Part Numbers Needed - (Cross posted!)
08-06-2005, 00:56
Does anyone have the current part #s for the Kohler Generator end
parts below. The gen is/was on a 35' FC 1982. Powered by Perkins 4
cyl. The new owners of our coach wants to convert the gen back to
original equipment.
1. Rotor
2. Stator
3. Brush holder
4. Brush
Thanks.
If you want to take offline use: wjmorganjr@...
Billy Morgan
ex 82FC35 3208NA SB
ex Chesapeake VA
08-06-2005, 05:59
Billy:
Actually there are several different part numbers for the 12.5KW Kohler. We
need the spec number off the name plate, usually found on the sloped
bracket from engine to the Kohler. Example (961005C) and the gen set type;
Example CCOPY67 or COPY or CCOPY. With this info I can give you the part
numbers needed.
On the CCOPY, Spec number (961015C) for instance. Those parts are listed in
group 201 as
1. rotor # A258569
2. Stator $ 258393
3. Brush holder # 259275
4. Brush # 239282
then regulator part number has changed to #228602
Safe travels,
>original equipment.
>1. Rotor
>2. Stator
>3. Brush holder
>4. Brush
>Thanks.
>Billy Morgan
>ex 82FC35 3208NA SB
>ex Chesapeake VA
