Battery Chargers
07-30-2005, 03:42
Battery Chargers
I have a a 87 PT-40 with two Statpower 40 amp chargers that have quit working.
Any recommendations for replacements? Pete Amerson 87 PT-40 Pensacola FL [Non-text portions of this message have been removed] |
07-30-2005, 05:19
Battery Chargers
Iwould have a look at having them rebuilt at statpower not a dealer
but at the company it can be fairly reasonable Stephen 77fc35 -- In WanderlodgeForum@yahoogroups.com, "Pete Amerson Jr" > I have a a 87 PT-40 with two Statpower 40 amp chargers that have quit working. Any recommendations for replacements? > > Pete Amerson > 87 PT-40 > Pensacola FL > > [Non-text portions of this message have been removed] |
07-30-2005, 14:29
Battery Chargers
They are a touch pricy, but I am a fan of the True Charge smart
chargers at: http://www.xantrex.com/web/id/3/type.asp http://www.vitelectronics.com/statpower.html is where I bought mine, along with the remote display panel. Dan --- In WanderlodgeForum@yahoogroups.com, "Pete Amerson Jr" > I have a a 87 PT-40 with two Statpower 40 amp chargers that have quit working. Any recommendations for replacements? > > Pete Amerson > 87 PT-40 > Pensacola FL > > [Non-text portions of this message have been removed] |
07-31-2005, 11:49
Battery Chargers
Pete,
I'm not sure of the brand/rating of the chargers that I removed from our 1987 PT38. I know they cooked the batteries. Kevin McKeown of this forum suggested the Progressive chargers to me. I installed two Progressive Dynamics with the Charge Wizards. I ordered the PD9155R. Progressive was out of stock so they sent the PD9160AR, no extra cost to me. These are the factory serviced power converters. They cost less than the new units and have a one year replacement guarantee. My batteries are happy with these chargers. Check their site. http://www.progressivedyn.com . Click on the Sales Dept. and then Hot Deals for the factory serviced units. Good luck. Curt Sprenger 1987 PT38, Anaheim Hills, Calif. Pete Amerson Jr wrote: > I have a a 87 PT-40 with two Statpower 40 amp chargers that have quit > working. Any recommendations for replacements? > > Pete Amerson > 87 PT-40 > Pensacola FL > > [Non-text portions of this message have been removed] > > > ------------------------------------------------------------------------ > YAHOO! GROUPS LINKS > > * Visit your group "WanderlodgeForum > <http://groups.yahoo.com/group/WanderlodgeForum>" on the web. > > * To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of > Service <http://docs.yahoo.com/info/terms/>. > > > ------------------------------------------------------------------------ > |
08-03-2005, 03:24
Battery Chargers
Interesting topic, as the PT38 I just purchased has one 40 amp charger working. Instead of replacing them with more chargers, I was thinking of replacing them with a 2500 watt inverter with 100 - 130 amp 3 stage, temperature correcting charger built in. Other than the cost (approx $1,400) is there anything else I am missing? I would think that the 1986 era inverter is inefficient and likely to die in the future anyway. Steve Harrie (St. George, UT) [Non-text portions of this message have been removed] |
08-03-2005, 07:55
Battery Chargers
>Instead of replacing them with more chargers, I was thinking of replacing >them with a 2500 watt inverter with 100 - 130 amp 3 stage, temperature >correcting >charger built in. Other than the cost (approx $1,400) is there anything else >I am missing? Steve, If you're thinking about a Trace unit, think again. If the inverter needs work, you're without a charger. and with Trace, the turn around time to have it fixed is lengthy. Trace quality has gone down since their buyout... Blair in Oregon >I would think that the 1986 era inverter is inefficient and likely to die in >the future anyway. > >Steve Harrie >(St. George, UT) > > > >[Non-text portions of this message have been removed] > > > >---------- >YAHOO! GROUPS LINKS > > * Visit your group > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. > * > * To unsubscribe from this group, send an email to: > * > odgeForum-unsubscribe@yahoogroups.com > > * > * Your use of Yahoo! Groups is subject to the > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > >---------- [Non-text portions of this message have been removed] |
08-04-2005, 09:45
Battery Chargers
turn around time to have it fixed is lengthy. Good point Blair, Steve [Non-text portions of this message have been removed] |
08-07-2005, 02:55
Battery Chargers
I have a couple of 3000w Freedom inverters which I believe the
charging section is malfunctioning. Any idea how much this would cost to fix and how long it would take? |
07-31-2006, 04:39
Battery Chargers
Fellows,
I need your input. I am looking at changing my old battery boilers. I have been reading about IOTA CHARGERS. I notice a lot of posts about using the DLS-45 Amp output. The old chargers are 60 amp. each. Would it be better to put two 55 amp or even two 75 amp. Can you disconnect the old chargers and use the same wireing and regulators. Where have you found the best pricing. Thanks, Howard Truitt Camilla, Ga. 86 PT40 [Non-text portions of this message have been removed] |
07-31-2006, 05:44
Battery Chargers
Howard I have an bank of eight six volt house batteries charged by two 55amp
IOTAs. If I were to do it again I think I would put in two 75amp. IOTAs are great with the add-on wizard device and the price is very reasonable. On 31/07/06, Howard O. Truitt > > Fellows, > I need your input. I am looking at changing my old battery boilers. I have > been reading about IOTA CHARGERS. > I notice a lot of posts about using the DLS-45 Amp output. The old > chargers are 60 amp. each. Would it be better to put two 55 amp or even two > 75 amp. > Can you disconnect the old chargers and use the same wireing and > regulators. > Where have you found the best pricing. > Thanks, > Howard Truitt > Camilla, Ga. > 86 PT40 > > [Non-text portions of this message have been removed] > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] |
