Samsung Refrigerator for 2001 LXi
09-23-2019, 09:12
(This post was last modified: 09-23-2019 09:13 by Gregg.)
Post: #21
RE: Samsung Refrigerator for 2001 LXi
Urnie,
I had the same problem. The easiest way I found was to locate an inverter plug and wire a second outlet from it to behind the frig. I used the plug under the dinette. I also put in a shut off for the plug in case I wanted to use the inverter but not the frig. Gregg Urnie, I had the same problem. The easiest way I found was to locate an inverter plug and wire a second outlet from it to behind the frig. I used the plug under the dinette. I also put in a shut off for the plug in case I wanted to use the inverter but not the frig. Gregg Gregg & Jane Gesse 1994 WLWB 40 Mid-Door |
01-05-2021, 00:59
Post: #22
Hi
I just got back from a trip to Colorado - temps were usually in the 20's. I had problems with the freezer part of the refrigerator - refrigerator was OK. The freezer quite often was about +20. When I pushed the "power freeze" button it worked for awhile. The next time I check it would be about +20 I think the problem was the outdoor temperature and I didn't block the panel at the back of the refrigerator and did not seal the top vent so the I think cold air was affecting the refrigerator. Please let me know if this is the problem. Urnie & Medie Krueger Yorkville, IL 2001 LXi One Slide 1983 FC35 sold |
