Engine tach
08-27-2005, 18:46
Engine tach
2 part question:
What's the best way to install a tach on a typical diesel engine? I'd like to add a dash gauge to mine but am unsure or where to get them. Installation I'm not scared of, just need a source and recommendation on brand. Where's a good place to get a handheld RPM reader? I need to make sure of the RPM range on my 8.3 Cummins and would like to buy a unit. I've seen some that use reflective tape and a laser to read RPM. Suggestions? Thanks a bunch! Steve 2 '98 Bluebird QBRE Partybuses - 1st official paying trip just make to Bristol Raceway and back this weekend!!! |
08-28-2005, 01:17
Engine tach
Probably the easiest way to install a tach would be a type which
would get a signal from the alternator. I'd check with NAPA and the like to see what they offer. Gary Miller 83 FC 33 - For Sale 'millercoachworks.com' Milwaukee area --- In WanderlodgeForum@yahoogroups.com, "transit360" > 2 part question: > What's the best way to install a tach on a typical diesel engine? I'd > like to add a dash gauge to mine but am unsure or where to get them. > Installation I'm not scared of, just need a source and recommendation > on brand. > > Where's a good place to get a handheld RPM reader? I need to make > sure of the RPM range on my 8.3 Cummins and would like to buy a unit. > I've seen some that use reflective tape and a laser to read RPM. > Suggestions? > > Thanks a bunch! > Steve > 2 '98 Bluebird QBRE Partybuses - 1st official paying trip just make to > Bristol Raceway and back this weekend!!! |
08-28-2005, 01:25
Engine tach
>Where's a good place to get a handheld RPM reader? I need to make >sure of the RPM range on my 8.3 Cummins and would like to buy a unit. >I've seen some that use reflective tape and a laser to read RPM. >Suggestions? > >Thanks a bunch! >Steve Steve, I've got a portable hand held that you can use...Blair in Oregon [Non-text portions of this message have been removed] |
08-29-2005, 13:01
Engine tach
Blair,
Is this RPM reader for sale or borrow? I need a permanent tool I can keep. Thanks for the reply. Steve Blair > >Where's a good place to get a handheld RPM reader? I need to make >sure of the RPM range on my 8.3 Cummins and would like to buy a unit. >I've seen some that use reflective tape and a laser to read RPM. >Suggestions? > >Thanks a bunch! >Steve Steve, I've got a portable hand held that you can use...Blair in Oregon [Non-text portions of this message have been removed] --------------------------------- YAHOO! GROUPS LINKS Visit your group "WanderlodgeForum" on the web. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. --------------------------------- Steve Wicker http://www.360partybus.com 828-236-2841/301-0245 --------------------------------- Yahoo! Mail Stay connected, organized, and protected. Take the tour [Non-text portions of this message have been removed] |
08-30-2005, 00:53
Engine tach
Steve, borrow....Blair
I get a lot of my instruments from an outfit in Phoenix, AZ....can't remember the name. At 06:01 PM 8/29/2005, you wrote: >Blair, > > Is this RPM reader for sale or borrow? I need a permanent tool I can > keep. Thanks for the reply. > >Steve [Non-text portions of this message have been removed] |
08-30-2005, 10:23
Engine tach
steve,
sorry for the lower case, shoulder operation yesterday. WARNING! LONG POST did you make it to bristol? would you say jarrett was a bit ticked? first, i would check with cummings to see where they mount a sender. i would guess they have a place somewhere. probably a reluctance mount maybe on a timeing gear, somewhere that has gear teeth, then by adjusting the air gap to specifications a good pulse to supply a tachometer can be obtained. they may also have a tach spec that would mate the pick-up. if not, then gary's suggestion about using an alternator with tach output. you will need to know drive and driven pulley sizes to set up the tach. i believe the alternator has dip switches that you set according to the ratio of the two pulleys. your indicator, the tach, is an analog device, generally using a diode to rectify the incoming pulses with a capacitor and resistor to correlate incoming pulses to an analog reading, or, using induction coils and a permenant magnet. a dc generator pick-up is no good after time mainly due to variation in output voltage caused