Window Vistas Rope Lighting
02-23-2014, 23:47
I have several blown bulbs in the rope lighting around my windows. Is it possible to replace the blown bulbs or does the entire rope have to be replaced?
02-24-2014, 12:06
RE: Window Vistas Rope Lighting
Chuck,
While I don't see why it wouldn't be possible to change just a bulb, I've never run across any discussions about doing so. Everybody has just replaced the entire rope. Not that this adds much info to solving your question. John Mace 06 450LXi bigger bird living in the wild hinterlands of the north free to roam without the man getting me down |
02-24-2014, 12:32
If you have to replace them look at the led rope lights. They're available in 12 volt and 120 volt/AC.
Just do a quick search and they can be found at the big box stores and Amazon, etc. Forest & Cindy Olivier 1998 Newell 45' double slide 2004 Z71 toad with Rzr 570LE |
02-25-2014, 23:24
I've wondered if running the rope lights at a lower voltage would extend the life? I know LEDs have trouble with some of the higher battery voltages seen in our Birds. Anybody replaced rope lights yet, I don't remember any posts on this. How about using some of the LEDs that can be programed for color changes?
Morey Zuber 99LXi41 |
03-04-2014, 01:21
Great Tip Rich , thank s for the Info
03-04-2014, 14:39
(03-02-2014 12:11)Bird Owner Wrote:(02-23-2014 23:47)cmillsap Wrote: I have several blown bulbs in the rope lighting around my windows. Is it possible to replace the blown bulbs or does the entire rope have to be replaced? Thanks, Rich, Chuck Chuck & Tela Millsap 2003 Prevost Marathon XLII 2000 LXi #2 S/S (Sold) 2004 M380 D/S (Sold) 2000 LXi #1 N/S (Sold |
03-04-2014, 22:20
If some bulbs have died, it is likely the rest are not far behind. I'd replace the whole string.
Ron & Dorinda Rueckwald 2000 LXi, Single Slide Summer in St. Joseph, MI Winter in St. Petersburg, FL |
