getting under your bird
03-22-2006, 11:22
for those that need to or want to get under your bb but have a problem
with the safety of this, try driving over a low area such as a ditch or
a drain in a parking lot. i have one that i use not far from my bus
barn and what i do is drive parallel to the drain with my wheels
straddling the low area. works good for me when needing to look at or
repair something. the ditch or drain is about 18" deep and about 48"
wide,and its clean. dump your air bags and go to work. be careful this
thing will kill you if you are in the wrong place and the air bags
loose air pressure. dump your bags first.
ed and peggy mcstay
35'fc rear bath
"lonesome dove"
lake charles, la.