by the brush point of contact with the armature which would very easily get a film covering in time. so for accuracy you might limit your search to a digital to analog tach. you could go digital to digital but unless you had periodic updating rather than instantaenous readings the tach would be too busy. calibration.. unless you wanted to keep your pit road speed as close to, but not exceed 55 mph, or, do some serious drive line calculations, i'm not sure that +/- 250 rpm makes that much difference, until you establish a pattern,then what you do want however is repeatability. for greatest accuracy an analog indicator sould be set to full-scale deflection, and, unless the zero set is way off i would leave it as you would need to open the housing. you wouldn't want to run the diesel at that speed anyway, and the only way this calibration can be accomplished is to have both sender and tach on a bench set-up. i have a tach that operates much the same way a tuning fork is used. it has a calibrated dial that is matched to the length of a calibrated rod. as the rod is extended the dial has a pointer indicating a lowerer frequency, and, vice versa, as in f=1/t. when the vibration from the motor is equal to the rod length the rod resonates. i would guess that there are others, maybe better, but the one i have and use is a briggs and stratton, birometer-vibra tach, model 19200,$20.87.you want find this doing a google search, or, on the shelf but if you ask the man where you buy briggs and stratton parts he can order one for you. i just called to make sure they were still available, and they are. i ue mine mainly to set or check the frequecy of the genset. where frequency equals number of poles times revolutions per minute divided by 60 seconds, f=2x1800/60. the motor operates at 1800 rpm turning a generator that has two poles for each revolution. i do this with a load on the motor, the two ac's draw about 13 ampe each leg, or, about 1/2 the load of a 6.5 kw genset. you can plug in the battery chargers for more or even connect an 8 ft heating strip, fan, whatever. p=i x e, power equals volts times current, or, 54.17 amps=6500 watts x 120 volts the max rating for this generator. first, after the motor has warmed i apply the load, the ac's. then setting the dial at 1800 rpm and held firmly to the cylinder head shroud, 4" connector box, or generator, i rotate the dial lower or higher slowly till the wand resonates.first setting the wand to 1800 which in fact corresponds to 60 cycles. once i find the motor speed i can adjust the motor govenor speed up or down to the desired 1800 rpm/60 cps. you can expect the motor to speed up slightly when the load is removed. now to check the engine tach. hold the tach on a solid surface. set the wand to 1000, 1200, and 1500 rpm by rotating the dial. on each setting slowly depress the accelerator pedal watching the wand, slowly as you can pass the spot easily. when the wand length is in resonance with the motor vibraton the wand will vibrate wildly. check the engine tach to see if the two readings correspond, make note of the difference. there are frquencies, harmonics, and sub-harmonics or a running motor. these vibrations will be indicated by the vibrating wand but harmonics with a lesser intensity. some practice with observation and you can master the speed testing. whew! all with one hand. sorry to those who don't like long posts. bob janes --- In WanderlodgeForum@yahoogroups.com, "transit360" > 2 part question: > What's the best way to install a tach on a typical diesel engine? I'd > like to add a dash gauge to mine but am unsure or where to get them. > Installation I'm not scared of, just need a source and recommendation > on brand. > > Where's a good place to get a handheld RPM reader? I need to make > sure of the RPM range on my 8.3 Cummins and would like to buy a unit. > I've seen some that use reflective tape and a laser to read RPM. > Suggestions? > > Thanks a bunch! > Steve > 2 '98 Bluebird QBRE Partybuses - 1st official paying trip just make to > Bristol Raceway and back this weekend!!! |
08-30-2005, 15:49
Engine tach
Bob,
Thanks for the in depth reply. I'll look into it as an option and pass it along to fellow busers. Steve __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com [Non-text portions of this message have been removed] |
