Refrigerator help needed.
08-09-2005, 15:27
The refrigerator is not cooling when operating on gas. It works fine
when hooked up to electricity. I pulled the burner out and cleaned
it, reinstalled. I also removed the vent cover on the roof to verify
there was no blockage. I also brushed the fins while the roof cover
was off. I have the wind shield off and the flame is all blue and
looks to be burning the full length of the flame tube. The
refrigerator is a Dometic RM1300. How long should it take to begin
cooling? Are there other things to check? There is also a fan behind
the refrigerator and when I turn the fan on at the galley panel should
the fan be spinning or is thermostatically controlled?
Troy, Waconia MN
1983 FC33
08-09-2005, 16:47
Hi Troy:
It is time to clean the flue tube of rust and soot and also clean the
baffle that hangs in the flue tube.
Open the anti flame blow out cap on top of the flue tube. You will see a
bent wire hanging on the inside of the tube, pull the baffle out taking
care not to disturb the bend in the wire and wire brush the baffle. Then
you need a flue tube brush to clean the tube with. Sort of like running a
brush down the barrel of a rifle to clean it.
The baffle makes the rising heat swirl to evenly distribute the heat in the
proper proportions and the built up scale inside the tube prevents the heat
from causing the ammonia/water to boil at the proper temp causing the super
heated gas to rise to the evaporator and the water to separate and flow
back to the chamber.
It heats on electric because the heat transfer is to the out side of the
flue tube causing the above reaction.
Safe travels,
>Troy, Waconia MN
>1983 FC33
08-11-2005, 02:13
That worked! Thanks Ralph.
How about the refrigerator cooling fan, mounted behind the fridge. Is
the fan thermostatically controlled?
Troy, Waconia MN
1983 FC33
> Hi Troy:
see a
taking
Then
running a
in the
the heat
the super
flow
> Safe travels,
fine
verify
cover
behind
should
> >Troy, Waconia MN
> >1983 FC33
08-11-2005, 03:14
With the frig. full of food, the setting all the way cold, and operating
for more than a day, what should the temperature be inside the frig?
> Troy, Waconia MN
> 1983 FC33
> > Hi Troy:
> the
> see a
> taking
> Then
> running a
> in the
> the heat
> the super
> flow
> the
> > Safe travels,
> fine
> verify
> cover
> behind
> should
> > >Troy, Waconia MN
> > >1983 FC33
> YAHOO! GROUPS LINKS
> * Visit your group "WanderlodgeForum
> <http://groups.yahoo.com/group/WanderlodgeForum>" on the web.
> * Your use of Yahoo! Groups is subject to the Yahoo! Terms of
> Service <http://docs.yahoo.com/info/terms/>.
08-11-2005, 03:43
Curt,
This is just a guess, But I think it should be about 40 degrees,
Until the outside ambient temp reaches over 80/85. The amonia frig
can only reduce the temp about 40 to 50 degrees.
It may not be as efficient at 90/95 outside degrees.
Bill 88 FC
operating
frig?
fridge. Is
> > Troy, Waconia MN
> > 1983 FC33
> > wrote:
> > > Hi Troy:
clean
> > the
will
> > see a
out
> > taking
baffle.
> > Then
> > running a
the heat
> > in the
prevents
> > the heat
causing
> > the super
> > flow
side of
> > the
> > > Safe travels,
works
> > fine
cleaned
> > verify
> > cover
blue and
begin
fan
> > behind
panel
> > should
> > > >Troy, Waconia MN
> > > >1983 FC33
> > YAHOO! GROUPS LINKS
web.
> > subject=Unsubscribe>
of
08-11-2005, 03:57
Thanks Bill. Our frig. operates at 40 degrees in 80/85 degree weather.
pattypape wrote:
> Curt,
> Bill 88 FC
> operating
> frig?
08-11-2005, 07:21
Curt, when I was a Hospital Corpsman we used to have to check the refrigerator
temps and they had to be 41 degrees F or lower to meet food safety standards.
So as long as they are below 41 degrees you should be OK.
Bruce Morris (919)872-7635
Webmaster - Wanderlodge Owners Online
1983 WL FC35RB
FMCA: 7142s Ham Radio: KI4ME
Vietnam Vet - 1966-67 'Doc' (Navy Corpsman) 3rd MarDiv.
> operating
> frig?
SPONSORED LINKS Recreational vehicles Wanderlodge Automotive maintenance
Recreational vehicle dealer Used recreational vehicles Automotive
radiators
YAHOO! GROUPS LINKS
08-11-2005, 09:30
Thanks Bruce. The thermometer in our frig. reads 40/41 degrees so I'm
going to be happy with that for now. It's s cheap thermometer so
accuracy is questionable.
> refrigerator temps and they had to be 41 degrees F or lower to meet
> 1983 WL FC35RB
> > operating
> > frig?
> maintenance
> Automotive radiators
> YAHOO! GROUPS LINKS
> Service.
> SPONSORED LINKS
<http://groups.yahoo.com/gads?t=ms&k=Recr...vehic\
les&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=U\
sed+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzhn_O\
bWmSYTw>
> Wanderlodge
<http://groups.yahoo.com/gads?t=ms&k=Wand...2=Wan\
derlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recrea\
tional+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLPj9U0JvqYQ>
<http://groups.yahoo.com/gads?t=ms&k=Auto...;vehi\
Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pmy34\
cC1O9CxA>
<http://groups.yahoo.com/gads?t=ms&k=Recr...ional\
+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deale\
r&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_XahaeY\
HfELr6o72IW1A>
<http://groups.yahoo.com/gads?t=ms&k=Used...onal+\
vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer\
&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km4L-\
kXbDI4ZSadEw>
<http://groups.yahoo.com/gads?t=ms&k=Auto...ehicl\
es&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Us\
ed+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgTnMq\
_4GlXA>
> YAHOO! GROUPS LINKS
08-11-2005, 12:28
Curt:
The freezer should be between 0F and 9F. The lower compartment should be
between 34F and 39F. Remember to leave air gaps between food stuffs so air
can circulate.
Safe travels,
Ralph
08-11-2005, 12:30
Good to hear, Troy. The fan should have a thermostat on it inline should
come on about 95F or so, that is give or take.
Safe travels,
Ralph
>Troy, Waconia MN
>1983 FC33
