Transmission Retarder Lever location? Position?
07-21-2023, 00:12
Okay, I haven't driven my Wandelodge much. I need to get it over a small but intimidatingly steep hill and wan to use the transmission retarder.
I understand the retarder, when enabled, will kick in whenever the brake pedal is pressed (and note that engaging and disengaging the retarder should be done with your foot OFF the throttle) but that also there's a manual lever to adjust how much oomph it supplies. Only I'm not sure if it's the lever I'm thinking it is.
On a 4-speed Allison (HTB748), 1987 vintage, is the transmission retarder the black lever, under the dash but close to the shift selector? Slightly bigger than a cigarette lighter, one domed end piece, one cylindrical (or a bit tapered) shaft? I wish I had a pic.
If that's the right lever, is down the least resistance and up more resistance, or the other way around?
Cheers!
07-28-2023, 17:05
RE: Transmission Retarder Lever location? Position?
Confirmed! It's the lever I thought it was, as described above. It's pretty obviously plumbed into the control palel, now I looked at it again.
With NO THROTTLE, and the lever in the UP position
Activate the transmission retarder via the switch on the transmission control panel, driver's left side. The indicator light will NOT come on until the retarder is acting on the transmission
The transmission retarder will engage if the BRAKE treadle is depressed OR
You can set the drag by lowering the lever partway or all the way. If the indicator light is on, the system is actively slowing the vehicle down.
For obvious reasons, you shouldn't hit the throttle when the transmission retarder operating, that would be like pushing the gas and the brake at the same time.
You can keep the system activated, with no drag set on the lever (indicator light off) and it will only assist the brakes. But don't forget to turn it off in the flats or you'll just be adding stress to the system every time you hit the brakes.
Keep an eye on the Transmission Retarder Temperature gauge, it heats up surprisingly quickly. I got mine up to about 260 degrees; the manual says 330 is tops, and that tracks with what's on the gauge.
