Still need answers: prospective owner
03-14-2006, 02:54
I believe the weight of a 35FC is around 32,000. CCC is not an issue. I have
stored all my stuff, very well, I also had a roof pod. We got around 7-9 mpg with our coach. If you cruise around 60, that is. Some folks mount their satellite on the roof ladder. Lots of options. Ernie-83pt40 in louisiana [Non-text portions of this message have been removed] |
03-14-2006, 05:48
I am still awaiting some answers from the experts. Please I need to
know!! What is the GVWR of a mid 80's FC35? What about CCC? Are there any problems with one axle or wheel position being overloaded? What is the empty weight of an FC35 ? 2.What about turning radius? I see the newer chassis advertising wheel cuts from 50 to 56. What is the wheel cut of a BB? 3.What is the torque rating of the 3208T? Does the Allison 4 spd. handle this power well? 4.Do all the BB's (FC) have only electric water heaters with motor aid or did they offer a gas heater? If not has anyone retrofitted one? 5. Fuel mileage: Most of the posts I read talk about 6 or 7 mpg. This does sound right for a heavy vehicle that is as aerodynamic as a 4x8 sheet of plywood but I also see some who claim closer to 10. Which is likely? I am aware that mpg varies by driver, conditions and egos. 5. I am watching the posts about batteries. I still find it hard to believe that BB would not supply a seperate starting battery. The 6 volts are NOT designed for the heavy instant load of a starter motor. I I think the installation of at least a series 31 would be my first mod. 6. Storage space. I understand this is lacking. Where do you put: hoses, cords, tools, boards, jack, spare parts, etc.? I have a tripod satellite internet system and wonder how I could transport the dish. I did get a few good replies via email. Thank you to those kind persons. Thanks : Bruce no BB YET! |
03-14-2006, 07:22
wrote: > > I am still awaiting some answers from the experts. Please I need to > know!! > > > > What is the GVWR of a mid 80's FC35? What about CCC? Are there any > problems with one axle or wheel position being overloaded? What is the > empty weight of an FC35 ? > 2.What about turning radius? I see the newer chassis advertising wheel > cuts from 50 to 56. What is the wheel cut of a BB? > 3.What is the torque rating of the 3208T? Does the Allison 4 spd. > handle this power well? > 4.Do all the BB's (FC) have only electric water heaters with motor aid > or did they offer a gas heater? If not has anyone retrofitted one? > 5. Fuel mileage: Most of the posts I read talk about 6 or 7 mpg. This > does sound right for a heavy vehicle that is as aerodynamic as a 4x8 > sheet of plywood but I also see some who claim closer to 10. Which is > likely? I am aware that mpg varies by driver, conditions and egos. > 5. I am watching the posts about batteries. I still find it hard to > believe that BB would not supply a seperate starting battery. The 6 > volts are NOT designed for the heavy instant load of a starter motor. > I > I think the installation of at least a series 31 would be my first > mod. > 6. Storage space. I understand this is lacking. Where do you put: > hoses, cords, tools, boards, jack, spare parts, etc.? I have a tripod > satellite internet system and wonder how I could transport the dish. > > > I did get a few good replies via email. Thank you to those kind > persons. > > Thanks : Bruce > no BB YET! Hi Bruce On my 86 pt40 my fully loaded wieght is 47,200 yes you can overload the different axles, when you get your coach one of the first things to do is weight your coach on a truck scale then you will know each axle load and rearrange the load as you need to. all the load ranges are listed on the coach, mine in the forward compartment. Batteries, I installed 6 interstate deep cell batteries with a new smart charger, no problems. the gen has its own battery steering radius who knows? I went to the biggest parking lot I found and just tested the radius and found what the limits were. storage there is never enough, keep it light you'll be surprize what you can do without. mpg ha I don't want to know but I found a big different going slower 60-65 mph, whats the hurry go for it I never regretted the purchase guy smalley 86 pt40 > |
03-14-2006, 08:02
I'm with you. I don't like electric hot water heaters. I will
probably install a gas tankless hot water heater in the future. Had one on a motorhome in Europe and I really liked it. A small Paloma can be mounted on a wall and vented thru the roof. Unlimited supply and very efficient. You could leave the existing heater in place. I have one sitting in my basement waiting to be installed. Having just moved from a Travco 220 to an FC, I find the amount of storage huge. No lack of space to carry tools, spare parts, etc. Kerry --- In WanderlodgeForum@yahoogroups.com, "birdshill123" > > I am still awaiting some answers from the experts. Please I need to > know!! > > > > What is the GVWR of a mid 80's FC35? What about CCC? Are there any > problems with one axle or wheel position being overloaded? What is the > empty weight of an FC35 ? > 2.What about turning radius? I see the newer chassis advertising wheel > cuts from 50 to 56. What is the wheel cut of a BB? > 3.What is the torque rating of the 3208T? Does the Allison 4 spd. > handle this power well? > 4.Do all the BB's (FC) have only electric water heaters with motor aid > or did they offer a gas heater? If not has anyone retrofitted one? > 5. Fuel mileage: Most of the posts I read talk about 6 or 7 mpg. This > does sound right for a heavy vehicle that is as aerodynamic as a 4x8 > sheet of plywood but I also see some who claim closer to 10. Which is > likely? I am aware that mpg varies by driver, conditions and egos. > 5. I am watching the posts about batteries. I still find it hard to > believe that BB would not supply a seperate starting battery. The 6 > volts are NOT designed for the heavy instant load of a starter motor. > I > I think the installation of at least a series 31 would be my first > mod. > 6. Storage space. I understand this is lacking. Where do you put: > hoses, cords, tools, boards, jack, spare parts, etc.? I have a tripod > satellite internet system and wonder how I could transport the dish. > > > I did get a few good replies via email. Thank you to those kind > persons. > > Thanks : Bruce > no BB YET! > |
