89wb- all the wires are cut leading to lp sniffer and alarm
07-27-2005, 12:16
New member needs help on reconnecting wires in drawer under frig
leading to lp sniffer and alarm. I just purchased the 89 wb a few weeks ago.I just found this drawer under the frig last weekend and would like to reconnect the wires.The wires(3) are red yellow and black. There is also no wires running to the alarm. is this the lp alarm? Where is the frig temp alarm? Also the lp cutoff solinoid was just hanging beside the tank, not connected to anything. I took the cutoff apart and cleaned it, and now it should work, hopefully. Iinstalled it back into the lp linewhere it should be. please help on the wires to the sniffer and alarm, as we are leaving on our second trip in our new bird... thanks for your help Ed 89wb |
07-30-2005, 00:27
Ed:
Do you still need the wiring for the shut off valve? Safe travels, Ralph and Charolette Fullenwider Ralph's RV Solutions,, Oklahoma At 12:16 AM 7/28/2005 +0000, you wrote: >New member needs help on reconnecting wires in drawer under frig >leading to lp sniffer and alarm. I just purchased the 89 wb a few >weeks >ago.I just found this drawer under the frig last weekend and would >like >to reconnect the wires.The wires(3) are red yellow and black. There >is >also no wires running to the alarm. is this the lp alarm? Where is >the >frig temp alarm? Also the lp cutoff solinoid was just hanging beside >the tank, not connected to anything. I took the cutoff apart and >cleaned it, and now it should work, hopefully. Iinstalled it back >into >the lp linewhere it should be. please help on the wires to the >sniffer >and alarm, as we are leaving on our second trip in our new bird... > thanks for your help > Ed 89wb > > |
08-02-2005, 03:38
ED,
Sorry for the late answer. If you still need help, I can identify these wires, There is 12 volts at the detector, but only 4 to 8 volts at the valve to keep it open. On our Bird this is wired to the electronic master, So it must be in the on position. Bill 88 FC --- In WanderlodgeForum@yahoogroups.com, "sonisaki" wrote: > New member needs help on reconnecting wires in drawer under frig > leading to lp sniffer and alarm. I just purchased the 89 wb a few > weeks > ago.I just found this drawer under the frig last weekend and would > like > to reconnect the wires.The wires(3) are red yellow and black. There > is > also no wires running to the alarm. is this the lp alarm? Where is > the > frig temp alarm? Also the lp cutoff solinoid was just hanging beside > the tank, not connected to anything. I took the cutoff apart and > cleaned it, and now it should work, hopefully. Iinstalled it back > into > the lp linewhere it should be. please help on the wires to the > sniffer > and alarm, as we are leaving on our second trip in our new bird... > thanks for your help > Ed 89wb |
