Where to dispose of antifreeze?
07-26-2005, 16:17
A lot of discussion going on about draining/refilling cooling
systems. But where do you dispose of the old antifreeze? Called Autozone and few other places and they said they don't take it. The landfill here is the only place that takes it and it costs a small fortune to dump it there. I want to say it was around $2 a gallon! This can be pretty pricey when we're talking about system with 60+ qt capacity. Suggestions? I want it to be as safe as possible. Also, could someone briefly go over the correct way to drain and refill a system properly while avoiding air bubbles or other problems? My system has some bad corrosion and I'd love to flush, but I'm afraid of not doing it correctly and possibly damaging something. And of course I have STILL yet to find a manual detailing on how it should be done on these shuttle buses. thanks, Steve 2 '98 BB QBRE Partybuses |
07-26-2005, 16:29
Steve dont know where you live but here in my locality talked to the waste
storage plant and they advised its alright to flush it down the toilet. About the corrosion problem. Where exactly is it? If the actual cooling system is that bad then repair everything first before doing the coolant exchange. The cooling system in my opinion is the most important part of preventative maintenance. Over 60% of the problems for engines are caused by malfunctioning cooling systems. Its the first thing I tore apart and refurbished starting with the radiator and water pump. tom 1982 Fc35 Vernon Center,NY At 04:17 AM 7/27/2005 +0000, you wrote: > A lot of discussion going on about draining/refilling cooling >systems. But where do you dispose of the old antifreeze? Called >Autozone and few other places and they said they don't take it. > The landfill here is the only place that takes it and it costs a >small fortune to dump it there. I want to say it was around $2 a >gallon! This can be pretty pricey when we're talking about system with >60+ qt capacity. Suggestions? I want it to be as safe as possible. > Also, could someone briefly go over the correct way to drain and >refill a system properly while avoiding air bubbles or other problems? >My system has some bad corrosion and I'd love to flush, but I'm afraid >of not doing it correctly and possibly damaging something. And of >course I have STILL yet to find a manual detailing on how it should be >done on these shuttle buses. > >thanks, > >Steve >2 '98 BB QBRE Partybuses > > > > > >---------- >YAHOO! GROUPS LINKS > > * Visit your group > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. > * > * To unsubscribe from this group, send an email to: > * > odgeForum-unsubscribe@yahoogroups.com > > * > * Your use of Yahoo! Groups is subject to the > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > >---------- |
07-26-2005, 18:40
--- In WanderlodgeForum@yahoogroups.com, "transit360"
> A lot of discussion going on about draining/refilling cooling > systems. But where do you dispose of the old antifreeze? Called > Autozone and few other places and they said they don't take it. > The landfill here is the only place that takes it and it costs a > small fortune to dump it there. I want to say it was around $2 a > gallon! This can be pretty pricey when we're talking about system with > 60+ qt capacity. Suggestions? I want it to be as safe as possible. > Also, could someone briefly go over the correct way to drain and > refill a system properly while avoiding air bubbles or other problems? > My system has some bad corrosion and I'd love to flush, but I'm afraid > of not doing it correctly and possibly damaging something. And of > course I have STILL yet to find a manual detailing on how it should be > done on these shuttle buses. > > thanks, > > Steve > 2 '98 BB QBRE Partybuses |
07-26-2005, 21:54
Steve,
Call your local health dept. and ask them about used coolant. Here in Lincoln, they're fine with us putting it down the drain as long as we put 5 gallons of water with every gallon of coolant. I have mine collected and recycled. You might find the cleanest, brightest, nicest looking auto shop in the area and ask them what they do with theirs. If they recycle, they might take yours for less than the landfill will. Landfill is a bad idea for the environment. George Witt 81 FC 35 Lincoln, Nebraska *Owner of the only auto repair shop in Lincoln that's ever won an Environmental Award from the Health Dept. --- In WanderlodgeForum@yahoogroups.com, "transit360" > A lot of discussion going on about draining/refilling cooling > systems. But where do you dispose of the old antifreeze? Called > Autozone and few other places and they said they don't take it. > The landfill here is the only place that takes it and it costs a > small fortune to dump it there. I want to say it was around $2 a > gallon! This can be pretty pricey when we're talking about system with > 60+ qt capacity. Suggestions? I want it to be as safe as possible. > Also, could someone briefly go over the correct way to drain and > refill a system properly while avoiding air bubbles or other problems? > My system has some bad corrosion and I'd love to flush, but I'm afraid > of not doing it correctly and possibly damaging something. And of > course I have STILL yet to find a manual detailing on how it should be > done on these shuttle buses. > > thanks, > > Steve > 2 '98 BB QBRE Partybuses |
07-27-2005, 02:14
When I drained the coolant out it looked a little brackish, not bright
green. When I took the thermostat housing off along with the upper radiator hoses, I noticed rust collecting on the inside of the pipes. That's where I've found it so far. Steve Tom Warner Steve dont know where you live but here in my locality talked to the waste storage plant and they advised its alright to flush it down the toilet. About the corrosion problem. Where exactly is it? If the actual cooling system is that bad then repair everything first before doing the coolant exchange. The cooling system in my opinion is the most important part of preventative maintenance. Over 60% of the problems for engines are caused by malfunctioning cooling systems. Its the first thing I tore apart and refurbished starting with the radiator and water pump. tom 1982 Fc35 Vernon Center,NY At 04:17 AM 7/27/2005 +0000, you wrote: > A lot of discussion going on about draining/refilling cooling >systems. But where do you dispose of the old antifreeze? Called >Autozone and few other places and they said they don't take it. > The landfill here is the only place that takes it and it costs a >small fortune to dump it there. I want to say it was around $2 a >gallon! This can be pretty pricey when we're talking about system with >60+ qt capacity. Suggestions? I want it to be as safe as possible. > Also, could someone briefly go over the correct way to drain and >refill a system properly while avoiding air bubbles or other problems? >My system has some bad corrosion and I'd love to flush, but I'm afraid >of not doing it correctly and possibly damaging something. And of >course I have STILL yet to find a manual detailing on how it should be >done on these shuttle buses. > >thanks, > >Steve >2 '98 BB QBRE Partybuses > > > > > >---------- >YAHOO! GROUPS LINKS > > * Visit your group > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. > * > * To unsubscribe from this group, send an email to: > * > odgeForum-unsubscribe@yahoogroups.com > > * > * Your use of Yahoo! Groups is subject to the > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > >---------- --------------------------------- YAHOO! GROUPS LINKS Visit your group "WanderlodgeForum" on the web. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. --------------------------------- Steve Wicker http://www.360partybus.com 828-236-2841/301-0245 --------------------------------- Yahoo! Mail Stay connected, organized, and protected. Take the tour [Non-text portions of this message have been removed] |
