Radio Antennas
08-08-2006, 05:17
Radio Antennas
Hi Again,
I need to replace the two AM-FM radio antennas and the two CB antennas on the coach. They are all NMO style mounts. I have searched the web and they are hard to find. Anyone know where they can be found? I have searched CB shops, truck shops, NAPA, Radio Shack, etc. Has anyone used another type of mount instead of the NMO style? If so, how did you retrofit? Thanks, Randy Merrill 93 WLWB Ocala, FL |
08-08-2006, 09:25
Radio Antennas
I used a trunk mount attached to an alum. angle which I attached to the front of
the "goat rail". That was on a cel antenna but the principle would be the same on others. I think that the trunk mount might be a NMO style only with the addition of the trunk mounting piece underneath and held in place with 2 screws from under the underside. Maybe not. But, you could drill the alum. angle and put the NMO mount through that. Dick Hayden - '87 PT 38 - Lake Stevens, WA ----- Original Message ----- From: Randy Merrill To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, August 08, 2006 10:17 AM Subject: [WanderlodgeForum] Radio Antennas Hi Again, I need to replace the two AM-FM radio antennas and the two CB antennas on the coach. They are all NMO style mounts. I have searched the web and they are hard to find. Anyone know where they can be found? I have searched CB shops, truck shops, NAPA, Radio Shack, etc. Has anyone used another type of mount instead of the NMO style? If so, how did you retrofit? Thanks, Randy Merrill 93 WLWB Ocala, FL [Non-text portions of this message have been removed] |
08-08-2006, 12:30
Radio Antennas
Randy:
Give these people a call. Their antennas all have the loading coil at the base of the antenna and the stainless steel rod is very flexible and take kindly to being laid back with a tree limb. I have used their amateur radio antennas for years and have never had one fail. I am sure they can help you with both the AM/FM and CB antennas. Marv 2004 M380 Ocean Shores, WA --- In WanderlodgeForum@yahoogroups.com, "Randy Merrill" > > Hi Again, > > I need to replace the two AM-FM radio antennas and the two CB antennas > on the coach. They are all NMO style mounts. I have searched the web > and they are hard to find. Anyone know where they can be found? I have > searched CB shops, truck shops, NAPA, Radio Shack, etc. Has anyone > used another type of mount instead of the NMO style? If so, how did you > retrofit? > > Thanks, > > Randy Merrill > 93 WLWB > Ocala, FL > |
08-08-2006, 12:37
Radio Antennas
Marv was there a link that I missed??
On 08/08/06, Marv & Jean > > Randy: > > Give these people a call. Their antennas all have the loading coil > at the base of the antenna and the stainless steel rod is very > flexible and take kindly to being laid back with a tree limb. > > I have used their amateur radio antennas for years and have never had > one fail. > > I am sure they can help you with both the AM/FM and CB antennas. > > Marv > 2004 M380 > Ocean Shores, WA > > --- In WanderlodgeForum@yahoogroups.com > "Randy Merrill" > > > > > > Hi Again, > > > > I need to replace the two AM-FM radio antennas and the two CB > antennas > > on the coach. They are all NMO style mounts. I have searched the > web > > and they are hard to find. Anyone know where they can be found? I > have > > searched CB shops, truck shops, NAPA, Radio Shack, etc. Has anyone > > used another type of mount instead of the NMO style? If so, how did > you > > retrofit? > > > > Thanks, > > > > Randy Merrill > > 93 WLWB > > Ocala, FL > > > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] |
08-08-2006, 15:18
Radio Antennas
My local CB shop set me up when I needed some, he told me that the
