Looking for Best 110V Portable Air Compressor
08-23-2005, 14:29
I want to invest in a 110V air compressor. I would like to setup in
my Bird somewhere that would allow me to 1) charge my air tanks without starting my Cat 3208T 2) Thus allow me to open my slide out Generator door 3) Air up my tires when cool 4) Drive some air tools for work around the Home and the Bird. I have seen some dual tank Air Compressors available from the local Harbor Freight Tool store. Are there any recommendation out there ?? I want it to be small enough to possibly fit in the Sewer Hose exterior Driver's side Bay on my FC35SB since that is where my Air Tool Outlet is currently living. I also considered a auxillary air tank that could hold compressed air from when I run the coach with maybe a one way valve so it will not drain down over time ??? __________________ Dave and Judy Beatty 83 FC35SB (BirdCage) Federal Way, Washington State |
08-23-2005, 15:12
Dave, there are also compact yeat powerfull high end 12 volt air
compressors the 4 wheeler guys use. http://www.fourwheeler.com/techarticles/62758/ . One example: Built to Last The Extreme Aire compressor is the only unit with a large, washable K&N filter on the intake, which extends compressor life. With a 100- percent duty-cycle and 150psi rating, it took only 3 minutes, 5 seconds to fill our test tire. The Extreme Aire performed well in the air-tool test, too. It was able to spin eight lug nuts before pausing when combined with a 2-gallon air tank. It takes a while to load the site. Dan 94 BMC 37' --- In WanderlodgeForum@yahoogroups.com, "Dave Beatty" <beattyd@y...> wrote: > I want to invest in a 110V air compressor. I would like to setup in > my Bird somewhere that would allow me to > > 1) charge my air tanks without starting my Cat 3208T > 2) Thus allow me to open my slide out Generator door > 3) Air up my tires when cool > 4) Drive some air tools for work around the Home and the Bird. > > I have seen some dual tank Air Compressors available from the local > Harbor Freight Tool store. Are there any recommendation out there ?? > I want it to be small enough to possibly fit in the Sewer Hose > exterior Driver's side Bay on my FC35SB since that is where my Air > Tool Outlet is currently living. > > I also considered a auxillary air tank that could hold compressed air > from when I run the coach with maybe a one way valve so it will not > drain down over time ??? > __________________ > Dave and Judy Beatty > 83 FC35SB (BirdCage) > Federal Way, Washington State |
08-24-2005, 01:04
<beattyd@y...> wrote: > I want to invest in a 110V air compressor. I would like to setup in > my Bird somewhere that would allow me to > > 1) charge my air tanks without starting my Cat 3208T > 2) Thus allow me to open my slide out Generator door > 3) Air up my tires when cool > 4) Drive some air tools for work around the Home and the Bird. >>>SNIP Hi Dave, #'s 1,2 &3 are no problem for many small, 120VAC compressors. #4 is a different story. Depending on the tools being run, and the length of time, IMO, you are going to need a much larger compressor and tank. My Bird(s), came with a Gast 120VAC twin http://www.gastmfg.com/piston.html and that is all that is required to pump up a tire and to keep the auxillary air up while connected to shore power. At home, I run my 5hp, two stage, with a 60 gallon size tank, at near capacity when running a sander and have to ocassionally wait for it to catch up when bead blasting. That unit has, about 50 times the capacity of the Bird's on board unit. If you just want to run an air drill or a few seconds of an imppact wrench, the small, on board unit may suffice. Any serious air use will require multiple horsepower and larger storage capacity. In order to get the higher pressures needed to reduce the tank size to something less huge, a two stage compressor is needed so the second stage "recompress's" the air from the first to boost the pressure. Rich D. '99LXi43' CT |
08-24-2005, 06:28
Thanks to all for the advise on the Air Compressor.
Dave Beatty --- In WanderlodgeForum@yahoogroups.com, "Dan Weaver" From: "Dan Weaver" Date: Tue Aug 23, 2005 8:12 pm Subject: Re: Looking for Best 110V Portable Air Compressor ac7880 Dave, there are also compact yeat powerfull high end 12 volt air compressors the 4 wheeler guys use. http://www.fourwheeler.com/techarticles/62758/ . One example: Built to Last The Extreme Aire compressor is the only unit with a large, washable K&N filter on the intake, which extends compressor life. With a 100- percent duty-cycle and 150psi rating, it took only 3 minutes, 5 seconds to fill our test tire. The Extreme Aire performed well in the air-tool test, too. It was able to spin eight lug nuts before pausing when combined with a 2-gallon air tank. It takes a while to load the site. Dan 94 BMC 37' --- In WanderlodgeForum@yahoogroups.com, "Dave Beatty" <beattyd@y...> wrote: I want to invest in a 110V air compressor. I would like to setup in my Bird somewhere that would allow me to 1) charge my air tanks without starting my Cat 3208T 2) Thus allow me to open my slide out Generator door 3) Air up my tires when cool 4) Drive some air tools for work around the Home and the Bird. I have seen some dual tank Air Compressors available from the local Harbor Freight Tool store. Are there any recommendation out there ?? I want it to be small enough to possibly fit in the Sewer Hose exterior Driver's side Bay on my FC35SB since that is where my Air Tool Outlet is currently living. I also considered a auxillary air tank that could hold compressed air from when I run the coach with maybe a one way valve so it will not drain down over time ??? __________________ Dave and Judy Beatty 83 FC35SB (BirdCage) Federal Way, Washington State |
