Priming the Fresh Water Pump
08-28-2005, 09:45
I drained my fresh water lines on my 35FC80 side bath using the knobs
at the rear bed compartment. I filled the tank halfway and tried the sinks. I hear the pump running but no water is coming out. The commercial hookup works fine. No water is leaking out anywhere. Does the pump need to be primed? If so, how? Thanks, SDF 35FC80 |
08-29-2005, 01:22
Shawn, I had the same prob but it was the valve that changes the input
water from 'hookup pressure' to 'tank fill'. I dont know if you have the same set up but the electric valve on my camper was holding open. Does the pump keep running? Greg --- In WanderlodgeForum@yahoogroups.com, "shawn_fountain" <shawn_fountain@h...> wrote: > I drained my fresh water lines on my 35FC80 side bath using the knobs > at the rear bed compartment. I filled the tank halfway and tried the > sinks. I hear the pump running but no water is coming out. The > commercial hookup works fine. No water is leaking out anywhere. Does > the pump need to be primed? If so, how? > > Thanks, > SDF > 35FC80 |
08-29-2005, 05:59
If it is the sporlan valve for the tank fill, try cycling it a couple
times with the hose attached and on. This will sometimes clean the sediment out of the assembly and allow the valve to close. If not, you may have to take the valve apart and get the sediment out, or it could be time for a rebuild. BB sells the sporlan rebuild kit. It could also be that your pump won't self prime anymore. BB sells a new pump base for about 20 dollars. This is less likely than the sporlan problem. To help the pump prime, loosen the outflow water hose, have someone turn it on while holding the hose, remove the hose just slightly and when you get a shower put it back on and scream to have the pump shut off. Don't forget to tighten it down again. It'll be fine until you run out of water. Lastly, the set screw can come off the pump pulley, or the belt can come off of at the pump. Turn on the pump and make sure it's spinning the belt. Gary MIller 83 FC 33 - For Sale 'millercoachworks.com' Milwaukee area --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > Shawn, I had the same prob but it was the valve that changes the input > water from 'hookup pressure' to 'tank fill'. I dont know if you have > the same set up but the electric valve on my camper was holding open. > Does the pump keep running? > Greg > > --- In WanderlodgeForum@yahoogroups.com, "shawn_fountain" > <shawn_fountain@h...> wrote: > > I drained my fresh water lines on my 35FC80 side bath using the knobs > > at the rear bed compartment. I filled the tank halfway and tried the > > sinks. I hear the pump running but no water is coming out. The > > commercial hookup works fine. No water is leaking out anywhere. Does > > the pump need to be primed? If so, how? > > > > Thanks, > > SDF > > 35FC80 |
08-31-2005, 14:11
The pump does just keep running. I am not familiar at all with how things
work. This is my first rv. Thanks for you patience. I have separate inputs for the fill versus commercial water, so I assume no valve for switching. SDF ----Original Message Follows---- From: "Gregory OConnor" Reply-To: WanderlodgeForum@yahoogroups.com To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Re: Priming the Fresh Water Pump Date: Mon, 29 Aug 2005 13:22:23 -0000 Shawn, I had the same prob but it was the valve that changes the input water from 'hookup pressure' to 'tank fill'. I dont know if you have the same set up but the electric valve on my camper was holding open. Does the pump keep running? Greg --- In WanderlodgeForum@yahoogroups.com, "shawn_fountain" <shawn_fountain@h...> wrote: > I drained my fresh water lines on my 35FC80 side bath using the knobs > at the rear bed compartment. I filled the tank halfway and tried the > sinks. I hear the pump running but no water is coming out. The > commercial hookup works fine. No water is leaking out anywhere. Does > the pump need to be primed? If so, how? > > Thanks, > SDF > 35FC80 |
08-31-2005, 14:19
Thanks for the detailed response and your patience. I am new to rvs, this is
my first one. And I am learning to be more mechanical, but I am not there yet. I do not know what the sporlan valve is or how to cycle it. I will check to make sure the tank is filling and look for a valve btw the fill point and the tank. I will also try to loosen the outflow and then check the belt. Thanks for the input. SDF ----Original Message Follows---- From: "Gary Miller" Reply-To: WanderlodgeForum@yahoogroups.com To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Re: Priming the Fresh Water Pump Date: Mon, 29 Aug 2005 17:59:43 -0000 If it is the sporlan valve for the tank fill, try cycling it a couple times with the hose attached and on. This will sometimes clean the sediment out of the assembly and allow the valve to close. If not, you may have to take the valve apart and get the sediment out, or it could be time for a rebuild. BB sells the sporlan rebuild kit. It could also be that your pump won't self prime anymore. BB sells a new pump base for about 20 dollars. This is less likely than the sporlan problem. To help the pump prime, loosen the outflow water hose, have someone turn it on while holding the hose, remove the hose just slightly and when you get a shower put it back on and scream to have the pump shut off. Don't forget to tighten it down again. It'll be fine until you run out of water. Lastly, the set screw can come off the pump pulley, or the belt can come off of at the pump. Turn on the pump and make sure it's spinning the belt. Gary MIller 83 FC 33 - For Sale 'millercoachworks.com' Milwaukee area --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > Shawn, I had the same prob but it was the valve that changes the input > water from 'hookup pressure' to 'tank fill'. I dont know if you have > the same set up but the electric valve on my camper was holding open. > Does the pump keep running? > Greg > > --- In WanderlodgeForum@yahoogroups.com, "shawn_fountain" > <shawn_fountain@h...