Broken valves and broken dreams
03-15-2006, 13:26
It should be noted that BlueBird recommended and I quote; Keep it around 2000
rpm. The recommendation is for the 3208. Cat calls 2400 rpm in marine
applications, "continuous cruise speed".
Some people think it's wise to check valve adjustment every 50k miles, some
think that's too much. I check it more often as I fear broken parts and I DO
NOT EVER take short cuts with my vehicles of any kind.
However, ignorance is bliss for most folks and occasionally the bite in the butt
from reality hurts.
Weak valve springs is the most common cause of valve failure, springs can lose
tension in storage. At rest, some valves are open at max lift and some are
closed. Those that are open can take a set and lose closing strength, this
allows the valve to bounce in operation, compound the problem by running
2700/2800 rpm and some times stuff breaks.
Watch that valve lash and check the valve spring tension regularly, other wise,
keep your fingers crossed. Ain't diesels fun?
Mike Hohnstein
Germantown, WI
83FC35
03-16-2006, 12:32
around 2000 rpm. The recommendation is for the 3208. Cat calls 2400
rpm in marine applications, "continuous cruise speed".
miles, some think that's too much. I check it more often as I fear
broken parts and I DO NOT EVER take short cuts with my vehicles of
any kind.
bite in the butt from reality hurts.
springs can lose tension in storage. At rest, some valves are open at
max lift and some are closed. Those that are open can take a set and
lose closing strength, this allows the valve to bounce in operation,
compound the problem by running 2700/2800 rpm and some times stuff
breaks.
other wise, keep your fingers crossed. Ain't diesels fun?
> Mike Hohnstein
> Germantown, WI
> 83FC35
Just one nagging question and that concerns the chart on the Vintage
Bird site! it states that at 2000 RPM' at 3208 n/a engine in a F/C
unit speed will be 48 MPH. Now lets get real about keeping it at 2000
RPM's and going down a freeway. Do you think when these coaches came
out that the Bluebird Corporation stated in there factory manuals
that there motor coaches would last allot longer if they were only
driven under 50 MPH? I might be different than most drivers but I try
to keep my speed at 55 but not 48 mph on the freeway. Does anyone
have a drivers manual for one of these old units? it would be
interesting to check it out and see what corp. said in those days.
Jon
1978 Wanderlodge
Bremerton Washington
03-16-2006, 13:35
Hmm, 2200 is 55 in your "vehicle", sounds like "around" 2 grand to me. Mebbe
you need a hobby?
MH
Sent: Thursday, March 16, 2006 6:32 PM
Subject: [WanderlodgeForum] Re: Broken valves and broken dreams
any kind.
breaks.
> Mike Hohnstein
> Germantown, WI
> 83FC35
Jon
1978 Wanderlodge
radiators
YAHOO! GROUPS LINKS
03-16-2006, 13:45
I have a 78 FC 33 with a non turbo 3208. My mechanic
says to keep it under 2500 however that is also around
55-60. I have others tell me that work on Cats that
those motors love to rev....
i am also confused???
Help
Chris
78 FC 33 Palmdale, ca "Seguro"
> "around" 2 grand to me. Mebbe you need a hobby?
> MH
> From: Jon
> broken dreams
> Hohnstein"
> I quote; Keep it
> speed".
> with my vehicles of
> any kind.
> occasionally the
> valve failure,
> valves are open at
> can take a set and
> some times stuff
> breaks.
> tension regularly,
> diesels fun?
> > Mike Hohnstein
> > Germantown, WI
> > 83FC35
> removed]
> engine in a F/C
> keeping it at 2000
> these coaches came
> factory manuals
> if they were only
> it would be
> said in those days.
> Jon
> 1978 Wanderlodge
> recreational vehicles Automotive radiators
> YAHOO! GROUPS LINKS
> web.
> email to:
> removed]
Do You Yahoo!?
http://mail.yahoo.com
03-16-2006, 14:51
The CAT operators manual for my coach says nothing about optimal rpm.
It says do not run it above the rated rpm on the engine plate
(2800rpm for a 210hp na). It says it can be run at full load between
the rated rpm and 1900rpm (for NA) It does say DO NOT run it at full
load under 1900rpm (for short periods, down to 1400 rpm's) for an NA
or not below 1400rpm for a turbo. If they thought there was an
optimal rpm, why not include it within all those limits?
Kerry
82 FC 35
Denver
--- In WanderlodgeForum@yahoogroups.com, Mr Chris Valdes
> Help
> Chris
03-16-2006, 15:02
I told the forums the way it is, there are plenty of "other"folks who like to
talk with out facts or reality to back up their remarks. I know what I'm
talking about.
MH
Sent: Thursday, March 16, 2006 7:45 PM
Subject: Re: [WanderlodgeForum] Re: Broken valves and broken dreams
Help
Chris
> MH
> From: Jon
> broken dreams
> Hohnstein"
> I quote; Keep it
> speed".
> with my vehicles of
> any kind.
> occasionally the
> valve failure,
> valves are open at
> can take a set and
> some times stuff
> breaks.
> tension regularly,
> diesels fun?
> > Mike Hohnstein
> > Germantown, WI
> > 83FC35
> removed]
> engine in a F/C
> keeping it at 2000
> these coaches came
> factory manuals
> if they were only
> it would be
> said in those days.
