refrigerant identification: was; the ever controversial "DASH AIR"
08-10-2005, 04:47
I agree Scott, mine cost me around $1,400.00 and is an on going cost factor.
When your EPA certified, every ounce recovered and every ounce dispersed, must be documented. One can get a good read on what is in a system with a known good chart, amp meter, accurate gauges and scales. The size of the access valves are a good indication, providing they were, in fact, changed over ( many are not) when going from R-12 to R-134a as a for instance. The ambient temp, the out put of the Delta T, the amps and the given low and high pressures, when put into an equation and crossed by the known values on the charts get very close. However, new blends are being brought out on the market every day and being advertised that they will be the replacements in the future. The base used in refrigerants is another item that must be considered when using, replacing or changing to an up graded version. Then it goes further if there has been a compressor burn out or not, in flushing the system the a vacuum draw down and another flushing using gasses like inert nitrogen. Then finely another full vacuum drawn on a time constant to a millibar reading and held stable there to check for leaks. Safe travels, Ralph and Charolette Fullenwider Ralph's RV Solutions, Duncan, Oklahoma http://home.swbell.net/rlf47/index.htm At 08:37 AM 8/10/2005 -0700, you wrote: >Not an easy task to identify the type of >refrigerant/oil is in your system. If you think >someone may have converted to something else, (and >there are lots of options out there, not just 134a), >you probably have to go to an A/C shop, and pay them >to test it. The equipment costs $700-$1000. > >Scott Peatross >'87PT40 > > > >--- ttikalsky > > >--------------------------------- >Anyone know how to test for the type of refrigerant >currently in the >system? (R12 or R134)? > > |
08-10-2005, 05:12
Yes Ralph, A/C system service is quite complicated
these days isn't it? I have a friend who owns a auto repair shop, and he says the average a/c repair job runs about $1,000. Lots of people running around in older cars with their windows down. Where can I get the pressure/temp/performance charts that you are using? Last week I was recharging my Acura with liquid gold (R12) and searched the net without luck for the performance parameters of R12. I recall some nice charts with inlet temp, outlet temp, vs. pressures, etc. I want to be fully prepared when I tackle the PT40 dash air. Scott Peatross '87PT40 dash air not working---yet --- "Ralph L. Fullenwider" One can get a good read on what is in a system with a known good chart, amp meter, accurate gauges and scales. |
08-10-2005, 06:13
Scott:
Here is a web address that has a decent chart to follow; http://hvacwebtech.com/freons.htm It is only off by .2 Safe travels, Ralph and Charolette Fullenwider Ralph's RV Solutions, Duncan, Oklahoma http://home.swbell.net/rlf47/index.htm At 10:12 AM 8/10/2005 -0700, you wrote: >Yes Ralph, A/C system service is quite complicated >these days isn't it? I have a friend who owns a auto >repair shop, and he says the average a/c repair job >runs about $1,000. Lots of people running around in >older cars with their windows down. > >Where can I get the pressure/temp/performance charts >that you are using? Last week I was recharging my >Acura with liquid gold (R12) and searched the net >without luck for the performance parameters of R12. I >recall some nice charts with inlet temp, outlet temp, >vs. pressures, etc. I want to be fully prepared when I >tackle the PT40 dash air. > >Scott Peatross >'87PT40 >dash air not working---yet > > |
