gen radiator update, question on insulation
08-25-2005, 09:20
Hi
I got the radiator back in today! Yea! just took a lot of patience and holding my mouth right, & propping the rad & shroud just right to get those bottom shroud bolts back in...have everything bolted back together, haven't fired it yet. Think my little brother would be tickled that I was able to fix it! Figure while I've got the slide out and can reach all that gray/black insulation that is falling down, cracking and rotting in the generator bay-- I'd finish pulling it out....it's caused problems a couple times, by falling down on and around the genny causing it to shut off.... Question, has anyone used the spray in foam type insulation? There are a couple places nearby that advertise. (haven't called yet to see if it's heat resistent etc. tho someone told me it was???) Thanks for the help! Quick recovery wished for Liz! Who at the moment is not homesick for Texas! Rose Mary 82 FC 33 Oregon |
08-25-2005, 09:46
Rose Mary,
Congratulations! I'm sure your little brother would be proud of you! You are an inspiration to me and my wife, she's willing to tackle 'Bird repairs and enjoys the "adventure" of learning by doing. The 'Birds have sprayed on urethane insulation for sound supression on the underside of the coach. I have no idea of its heat resistance properties... I'm sure someone on the forum(s) has more direct knowledge of this product or can recommend another product better suited to your application. Keep learning, you'll have the "enjoyment" and satisfaction of having done it yourself for much less money than hiring it done. Jim & Pam Owens 77 FC33SB (Gas) "Sweetie's Dream" Lake of the Ozarks, MO --- In WanderlodgeForum@yahoogroups.com, "Rose Mary" > Hi > I got the radiator back in today! Yea! just took a lot of patience > and holding my mouth right, & propping the rad & shroud just right to > get those bottom shroud bolts back in...have everything bolted back > together, haven't fired it yet. Think my little brother would be > tickled that I was able to fix it! > > Figure while I've got the slide out and can reach all that gray/black > insulation that is falling down, cracking and rotting in the > generator bay-- I'd finish pulling it out....it's caused problems a > couple times, by falling down on and around the genny causing it to > shut off.... > Question, has anyone used the spray in foam type insulation? There > are a couple places nearby that advertise. (haven't called yet to see > if it's heat resistent etc. tho someone told me it was???) > > Thanks for the help! > > Quick recovery wished for Liz! Who at the moment is not homesick for > Texas! > Rose Mary > 82 FC 33 > Oregon |
08-25-2005, 10:43
Way to go Rose Mary!!
Mike Bulriss 83 PT40 "Stagecoach" - for sale 91 PT40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "Rose Mary" > Hi > I got the radiator back in today! Yea! just took a lot of patience > and holding my mouth right, & propping the rad & shroud just right to > get those bottom shroud bolts back in...have everything bolted back > together, haven't fired it yet. Think my little brother would be > tickled that I was able to fix it! > > Figure while I've got the slide out and can reach all that gray/black > insulation that is falling down, cracking and rotting in the > generator bay-- I'd finish pulling it out....it's caused problems a > couple times, by falling down on and around the genny causing it to > shut off.... > Question, has anyone used the spray in foam type insulation? There > are a couple places nearby that advertise. (haven't called yet to see > if it's heat resistent etc. tho someone told me it was???) > > Thanks for the help! > > Quick recovery wished for Liz! Who at the moment is not homesick for > Texas! > Rose Mary > 82 FC 33 > Oregon |
08-25-2005, 14:15
Rose Mary, Great news!! Good to see you "update" the situation. The
insulation question is right on the money..do the upgrade NOW when you have the genny out.It will be sooo much easier without the genny compartment full of stuff...I purchased the insulation material from forum member Stephen Birtles..man that stuff is good. Very easy to work with. (ie:cutting, placing before removing the "very sticky" backing) That material is very good. One word of caution...Make sure the surface on the coach is REALLY clean..especially the TOP of the genny compartment. Mine was not (son did the grinding there) and it fell..I had to redo that portion..but there was a NOTICEABLE noise difference...when the genny ran!! Best of luck Scott B 86FC35 Murrells Inlet SC (working on a new power tech genny..hmm parts anyone??) --- In WanderlodgeForum@yahoogroups.com, "Rose Mary" > Hi > I got the radiator back in today! Yea! just took a lot of patience > and holding my mouth right, & propping the rad & shroud just right to > get those bottom shroud bolts back in...have everything bolted back > together, haven't fired it yet. Think my little brother would be > tickled that I was able to fix it! > > Figure while I've got the slide out and can reach all that gray/black > insulation that is falling down, cracking and rotting in the > generator bay-- I'd finish pulling it out....it's caused problems a > couple times, by falling down on and around the genny causing it to > shut off.... > Question, has anyone used the spray in foam type insulation? There > are a couple places nearby that advertise. (haven't called yet to see > if it's heat resistent etc. tho someone told me it was???) > > Thanks for the help! > > Quick recovery wished for Liz! Who at the moment is not homesick for > Texas! > Rose Mary > 82 FC 33 > Oregon |
08-25-2005, 14:38
well scott i guess mine will fall to till i get some time to put some
screws and washers in..ran outa steam on that project tonite.. how many sheets did you get? i got 3 and i needed 4~~~~~~~~~ woody fc35rb 1981 with SLICK DOOR GEN SET ps how much for me to make it a clean removal scott~! |
08-25-2005, 15:01
Looks good, I want the OEM fan shroud. Dupree will ship it.