03-14-2006, 14:29
A mid-'80s FC35 is rated at 34,600 GVWR. Mine always weighed around
32,000 fully loaded with 265gallons of diesel, 110gallons of fuel, a couple-hundred pounds of tools and spares, and my family of six with their belongings. Yes you can overload the front axle, if you have an empty fuel tank, empty fresh water, full waste tanks, and people/belongings loaded front-heavy. I believe that the drive-axle (24,000cap) is difficult to overload, we couldn't do it, even with 27' of enclosed trailer behind full of car and stuff. Wheel cut is good for advertising, you need to know turning radius. I don't have the number, but the FC is pretty good, especially curb- curb because of the combination of wheel cut and front overhang. Different years had different geometry. On the disposable-fiberglass coaches they need as long a wheelbase as possible to handle crosswinds etc, so they need a sharp wheel cut to make up for it. The stability of the BlueBird platform didn't need the stretched wheelbase for crosswind & truck-wake resistance, it is already in there, so the shorter wheelbase allows shorter turns. Still a big bus though. Mileage? I drive with the loud-pedal pretty well floored most of the time. I've upped horsepower, changed gearing, always run full of fluids, and am usually trying to make time. In all of my FCs from 210hp to 300hp I got between 7.5 and 8.5mpg. The allison MT-643 isn't the most refined feeling transmission, but it is a garbage-truck transmission, a school-bus transmission, dump- trucks, ... pretty hard to wear it out. Rated for the 3208T's hp and torque. Don't knock the electric/motoraid setup, it will hold 12gallons of very hot water from engine heat, plenty for a shower the next morning. For extended stays you need electricity once per day anyway, most of us fire up the genset for coffee and battery charging before we get into the shower. A gas water heater would be fine, but while the genset is running it is best to have a load, not just battery charging. If you're going to dry-camp in this manner, a gas water heater and pocket-sized portable genset for charging the batteries is a good setup. A diesel-fired heater is better still, heat the coach, engine, domestic water, all at the same time with little electric use and diesel has more BTUs than LP with less possibility of going boom. - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, "birdshill123" > > I am still awaiting some answers from the experts. Please I need to > know!! > > > > What is the GVWR of a mid 80's FC35? What about CCC? Are there any > problems with one axle or wheel position being overloaded? What is the > empty weight of an FC35 ? > 2.What about turning radius? I see the newer chassis advertising wheel > cuts from 50 to 56. What is the wheel cut of a BB? > 3.What is the torque rating of the 3208T? Does the Allison 4 spd. > handle this power well? > 4.Do all the BB's (FC) have only electric water heaters with motor aid > or did they offer a gas heater? If not has anyone retrofitted one? > 5. Fuel mileage: Most of the posts I read talk about 6 or 7 mpg. This > does sound right for a heavy vehicle that is as aerodynamic as a 4x8 > sheet of plywood but I also see some who claim closer to 10. Which is > likely? I am aware that mpg varies by driver, conditions and egos. > 5. I am watching the posts about batteries. I still find it hard to > believe that BB would not supply a seperate starting battery. The 6 > volts are NOT designed for the heavy instant load of a starter motor. > I > I think the installation of at least a series 31 would be my first > mod. > 6. Storage space. I understand this is lacking. Where do you put: > hoses, cords, tools, boards, jack, spare parts, etc.? I have a tripod > satellite internet system and wonder how I could transport the dish. > > > I did get a few good replies via email. Thank you to those kind > persons. > > Thanks : Bruce > no BB YET! > |
03-14-2006, 14:41
I guess that before you condemn the 4-GC6 battery setup, try it. Being
series-parallel, there are plenty of cranking amps if the batteries are good, cables are good, and charging system is working properly. In short it works, that's why there are still thousands of BB/FC coaches out there using this system after 15-25years. Sure the addition of a pair of starting batteries would be optimum, but most of us don't want to give up the storage for something that the coach doesn't need. I've gotten very familiar with Mike H's setup with an additional battery bank, it works exceptionally well. He has the storage, wants the inverter bank, it is a great setup also. - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, "birdshill123" > > I am still awaiting some answers from the experts. Please I need to > know!!<<snip>> > 5. I am watching the posts about batteries. I still find it hard to > believe that BB would not supply a seperate starting battery. The 6 > volts are NOT designed for the heavy instant load of a starter motor. > I > I think the installation of at least a series 31 would be my first > mod.<<snip>> |
