Sending Units for Kohler/Yanmar 12.5
08-01-2005, 02:54
Does anyone know the part numbers for the oil pressure & water
temperature sensors for a Kohler/Yanmar 12.5 (engine model #4tn82e-uk)? This is Kohler model #12.5CC067. I have ordered from a Kohler dealer but keep receiving the shutdown switches. Bill & Rita in Roanoke, VA 1987 FC-35 |
08-01-2005, 13:31
Bill and Rita,
I checked my service manual, and it looks like the part numbers are: Oil pressure switch: #256530 Water Temp switch: #252752 The manual also shows "switch, water temperature", with a part #258694, and I can't tell which one is used. Let me know if this doesn't help...I'll investigate further if necessary. Kevin McKeown Yorba Linda, CA 1986 38' PT 12.5 Yanmar/Kohler 4TN-82E [Non-text portions of this message have been removed] |
08-01-2005, 20:50
Kevin, Thanks for the info on the sending units, In addition to the
incorrect parts received from the Kohler dealer I also received a oil pressure switch from BB with the wrong size threads. The numbers you have provided should help us finally resolve the issue. Thanks again, Bill & Rita in Roanoke, VA 1987 FC-35 [Non-text portions of this message have been removed] |
