Pac brake
07-12-2005, 15:05
Pac brake
I can't seem to find what a "Pac brake" is; it in an ad for BMC
with no further explination. Help ? Wallace Craig 85WLPT40 Azle, Tx |
07-13-2005, 01:39
Pac brake
I've always been under the impression that a "Jake Brake" was
associated with engine valve timing. A "pac" brake was associated with restricted exhust flow. Bob 93pt-Illinois |
07-13-2005, 01:48
Pac brake
Yep, that's correct.
Mike Hohnstein ----- Original Message ----- From: Bob & Carol Howald` To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, July 13, 2005 8:39 AM Subject: [WanderlodgeForum] Re: Pac brake I've always been under the impression that a "Jake Brake" was associated with engine valve timing. A "pac" brake was associated with restricted exhust flow. Bob 93pt-Illinois ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] |
07-13-2005, 03:23
Pac brake
Hi Wallace,
I see you have got several other answers from those who have not actually worked on the various auxiliary braking systems. The Pac Brake, <http://www.pacbrake.com>, is made by a privately owned company in the northwest. I believe it is homebased in Canada. The Pac Brake is primarily an exhaust brake consisting of a butterfly valve that is placed in the exhaust. When activated, the exhaust back pressure acts as a braking device. It is very effective and, more important these days, Quiet... Someone else likened it to the Jake Brake. Only in that it provides auxiliary braking. The Jacobs Company developed the Engine Brake, which is commonly called the Jake Brake. It is more complex and operates by activating the exhaust valve of the engine to release the stored energy from the compression stroke. It is also very noisy - makes the BRAACC noise you hear on trucks etc. Now that he patents have run out, there are several companies that make both the Engine brake and the exhaust brake. Each are referred to by their original developers names, hence the Pac Brake and the Jake Brake. FWIW, there are other auxiliary braking systems such as the transmission retarder and the Telma retarder which is a magnetically operated system. I have used both the Jake engine Brake, commonly used on Detroit engines and the Pac Brake. I had that on the GM bus conversion on a Cummins 903 engine. I was going to use the engine brake but the installation did not have enough room for the extended valve covers. After using the Pac Brake, I found that we actually preferred it because it was not restricted from use like the noisier Jake. Hope this helps, George Lowry '95 WBDA 4203 Spearfish, SD Wallace Craig wrote: > I can't seem to find what a "Pac brake" is; it in an ad for BMC > with no further explination. Help ? > Wallace Craig > 85WLPT40 > Azle, Tx > > > > > > > > Yahoo! Groups Links > > > > > > > > > |
07-13-2005, 10:09
Pac brake
George, many thanks for your thorough reply and the fact that use have used and
like the Pac brake, I am considering a BMC that has a Pac on it. Thanks again. Wallace George Lowry I see you have got several other answers from those who have not actually worked on the various auxiliary braking systems. The Pac Brake, <http://www.pacbrake.com>, is made by a privately owned company in the northwest. I believe it is homebased in Canada. The Pac Brake is primarily an exhaust brake consisting of a butterfly valve that is placed in the exhaust. When activated, the exhaust back pressure acts as a braking device. It is very effective and, more important these days, Quiet... Someone else likened it to the Jake Brake. Only in that it provides auxiliary braking. The Jacobs Company developed the Engine Brake, which is commonly called the Jake Brake. It is more complex and operates by activating the exhaust valve of the engine to release the stored energy from the compression stroke. It is also very noisy - makes the BRAACC noise you hear on trucks etc. Now that he patents have run out, there are several companies that make both the Engine brake and the exhaust brake. Each are referred to by their original developers names, hence the Pac Brake and the Jake Brake. FWIW, there are other auxiliary braking systems such as the transmission retarder and the Telma retarder which is a magnetically operated system. I have used both the Jake engine Brake, commonly used on Detroit engines and the Pac Brake. I had that on the GM bus conversion on a Cummins 903 engine. I was going to use the engine brake but the installation did not have enough room for the extended valve covers. After using the Pac Brake, I found that we actually preferred it because it was not restricted from use like the noisier Jake. Hope this helps, George Lowry '95 WBDA 4203 Spearfish, SD Wallace Craig wrote: > I can't seem to find what a "Pac brake" is; it in an ad for BMC > with no further explination. Help ? > Wallace Craig > 85WLPT40 > Azle, Tx > > > > > > > > Yahoo! Groups Links > > > > > > > > > SPONSORED LINKS Recreational vehicles Automotive maintenance Recreational vehicle dealer Used recreational vehicles Automotive radiators --------------------------------- YAHOO! GROUPS LINKS Visit your group "WanderlodgeForum" on the web. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. --------------------------------- __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com [Non-text portions of this message have been removed] |
07-13-2005, 11:30
Pac brake
--- In WanderlodgeForum@yahoogroups.com, "Wallace Craig"
> I can't seem to find what a "Pac brake" is; it in an ad for BMC > with no further explination. Help ? > Wallace Craig > 85WLPT40 > Azle, Tx George had the best answer, they are located in Canada, one additional note, the Pac brake turns your engine into a compressor, so the more RPM's the more braking. I have a 95 BMC and know the system well, as I had to fix the one on my coach. |
07-13-2005, 14:21
Pac brake
You said you had to fix the Pac brake; is this as a result of some fundemental
flaw with the Pac of just wear and tear?? Do you generally recommend the Pac brake? Wallace Craig martingregg598 WanderlodgeForum@yahoogroups.com, "Wallace Craig" > I can't seem to find what a "Pac brake" is; it in an ad for BMC > with no further explination. Help ? > Wallace Craig > 85WLPT40 > Azle, Tx George had the best answer, they are located in Canada, one additional note, the Pac brake turns your engine into a compressor, so the more RPM's the more braking. I have a 95 BMC and know the system well, as I had to fix the one on my coach. --------------------------------- YAHOO! GROUPS LINKS Visit your group "WanderlodgeForum" on the web. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. --------------------------------- --------------------------------- Start your day with Yahoo! - make it your home page [Non-text portions of this message have been removed] |
07-13-2005, 14:54
Pac brake
George: I have to admit that I have never had to do much maintance
on the Pac-Brake in my Dodge Diesel truck. or did I have to do any maintance or work on my Jake-Brake in the motorhome but, I do understand the system's very well. I was only trying to give Harold a little room to recover from his earlier statement.To jump to the conclusion that one has to actually work on the system to understand it is not always correct. Bob 93pt. Illinois |
07-14-2005, 04:50
Pac brake
> > > When I got the coach the Pac brake did not function, the throttle stop switch linkage had disappeared and the switch was frozen up. A little work on the switch and a little linkage fab and it worked fine. This was only after a lot of research to find out how the system was manufactured and how it works, A tech at Pac Brake, Mike at Spartan, Benny at Blue Bird were all great. > > --------------------------------- > YAHOO! GROUPS LINKS > > > Visit your group "WanderlodgeForum" on the web. > > To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > --------------------------------- > > > > > > --------------------------------- > Start your day with Yahoo! - make it your home page > > [Non-text portions of this message have been removed] |
06-22-2007, 13:29
Pac brake
Call Cat with engine and arrangement number. It is important to have the
right lifters, and some other things that I can't recall at the moment. Been a long time since I had a 3208!! Max Lurker and pondering But would sure miss my CAT C12 HP and torque. ************************************** See what's free at http://www.aol.com. [Non-text portions of this message have been removed] |
