Low Water Pressure
08-08-2006, 05:08
Low Water Pressure
Hi,
My water pressure is very low when hooked to park water. When I use the fresh tank water and the pumps the pressure is fine. I think I remember hearing something about the fresh water inlet valve being spring loaded. Does anyone have any experience trouble shooting the valve? By the way, I took the Microphor toilet apart and replaced the seal in the hopper. I think it is a poorly designed air assisted toilet and will replace if I have trouble with it again. Anyone have any experience with any other brand of air assisted other than Microphor? Thanks, Randy Merrill 93 WLWB Ocala, Fl |
08-08-2006, 06:06
Low Water Pressure
As to water pressure, the culprit is the entire
inlet assembly which is a combination pressure reducer/volume limiter and checkvalve. Some of us have reworked/replaced the entire assembly with a commercial 3/4" brass adjustable pressure regulator, a 3/4" checkvalve, and the necessary fittings to couple to the existing hose as the hose is not the problem we originally thought. That also requires a new metal plate to fill the original opening and to provide the structure to hold the 3/4" female hose connector. Total package cost approached $100 but was well worth it to achieve volume from the shore water similar to that you experience at home. While we were at it, some added a pressure meter. One caveat - care has to be exercised in the winter months as the volume of hot water can easily exceed the capacity of the Aqua-Hot. Of course, that depends upon the difference between the inlet water temp and your shower temp preferences. John Suter --- Randy Merrill > Hi, > > My water pressure is very low when hooked to park > water. When I use the > fresh tank water and the pumps the pressure is fine. > I think I remember > hearing something about the fresh water inlet valve > being spring > loaded. Does anyone have any experience trouble > shooting the valve? > > By the way, I took the Microphor toilet apart and > replaced the seal in > the hopper. I think it is a poorly designed air > assisted toilet and > will replace if I have trouble with it again. Anyone > have any > experience with any other brand of air assisted > other than Microphor? > > Thanks, > > Randy Merrill > 93 WLWB > Ocala, Fl > > > > > __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com |
08-08-2006, 06:50
Low Water Pressure
I know Randy Dupree removed his air assisted Microphor and just replaced it
with a regular gravity model. Yes his plumbing did have to go laterally for a short distance but he reasoned it had sufficient slope and the distance was not so great that the toilet contents wouldn't make it to waste tank. Turns out he was right and he didn't need an air assisted system after all. Of course your situation may be different so I would ask him for specifics. His bird is a 1993 Side Aisle. On 08/08/06, Randy Merrill > > Hi, > > My water pressure is very low when hooked to park water. When I use the > fresh tank water and the pumps the pressure is fine. I think I remember > hearing something about the fresh water inlet valve being spring > loaded. Does anyone have any experience trouble shooting the valve? > > By the way, I took the Microphor toilet apart and replaced the seal in > the hopper. I think it is a poorly designed air assisted toilet and > will replace if I have trouble with it again. Anyone have any > experience with any other brand of air assisted other than Microphor? > > Thanks, > > Randy Merrill > 93 WLWB > Ocala, Fl > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] |
08-08-2006, 07:12
Low Water Pressure
As John said, the problem can be fixed with a change of regulator
and inlet connection. Here is a link to the photos of my change. http://photosleeve.com/gallery2/v/Gman/Regulator_Fix/ Click on the individual pictures for larger views. As far as the AquaHot is concerned, there is a tempering valve on the AquaHot that can be adjusted if needed. By turning down the amount of cold mixed with the hot, the water will maintain a proper temperature. Rich D. '99LXi43' CT --- In WanderlodgeForum@yahoogroups.com, John Suter wrote: > > As to water pressure, the culprit is the entire > inlet assembly which is a combination pressure > reducer/volume limiter and checkvalve. > > Some of us have reworked/replaced the entire > assembly with a commercial 3/4" brass adjustable > pressure regulator, a 3/4" checkvalve, and the > necessary fittings to couple to the existing hose as > the hose is not the problem we originally thought. > That also requires a new metal plate to fill the > original opening and to provide the structure to hold > the 3/4" female hose connector. Total package cost > approached $100 but was well worth it to achieve > volume from the shore water similar to that you > experience at home. While we were at it, some added a > pressure meter. One caveat - care has to be exercised > in the winter months as the volume of hot water can > easily exceed the capacity of the Aqua-Hot. Of > course, that depends upon the difference between the > inlet water temp and your shower temp preferences. > > John Suter > > > > > --- Randy Merrill > > > Hi, > > > > My water pressure is very low when hooked to park > > water. When I use the > > fresh tank water and the pumps the pressure is fine. > > I think I remember > > hearing something about the fresh water inlet valve > > being spring > > loaded. Does anyone have any experience trouble > > shooting the valve? > > > > By the way, I took the Microphor toilet apart and > > replaced the seal in > > the hopper. I think it is a poorly designed air > > assisted toilet and > > will replace if I have trouble with it again. Anyone > > have any > > experience with any other brand of air assisted > > other than Microphor? > > > > Thanks, > > > > Randy Merrill > > 93 WLWB > > Ocala, Fl > > > > > > > > > > > > > __________________________________________________ > Do You Yahoo!? > Tired of spam? Yahoo! Mail has the best spam protection around > http://mail.yahoo.com > |
