brake is what I need. Thanks, hope your rally is a
success. ernie-83pt40-going home wed!!! [Non-text portions of this message have been removed] |
03-14-2006, 02:15
Post: #67
Heck Ernie, I have those, I thought you wanted the Jake brake stuff I
do not have a Jake on my coach. I have the retarder. Email me and I will either snail mail it or scan and email..depends on you. Scott B 86FC35 "RUBY" Murrells Inlet SC "right next to heaven" --- In WanderlodgeForum@yahoogroups.com, erniecarpet@... wrote: > > Thanks to Stephen for uploading that file. George is correct, I need the > engine brake retarder schematics. Ernie-83pt40 in Louisiana > > > [Non-text portions of this message have been removed] > |
03-14-2006, 02:43
Post: #68
Opps.. no problem..
Well, If any one needs it, its there.. LOL Stephen 81 FC-33SB Plant City, FL _____ From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of erniecarpet@... Sent: Tuesday, March 14, 2006 7:28 AM To: WanderlodgeForum@yahoogroups.com Subject: Re: [WanderlodgeForum] New file uploaded to WanderlodgeForum Thanks to Stephen for uploading that file. George is correct, I need the engine brake retarder schematics. Ernie-83pt40 in Louisiana [Non-text portions of this message have been removed] |
03-22-2006, 07:34
Post: #69
Hello,
This email message is a notification to let you know that a file has been uploaded to the Files area of the WanderlodgeForum group. File : /Rally Information/Lone Star Birds Rally Schedule 2006.pdf Uploaded by : mbulriss <mbulriss@...> Description : Lone Star Birds 2006 Rally Schedule You can access this file at the URL: http://groups.yahoo.com/group/Wanderlodg...ne%20\ Star%20Birds%20Rally%20Schedule%202006.pdf To learn more about file sharing for your group, please visit: http://help.yahoo.com/help/us/groups/files Regards, mbulriss <mbulriss@...> |
03-23-2006, 10:53
Post: #70
Hello,
This email message is a notification to let you know that a file has been uploaded to the Files area of the WanderlodgeForum group. File : /Question Sensor.JPG Uploaded by : wanderlodge3208 <share@...> Description : Question sensor You can access this file at the URL: http://groups.yahoo.com/group/Wanderlodg...Sensor.JPG To learn more about file sharing for your group, please visit: http://help.yahoo.com/help/us/groups/files Regards, wanderlodge3208 <share@...> |
