Burnt wiring harness by turbo
08-19-2005, 07:27
I have a 1982 3208t cat in a 35 foot wanderlodge.The power stering
reservoir hose was burnt and I moved it to the front AC comptessor location.I installed a heat shield on the turbo and cross exhaust manafold.I changed the tranmission shiftdown cable,Burnt.The wiring harness is brittle and insulation coming off. Has anyone had this problem or re-routed the wiring? There is just enough room to put you fingers between the exhaust blanket and the dog house. Ken Kalmakoff Richmond BC Canada 1982 3208t 35ft |
08-19-2005, 13:06
Hi Ken,
I was reading your post and it all sounded odd...until I noticed your coach year. The turbo 3208 was not installed by the factory until the 1983 model year. Your engine was likely installed as a custom job by an aftermarket shop. Sounds like they missed a few things, but you're tracking them down. You might also want to wrap the exhaust with header wrap as it goes on by the airbags under the coach. Gary Miller 83 FC 33 - For Sale 'millercoachworks.com" Milwaukee area --- In WanderlodgeForum@yahoogroups.com, "bus2nut" > I have a 1982 3208t cat in a 35 foot wanderlodge.The power stering > reservoir hose was burnt and I moved it to the front AC comptessor > location.I installed a heat shield on the turbo and cross exhaust > manafold.I changed the tranmission shiftdown cable,Burnt.The wiring > harness is brittle and insulation coming off. > Has anyone had this problem or re-routed the wiring? > There is just enough room to put you fingers between the exhaust > blanket and the dog house. > > Ken Kalmakoff > Richmond BC Canada > 1982 3208t 35ft |
08-19-2005, 15:39
--- In WanderlodgeForum@yahoogroups.com, "Gary Miller"
> Hi Ken, > > I was reading your post and it all sounded odd...until I noticed > your coach year. The turbo 3208 was not installed by the factory > until the 1983 model year. > > Your engine was likely installed as a custom job by an aftermarket > shop. Sounds like they missed a few things, but you're tracking > them down. > > You might also want to wrap the exhaust with header wrap as it goes > on by the airbags under the coach. > > Gary Miller > 83 FC 33 - For Sale 'millercoachworks.com" > Milwaukee area > > --- In WanderlodgeForum@yahoogroups.com, "bus2nut" > > I have a 1982 3208t cat in a 35 foot wanderlodge.The power stering > > reservoir hose was burnt and I moved it to the front AC comptessor > > location.I installed a heat shield on the turbo and cross exhaust > > manafold.I changed the tranmission shiftdown cable,Burnt.The > wiring > > harness is brittle and insulation coming off. > > Has anyone had this problem or re-routed the wiring? > > There is just enough room to put you fingers between the exhaust > > blanket and the dog house. > > > > Ken Kalmakoff > > Richmond BC Canada > > 1982 3208t 35ft You are right Garry. Wanderlodge aparantly only installed turbos on the last six coaches built in 1982.My motor was installed by the original owner in 1995. I purchased it in 1998.The maesurements of the new motor are wider and longer leaving little room at the rear.I have moved the power steering pump up front to where the air conditionar pump was.The pump hoses where brittle from the heat from the turbo.The heat from the turbo has now taken its toll on the wiring harness. Ken Kalmakoff Richmond BC Canada 1982fc 3208t |