> wrote: > > I drained my fresh water lines on my 35FC80 side bath using the knobs > > at the rear bed compartment. I filled the tank halfway and tried the > > sinks. I hear the pump running but no water is coming out. The > > commercial hookup works fine. No water is leaking out anywhere. Does > > the pump need to be primed? If so, how? > > > > Thanks, > > SDF > > 35FC80 |
08-31-2005, 17:17
Shawn, The pump should have an arrow showing the direction of water
in and out. If you can, 1- remove the output hose. 2- losen the input side until it leaks. 3- retighten the input hose. and run the pump. result should be a burst of water. if not pump may be bad. if yes then 4. shut pump off and reattach output hose. 5.turn pump on and see if you have pressure at any valve. if yes than check if pump cycles off when you close all house valves. Remember to give the hotwater heater time to fill up. It took a long time to fill my hot water heater up so I shut the input to the heater off while I traced the problem with my pump system. If that doesnot work, the water must be cycling in a circular motion maybe back to the tank? Dont know Greg 94'pt40Romoland California --- In WanderlodgeForum@yahoogroups.com, "Shawn Fountain" <shawn_fountain@h...> wrote: > The pump does just keep running. I am not familiar at all with how things > work. This is my first rv. Thanks for you patience. I have separate inputs > for the fill versus commercial water, so I assume no valve for switching. > > SDF > > ----Original Message Follows---- > From: "Gregory OConnor" > Reply-To: WanderlodgeForum@yahoogroups.com > To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] Re: Priming the Fresh Water Pump > Date: Mon, 29 Aug 2005 13:22:23 -0000 > > Shawn, I had the same prob but it was the valve that changes the input > water from 'hookup pressure' to 'tank fill'. I dont know if you have > the same set up but the electric valve on my camper was holding open. > Does the pump keep running? > Greg > > --- In WanderlodgeForum@yahoogroups.com, "shawn_fountain" > <shawn_fountain@h...> wrote: > > I drained my fresh water lines on my 35FC80 side bath using the knobs > > at the rear bed compartment. I filled the tank halfway and tried the > > sinks. I hear the pump running but no water is coming out. The > > commercial hookup works fine. No water is leaking out anywhere. Does > > the pump need to be primed? If so, how? > > > > Thanks, > > SDF > > 35FC80 |
09-01-2005, 16:31
Shawn check out the "what is this" thread, Tom Warner has good advice
and is knowledgable on your type of house water system Greg --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > Shawn, The pump should have an arrow showing the direction of water > in and out. If you can, > 1- remove the output hose. > 2- losen the input side until it leaks. > 3- retighten the input hose. and run the pump. > result should be a burst of water. if not pump may be bad. if yes then > 4. shut pump off and reattach output hose. > 5.turn pump on and see if you have pressure at any valve. if yes than > check if pump cycles off when you close all house valves. Remember to > give the hotwater heater time to fill up. > It took a long time to fill my hot water heater up so I shut the > input to the heater off while I traced the problem with my pump > system. > If that doesnot work, the water must be cycling in a circular motion > maybe back to the tank? Dont know > Greg 94'pt40Romoland California > > --- In WanderlodgeForum@yahoogroups.com, "Shawn Fountain" > <shawn_fountain@h...> wrote: > > The pump does just keep running. I am not familiar at all with how > things > > work. This is my first rv. Thanks for you patience. I have > separate inputs > > for the fill versus commercial water, so I assume no valve for > switching. > > > > SDF > > > > ----Original Message Follows---- > > From: "Gregory OConnor" > > Reply-To: WanderlodgeForum@yahoogroups.com > > To: WanderlodgeForum@yahoogroups.com > > Subject: [WanderlodgeForum] Re: Priming the Fresh Water Pump > > Date: Mon, 29 Aug 2005 13:22:23 -0000 > > > > Shawn, I had the same prob but it was the valve that changes the > input > > water from 'hookup pressure' to 'tank fill'. I dont know if you have > > the same set up but the electric valve on my camper was holding > open. > > Does the pump keep running? > > Greg > > > > --- In WanderlodgeForum@yahoogroups.com, "shawn_fountain" > > <shawn_fountain@h...> wrote: > > > I drained my fresh water lines on my 35FC80 side bath using the > knobs > > > at the rear bed compartment. I filled the tank halfway and tried > the > > > sinks. I hear the pump running but no water is coming out. The > > > commercial hookup works fine. No water is leaking out anywhere. > Does > > > the pump need to be primed? If so, how? > > > > > > Thanks, > > > SDF > > > 35FC80 |