I will pay you if I have to. Mike Hohnstein ----- Original Message ----- From: rwoodysurplus To: WanderlodgeForum@yahoogroups.com Sent: Thursday, August 25, 2005 9:38 PM Subject: [WanderlodgeForum] Re: gen radiator update, question on insulation well scott i guess mine will fall to till i get some time to put some screws and washers in..ran outa steam on that project tonite.. how many sheets did you get? i got 3 and i needed 4~~~~~~~~~ woody fc35rb 1981 with SLICK DOOR GEN SET ps how much for me to make it a clean removal scott~! ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] |
08-25-2005, 15:04
i used the factory shroud but maybe you were to be asking scott?
later!- -- In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" <MHOHNSTEIN@w...> wrote: > Looks good, I want the OEM fan shroud. Dupree will ship it. > I will pay you if I have to. > Mike Hohnstein > ----- Original Message ----- > From: rwoodysurplus > To: WanderlodgeForum@yahoogroups.com > Sent: Thursday, August 25, 2005 9:38 PM > Subject: [WanderlodgeForum] Re: gen radiator update, question on insulation > > > well scott i guess mine will fall to till i get some time to put some > screws and washers in..ran outa steam on that project tonite.. > > how many sheets did you get? > i got 3 and i needed 4~~~~~~~~~ > > woody fc35rb 1981 with SLICK DOOR GEN SET > > ps > how much for me to make it a clean removal scott~! > > > > > > ------------------------------------------------------------------- ----------- > YAHOO! GROUPS LINKS > > a.. Visit your group "WanderlodgeForum" on the web. > > b.. To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > ------------------------------------------------------------------- ----------- > > > > [Non-text portions of this message have been removed] |
08-25-2005, 15:22
Yeah mebbe, whatever, I need one.