mount is common with "business-band" radios. The CB Shop, in Holland, MI, located in the Tulip City Truck Stop lot FYI. - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, "Marv & Jean" > > Randy: > > Give these people a call. Their antennas all have the loading coil > at the base of the antenna and the stainless steel rod is very > flexible and take kindly to being laid back with a tree limb. > > I have used their amateur radio antennas for years and have never had > one fail. > > I am sure they can help you with both the AM/FM and CB antennas. > > Marv > 2004 M380 > Ocean Shores, WA > > > --- In WanderlodgeForum@yahoogroups.com, "Randy Merrill" > > > > > Hi Again, > > > > I need to replace the two AM-FM radio antennas and the two CB > antennas > > on the coach. They are all NMO style mounts. I have searched the > web > > and they are hard to find. Anyone know where they can be found? I > have > > searched CB shops, truck shops, NAPA, Radio Shack, etc. Has anyone > > used another type of mount instead of the NMO style? If so, how did > you > > retrofit? > > > > Thanks, > > > > Randy Merrill > > 93 WLWB > > Ocala, FL > > > |
08-08-2006, 15:53
Radio Antennas
Jeff after next summers OSKOSH gathering is there a chance I stop by your
shop? On 08/08/06, Jeff Miller > > My local CB shop set me up when I needed some, he told me that the > mount is common with "business-band" radios. > > The CB Shop, in Holland, MI, located in the Tulip City Truck Stop lot > FYI. > > - Jeff Miller > in Holland, MI > > --- In WanderlodgeForum@yahoogroups.com > "Marv & Jean" > > > > > > Randy: > > > > Give these people a call. Their antennas all have the loading coil > > at the base of the antenna and the stainless steel rod is very > > flexible and take kindly to being laid back with a tree limb. > > > > I have used their amateur radio antennas for years and have never > had > > one fail. > > > > I am sure they can help you with both the AM/FM and CB antennas. > > > > Marv > > 2004 M380 > > Ocean Shores, WA > > > > > > --- In WanderlodgeForum@yahoogroups.com > "Randy Merrill" > > > > > > > > Hi Again, > > > > > > I need to replace the two AM-FM radio antennas and the two CB > > antennas > > > on the coach. They are all NMO style mounts. I have searched the > > web > > > and they are hard to find. Anyone know where they can be found? I > > have > > > searched CB shops, truck shops, NAPA, Radio Shack, etc. Has > anyone > > > used another type of mount instead of the NMO style? If so, how > did > > you > > > retrofit? > > > > > > Thanks, > > > > > > Randy Merrill > > > 93 WLWB > > > Ocala, FL > > > > > > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] |
08-09-2006, 02:26
Radio Antennas
Randy:
There should have been a link but I omitted it. http://www.radialllarsen.com That should do the trick. Sorry but I must have had a "senior moment" Marv 2004 M380 Ocean Shores, WA --- In WanderlodgeForum@yahoogroups.com, "Rob Robinson" > > Marv was there a link that I missed?? > > On 08/08/06, Marv & Jean > > > > Randy: > > > > Give these people a call. Their antennas all have the loading coil > > at the base of the antenna and the stainless steel rod is very > > flexible and take kindly to being laid back with a tree limb. > > > > I have used their amateur radio antennas for years and have never had > > one fail. > > > > I am sure they can help you with both the AM/FM and CB antennas. > > > > Marv > > 2004 M380 > > Ocean Shores, WA > > > > --- In WanderlodgeForum@yahoogroups.com > > "Randy Merrill" > > > > > > > > > > Hi Again, > > > > > > I need to replace the two AM-FM radio antennas and the two CB > > antennas > > > on the coach. They are all NMO style mounts. I have searched the > > web > > > and they are hard to find. Anyone know where they can be found? I > > have > > > searched CB shops, truck shops, NAPA, Radio Shack, etc. Has anyone > > > used another type of mount instead of the NMO style? If so, how did > > you > > > retrofit? > > > > > > Thanks, > > > > > > Randy Merrill > > > 93 WLWB > > > Ocala, FL > > > > > > > > > > > > > -- > Rob, Sue & Merlin Robinson > 94 WLWB > > > [Non-text portions of this message have been removed] > |
