LXi 2002 Entry Door Window
09-22-2015, 14:13
Recently my entry door double pane window was removed to repair glass (was fogged). On re-installation the window frame was set in place "dry". This and the driver's window are the only windows that have a rubber gasket between the window frame and the door (or bus body), on all others the window frame is set tight to the bus body.
In places there are small visible gaps between the gasket edge and the door for potential leaks in my opinion to develop. There is evidence someone previously ran a partial bead around gasket without removing window. Would I not be wise to remove window and run a bead of caulk around opening to set and positively seal between gasket and door body? Was window originally installed "dry" by BB using only rubber gasket? If answer is YES recommendation on brand and type of chalk would be appreciated. Dean Dean M. Bertrand Cape Coral, FL 2002 LXi 43 SS dmbertrand@embarqmail.com |
09-22-2015, 17:17
(This post was last modified: 09-22-2015 17:18 by davidbrady.)
RE: LXi 2002 Entry Door Window
Dean,
I would call Hehr to get their opinion. They have service manuals on their website which might be of use: http://www.hehrintl.com/servicemanuals.htm. The window should be installed using a bedding compound, probably a urethane but I'd check with Hehr. For a sealant around the window I'd also use a window adhesive urethane which should be available at Carquest, Napa, or any of the other automotive chains. Prevost glues all their windows in using urethane. Here are the glazing numbers for the LXi windows: The driver's window is Hehr drawing number: 0 470 304 320 3535 2051 0305. The passenger's is: 0 384252 000 0 3535 2051 0505. david brady, '02 Wanderlodge LXi 'Smokey' (Sold), '04 Prevost H3 Vantare 'SpongeBob' "I don't like being wrong, but I really hate being right" |
09-22-2015, 19:05
David
Thank you. Dean Dean M. Bertrand Cape Coral, FL 2002 LXi 43 SS dmbertrand@embarqmail.com |
09-25-2015, 12:46
the door is aluminum skinned and slammed shut. this may need consideration or had consideration when fit