> Jon
> 1978 Wanderlodge
> YAHOO! GROUPS LINKS
> web.
> email to:
> removed]
Do You Yahoo!?
radiators
YAHOO! GROUPS LINKS
03-16-2006, 15:14
Yo, Kerry, you have a rig that's 24 freekin' years old, you want to run that
tired old tank at 100%, be my guest.
You and Jon should talk to Ralph F about the way things are. He could bring
some interesting tidbits to your attention. I have turned wrenches
professionally for 30 years and I can deal with Cat mechanics as equals. Most
of the people in vehicle service in the Milwaukee metro area know who I am.
That said, I have NEVER talked to a competent Cat man who thinks it's OK to run
a 'throwaway' against the governor. You guys who know better have at it. Hope
it don't blow up when you loan it out to some "tourist".
MH
Sent: Thursday, March 16, 2006 8:51 PM
Kerry
82 FC 35
Denver
> Help
> Chris
radiators
YAHOO! GROUPS LINKS
03-16-2006, 15:21
I asked a simple question. I said nothing about how I would run my
vehicle. Do you know why CAT did not put optimal rpm's in their manual?
I don't see what any of this has to do with who drives my vehicles.
Kerry
82 FC 35
Denver
run that tired old tank at 100%, be my guest.
could bring some interesting tidbits to your attention. I have turned
wrenches professionally for 30 years and I can deal with Cat mechanics
as equals. Most of the people in vehicle service in the Milwaukee
metro area know who I am. That said, I have NEVER talked to a
competent Cat man who thinks it's OK to run a 'throwaway' against the
governor. You guys who know better have at it. Hope it don't blow up
> MH
> From: davidkerryedwards
> Kerry
> 82 FC 35
> Denver
03-16-2006, 15:25
Caterpillar had weak valve springs in the early 80'S, we replaced thousands in
truck engines, there were other applications that used the same spring and they
gave no trouble if the engine was not in a truck.
as far as rpms we had 3208's in several applications, med duty trucks, scrapers,
and irragation engines, and excavators. the irragation engines ran at full load
for weeks on end sometimes when their was a drought, in an excavator you fire it
up ,warm it up, move to full throttle and dig holes and ditchs all day. the
medium duty trucksi think in those days the speed limit was 55MPH but not sure.
strrong engine but keep your valves adjusted.
re
-------------- Original message from "Mike Hohnstein" <MHOHNSTEIN@...>:
talking about.
MH
Help
Chris
> MH
> From: Jon
> broken dreams
> Hohnstein"
> I quote; Keep it
> speed".
> with my vehicles of
> any kind.
> occasionally the
> valve failure,
> valves are open at
> can take a set and
> some times stuff
> breaks.
> tension regularly,
> diesels fun?
> > Mike Hohnstein
> > Germantown, WI
> > 83FC35
> removed]
> engine in a F/C
> keeping it at 2000
> these coaches came
> factory manuals
> if they were only
> it would be
> said in those days.
> Jon
> 1978 Wanderlodge
> YAHOO! GROUPS LINKS
> web.
> email to:
> removed]
Do You Yahoo!?
radiators
YAHOO! GROUPS LINKS
YAHOO! GROUPS LINKS
03-16-2006, 15:51
thousands in truck engines, there were other applications that used
the same spring and they gave no trouble if the engine was not in a
truck.
trucks, scrapers, and irragation engines, and excavators. the
irragation engines ran at full load for weeks on end sometimes when
their was a drought, in an excavator you fire it up ,warm it up, move
to full throttle and dig holes and ditchs all day. the medium duty
> re
<MHOHNSTEIN@...>: --------------
who like to talk with out facts or reality to back up their remarks.
I know what I'm talking about.
> MH
> From: Mr Chris Valdes
dreams
> Help
> Chris
> > MH
> > From: Jon
> > broken dreams
> > Hohnstein"
> > I quote; Keep it
> > speed".
> > with my vehicles of
> > any kind.
> > occasionally the
> > valve failure,
> > valves are open at
> > can take a set and
> > some times stuff
> > breaks.
> > tension regularly,
> > diesels fun?
> > > Mike Hohnstein
> > > Germantown, WI
> > > 83FC35
> > removed]
> > engine in a F/C
> > keeping it at 2000
> > these coaches came
> > factory manuals
> > if they were only
> > it would be
> > said in those days.
> > Jon
> > 1978 Wanderlodge
> > OK I said enough about RPM's and speed but it is interesting
just to see what kind of comments I would get about that chart. I
wish I had enough money to put in a new set of gears for the rear end
so I could keep up with today's traffic but cost wise its just not
worth it. And like I said before when I'm out on the road its not
how fast I get there but just the enjoyment of the rig and its being
built like a tank. Wanderlodges forever!!!!!!!!!!!!!!!!!!!!!!
Jon
78 Rebel Bird
> > YAHOO! GROUPS LINKS
> > web.
> > email to:
> > removed]
> Do You Yahoo!?
maintenance
> YAHOO! GROUPS LINKS
of Service.
maintenance
radiators
> YAHOO! GROUPS LINKS
Service.
User(s) browsing this thread: 11 Guest(s)