Mike Hohnstein ----- Original Message ----- From: rwoodysurplus To: WanderlodgeForum@yahoogroups.com Sent: Thursday, August 25, 2005 10:04 PM Subject: [WanderlodgeForum] Re: gen radiator update, question on insulation i used the factory shroud but maybe you were to be asking scott? later!- -- In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" <MHOHNSTEIN@w...> wrote: > Looks good, I want the OEM fan shroud. Dupree will ship it. > I will pay you if I have to. > Mike Hohnstein > ----- Original Message ----- > From: rwoodysurplus > To: WanderlodgeForum@yahoogroups.com > Sent: Thursday, August 25, 2005 9:38 PM > Subject: [WanderlodgeForum] Re: gen radiator update, question on insulation > > > well scott i guess mine will fall to till i get some time to put some > screws and washers in..ran outa steam on that project tonite.. > > how many sheets did you get? > i got 3 and i needed 4~~~~~~~~~ > > woody fc35rb 1981 with SLICK DOOR GEN SET > > ps > how much for me to make it a clean removal scott~! > > > > > > ------------------------------------------------------------------- ----------- > YAHOO! GROUPS LINKS > > a.. Visit your group "WanderlodgeForum" on the web. > > b.. To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > ------------------------------------------------------------------- ----------- > > > > [Non-text portions of this message have been removed] ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] |
08-25-2005, 21:54
Woody, your exactly right I could have used more. I think I got 2.5
sheets from Stephen. One note..If you have not completed the project yet I noticed the clearance on the front (body panel)and the water pump pully was REALLY CLOSE. Mine is cutting into the material. Not a biggy for me cause the genny not working exactly right. Also the idea of screws and fender washers is a good one for the top of the compartment. The material is so heavy (it has to be) I think with all the vibrations from genny running, and driving down the road, the best idea is to secure that section. The rest has held up great. A 5.00 roll of aluminum tape to finish corners etc makes for a clean upgrade. I am gonna make one last attempt to fix it myself since I now have relays, regulators etc "in stock" lol. Just waiting for the heat to subside a bit. Should that fail (with my mechanical ability coupled with my patience level being stuffed under there) dont bet the ranch that I will fix it sooooo maybe a bunch of good/like new parts may be for sale. I will have the answer soon!! Scott B 86FC --- In WanderlodgeForum@yahoogroups.com, "rwoodysurplus" wrote: > well scott i guess mine will fall to till i get some time to put some > screws and washers in..ran outa steam on that project tonite.. > > how many sheets did you get? > i got 3 and i needed 4~~~~~~~~~ > > woody fc35rb 1981 with SLICK DOOR GEN SET > > ps > how much for me to make it a clean removal scott~! |
08-25-2005, 23:37
I redid my generator compartment with Soundown composite foam 1" thick 2#
per square foot insulation with a foil coating and the engine doghouse with 2" thick 2# per square foot composite insulation with a foil coating ( http://www.soundown.com/ ). The generator insulation has been on for over 2 years and it is still as tight as when I installed it. I coated both the generator surface and the insulation with 3M Super 77 adhesive. When the two surfaces are put in contact it is impossible to remove without destroying the insulation it is that good an adhesive. The 2" insulation was $169 for a 4.5 by 6' sheet which was more then enough to do the engine doghouse with material left over. It made a dramatic difference in both noise control and heat.. The 1" insulation was $116 and comes in a 4' by 8' sheet and there was material left over when doing the generator compartment. It should be noted that the piece for the generator door panel was cut using the old piece that BB had installed for a pattern and the cutouts for the pullies gave the correct clearance for them. Tom 1982 FC35 Vernon Center,NY At 09:54 AM 8/26/2005 +0000, you wrote: >Woody, your exactly right I could have used more. I think I got 2.5 >sheets from Stephen. One note..If you have not completed the project >yet I noticed the clearance on the front (body panel)and the water pump >pully was REALLY CLOSE. Mine is cutting into the material. Not a biggy >for me cause the genny not working exactly right. Also the idea of >screws and fender washers is a good one for the top of the compartment. >The material is so heavy (it has to be) I think with all the vibrations >from genny running, and driving down the road, the best idea is to >secure that section. The rest has held up great. A 5.00 roll of >aluminum tape to finish corners etc makes for a clean upgrade. > >I am gonna make one last attempt to fix it myself since I now have >relays, regulators etc "in stock" lol. Just waiting for the heat to >subside a bit. Should that fail (with my mechanical ability coupled >with my patience level being stuffed under there) dont bet the ranch >that I will fix it sooooo maybe a bunch of good/like new parts may be >for sale. I will have the answer soon!! >Scott B >86FC > >--- In WanderlodgeForum@yahoogroups.com, "rwoodysurplus" >wrote: > > well scott i guess mine will fall to till i get some time to put some > > screws and washers in..ran outa steam on that project tonite.. > > > > how many sheets did you get? > > i got 3 and i needed 4~~~~~~~~~ > > > > woody fc35rb 1981 with SLICK DOOR GEN SET > > > > ps > > how much for me to make it a clean removal scott~! > > > > >---------- >YAHOO! GROUPS LINKS > > * Visit your group > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. > * > * To unsubscribe from this group, send an email to: > * > odgeForum-unsubscribe@yahoogroups.com > > * > * Your use of Yahoo! Groups is subject to the > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > >---------- |