03-14-2006, 23:29
As usual Jeff is right on with his answers here. I used to dry camp
for two weeks with ours with no problems whatsoever. I would run the generator a bit each day and didn't have any concern. The only thing related to batteries in the 1980 (and others) that I would concern myself with is the chargers. If it still has the old battery boilers I would consider going to a good microprocessor controlled charger such as the Truecharge or others. Other than that upgrade I use Trogan T125's (on my 6th year) and keep check on the water. As far as planning other mods I would suggest owning the coach first and get used to it. Its easy to get caught up in the excitement of buying an older bird and wanting to fix her up but you may find that some things such as the hot water system are a really good design for the period and will meet most folks needs more than adequately. Even though they are now 26 years old, alot of the systems in the 1980 are still a far cry better (and of higher quality) than what is in most new fiberglass rv's today. Try it, use it a while, fix what is broken and then make experience based decisions later on what you want to modify...... Best of luck, John Stiles 1980 33FC "My Navion" Stockbridge, GA --- In WanderlodgeForum@yahoogroups.com, "Jeff Miller" > > I guess that before you condemn the 4-GC6 battery setup, try it. Being > series-parallel, there are plenty of cranking amps if the batteries are > good, cables are good, and charging system is working properly. In > short it works, that's why there are still thousands of BB/FC coaches > out there using this system after 15-25years. > > Sure the addition of a pair of starting batteries would be optimum, but > most of us don't want to give up the storage for something that the > coach doesn't need. > > I've gotten very familiar with Mike H's setup with an additional > battery bank, it works exceptionally well. He has the storage, wants > the inverter bank, it is a great setup also. > > - Jeff Miller > in Holland, MI > > > --- In WanderlodgeForum@yahoogroups.com, "birdshill123" > > > > > I am still awaiting some answers from the experts. Please I need to > > know!!<<snip>> > > 5. I am watching the posts about batteries. I still find it hard to > > believe that BB would not supply a seperate starting battery. The 6 > > volts are NOT designed for the heavy instant load of a starter motor. > > I > > I think the installation of at least a series 31 would be my first > > mod.<<snip>> > |
03-15-2006, 02:33
Boy, anyone who has seen the work John and his wife
have personally done on their 1980 model Bluebird, has to bow in deference to their recommendation to try the coach out first, and then decide what changes/upgrades to make. John, are the pictures posted? If not, it might be a good excuse for a trip for a prospective purchaser to see what they have done. John Suter --- John Stiles > As usual Jeff is right on with his answers here. I > used to dry camp > for two weeks with ours with no problems whatsoever. > I would run > the generator a bit each day and didn't have any > concern. The only > thing related to batteries in the 1980 (and others) > that I would > concern myself with is the chargers. If it still > has the old > battery boilers I would consider going to a good > microprocessor > controlled charger such as the Truecharge or others. > Other than > that upgrade I use Trogan T125's (on my 6th year) > and keep check on > the water. As far as planning other mods I would > suggest owning the > coach first and get used to it. Its easy to get > caught up in the > excitement of buying an older bird and wanting to > fix her up but you > may find that some things such as the hot water > system are a really > good design for the period and will meet most folks > needs more than > adequately. Even though they are now 26 years old, > alot of the > systems in the 1980 are still a far cry better (and > of higher > quality) than what is in most new fiberglass rv's > today. Try it, > use it a while, fix what is broken and then make > experience based > decisions later on what you want to modify...... > > Best of luck, > > John Stiles > 1980 33FC > "My Navion" > Stockbridge, GA > > > --- In WanderlodgeForum@yahoogroups.com, "Jeff > Miller" > > > > > I guess that before you condemn the 4-GC6 battery > setup, try it. > Being > > series-parallel, there are plenty of cranking amps > if the > batteries are > > good, cables are good, and charging system is > working properly. In > > short it works, that's why there are still > thousands of BB/FC > coaches > > out there using this system after 15-25years. > > > > Sure the addition of a pair of starting batteries > would be > optimum, but > > most of us don't want to give up the storage for > something that > the > > coach doesn't need. > > > > I've gotten very familiar with Mike H's setup with > an additional > > battery bank, it works exceptionally well. He has > the storage, > wants > > the inverter bank, it is a great setup also. > > > > - Jeff Miller > > in Holland, MI > > > > > > --- In WanderlodgeForum@yahoogroups.com, > "birdshill123" > > > > > > > > I am still awaiting some answers from the > experts. Please I need > to > > > know!!<<snip>> > > > 5. I am watching the posts about batteries. I > still find it hard > to > > > believe that BB would not supply a seperate > starting battery. > The 6 > > > volts are NOT designed for the heavy instant > load of a starter > motor. > > > I > > > I think the installation of at least a series 31 > would be my > first > > > mod.<<snip>> > > > > > > > __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com |