08-08-2006, 07:31
Low Water Pressure
I always use my water pump and refill the tank when needed. This way, if I go
someplace all I have to do is turn off the pump. Ernie Ekberg 83 PT40 Livingston, Montana [Non-text portions of this message have been removed] |
08-08-2006, 09:30
Low Water Pressure
If the pump pressure is adequate, why not simply use the tank water and refill
as needed. I don't generally like to have a full tank when traveling and this method keeps the water in the tank fresh. Dick Hayden - '87 PT 38 - Lake Stevens, WA ----- Original Message ----- From: John Suter To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, August 08, 2006 11:06 AM Subject: Re: [WanderlodgeForum] Low Water Pressure As to water pressure, the culprit is the entire inlet assembly which is a combination pressure reducer/volume limiter and checkvalve. Some of us have reworked/replaced the entire assembly with a commercial 3/4" brass adjustable pressure regulator, a 3/4" checkvalve, and the necessary fittings to couple to the existing hose as the hose is not the problem we originally thought. That also requires a new metal plate to fill the original opening and to provide the structure to hold the 3/4" female hose connector. Total package cost approached $100 but was well worth it to achieve volume from the shore water similar to that you experience at home. While we were at it, some added a pressure meter. One caveat - care has to be exercised in the winter months as the volume of hot water can easily exceed the capacity of the Aqua-Hot. Of course, that depends upon the difference between the inlet water temp and your shower temp preferences. John Suter --- Randy Merrill > Hi, > > My water pressure is very low when hooked to park > water. When I use the > fresh tank water and the pumps the pressure is fine. > I think I remember > hearing something about the fresh water inlet valve > being spring > loaded. Does anyone have any experience trouble > shooting the valve? > > By the way, I took the Microphor toilet apart and > replaced the seal in > the hopper. I think it is a poorly designed air > assisted toilet and > will replace if I have trouble with it again. Anyone > have any > experience with any other brand of air assisted > other than Microphor? > > Thanks, > > Randy Merrill > 93 WLWB > Ocala, Fl > > > > > __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com<http://mail.yahoo.com/> [Non-text portions of this message have been removed] |
08-08-2006, 09:33
Low Water Pressure
--- In WanderlodgeForum@yahoogroups.com, "g_man1146"
> > As John said, the problem can be fixed with a change of regulator > and inlet connection. > Here is a link to the photos of my change. Rich, Among your many skills, I can see you should have been a plumber instead of an electrician, LOL. I, too, have low pressure and removed the inlet valve and do not have a pressure regulator or strainer , just a check valve. I have been told that it is probably the sporlan valve that needs cleaning. Don't know where your sporlan valve is located, but mine appears (appears because I can't see it, but can hear it when switched) to be buried areound the pumps in an impossible area to reach without removing half the plumbing and charcoal filter. Paul 97wb43 |
08-08-2006, 14:23
Low Water Pressure
And you don't have to worry about them camp grounds with big water pressure
popping a water line. MH ----- Original Message ----- From: erniecarpet@... To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, August 08, 2006 6:31 PM Subject: Re: [WanderlodgeForum] Low Water Pressure I always use my water pump and refill the tank when needed. This way, if I go someplace all I have to do is turn off the pump. Ernie Ekberg 83 PT40 Livingston, Montana [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
08-08-2006, 14:50
Low Water Pressure
Hi Paul,
In my case the culprit was the regulator/fill valve. The flow increased dramatically with the new setup. The tank fills in about 1/2 the time too. My Sporlan valve is next to the filters in #2 roadside bay, behind the pumps, probably the same as yours. I haven't had to get at it yet so I don't know how much trouble it is. I'm waiting for you to do it then tell me how! Rich D. '99LXi43' CT --- In WanderlodgeForum@yahoogroups.com, "p_a_lazar" wrote: > > --- In WanderlodgeForum@yahoogroups.com, "g_man1146" wrote: > > > > As John said, the problem can be fixed with a change of regulator > > and inlet connection. > > Here is a link to the photos of my change. > > Rich, > > Among your many skills, I can see you should have been a plumber > instead of an electrician, LOL. > > I, too, have low pressure and removed the inlet valve and do not have > a pressure regulator or strainer , just a check valve. I have been > told that it is probably the sporlan valve that needs cleaning. Don't > know where your sporlan valve is located, but mine appears (appears > because I can't see it, but can hear it when switched) to be buried > areound the pumps in an impossible area to reach without removing half > the plumbing and charcoal filter. > > Paul > 97wb43 > |
10-25-2010, 10:38
Low Water Pressure
I haven't taken the bus out since Labor Day, but had occasion to be in it over
the weekend. When I used the water, the water pump ran continuously and the water pressure was low at all faucets. Soooo, I assume the wonderful Sporlan valve has struck once again and is stuck. Anyone agree or disagree? Thanks, Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX |
