no gas, no hot water
09-03-2005, 13:15
I have a 1983 fc-35, I bought after hearing so much about
wanderlodge. Seems like I have more things not working than i do working. I have several problems 1. No gas I gave narrowed it down to the sloenid valve, but can't get it to reset, it won't move at all. Any ideas.? 2. no hot water i have voltage to the junction box, but no amp draw, any one ever replace an heating element in one of these heaters> 3. someone said run two air intake lines out the front to get cool intake air and more volume.How? 4. Whats the larest on the backup camera? anyone got one fixed or replaced recently thanks for your help re brake |
09-03-2005, 14:09
--- Hang in there..experts will answer your questions and help you in
due course. You did right buying a bird over plastic..just takes a bit of time to de-bug it and then you will have one of the best coaches that everyone in the campground will envy!! regards, Hank Hannigan 90SP36 In WanderlodgeForum@yahoogroups.com, "putneyflash" > I have a 1983 fc-35, I bought after hearing so much about > wanderlodge. > Seems like I have more things not working than i do working. > I have several problems > 1. No gas I gave narrowed it down to the sloenid valve, but can't get > it to reset, it won't move at all. Any ideas.? > 2. no hot water i have voltage to the junction box, but no amp draw, > any one ever replace an heating element in one of these heaters> > 3. someone said run two air intake lines out the front to get cool > intake air and more volume.How? > 4. Whats the larest on the backup camera? anyone got one fixed or > replaced recently > > thanks for your help > re brake |
09-03-2005, 14:17
1. I assume you mean the solenoid behind the refrigerator that requires
12VDC to set. This solenoid is accessable from the outside access door. . Check, with a voltmeter there to see if there is 12VDC. If there is 12VDC there make sure that the LP is turned on in the outside valve near the LP tank. 2. You can get new heating elements at almost any RV dealers and they are easy to replace. 3. If your 83FC35 is as crowded as mine there is very little room to run an additional air scoop. I believe Mike Hohenstein ran one for his. 4. I rebuilt my backup camera and it works fine now. Do you have any idea which part is bad on yours, the camera or the TV portion. Can you get TV channels on your TV when the ignition is turned off? I would be glad to speak to you via phone about your problems as more then likely I have already been through the problems you are experiencing. Just send me your phone number off forum. tom 1982 FC35 Vernon Center,NY At 01:15 AM 9/4/2005 +0000, you wrote: >I have a 1983 fc-35, I bought after hearing so much about >wanderlodge. >Seems like I have more things not working than i do working. >I have several problems >1. No gas I gave narrowed it down to the sloenid valve, but can't get >it to reset, it won't move at all. Any ideas.? >2. no hot water i have voltage to the junction box, but no amp draw, >any one ever replace an heating element in one of these heaters> >3. someone said run two air intake lines out the front to get cool >intake air and more volume.How? >4. Whats the larest on the backup camera? anyone got one fixed or >replaced recently > >thanks for your help >re brake > > > > > > >SPONSORED LINKS ><http://groups.yahoo.com/gads?t=ms&k=Recr...;vehi\ cles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=\ Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzhn_\ ObWmSYTw>Recreational >vehicles ><http://groups.yahoo.com/gads?t=ms&k=Wand...w2=Wa\ nderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recre\ ational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLPj9U0JvqYQ>W\ anderlodge ><http://groups.yahoo.com/gads?t=ms&k=Auto...3;veh\ icles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5\ =Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pmy3\ 4cC1O9CxA>Automotive >maintenance ><http://groups.yahoo.com/gads?t=ms&k=Recr...tiona\ l+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deal\ er&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_Xahae\ YHfELr6o72IW1A>Recreational >vehicle dealer ><http://groups.yahoo.com/gads?t=ms&k=Used...ional\ +vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deale\ r&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km4L\ -kXbDI4ZSadEw>Used >recreational vehicles ><http://groups.yahoo.com/gads?t=ms&k=Auto...vehic\ les&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=U\ sed+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgTnM\ q_4GlXA>Automotive >radiators > > >---------- >YAHOO! GROUPS LINKS > > * Visit your group > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. > * > * To unsubscribe from this group, send an email to: > * > odgeForum-unsubscribe@yahoogroups.com > > * > * Your use of Yahoo! Groups is subject to the > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > >---------- |
09-04-2005, 03:37
Hello??
The solenoid is controlled by an LP sensor located near the booth or under the refrigerator. This supplies the 12 vdc to the solenoid valve that shuts off LP to all your LP systems. You should get a green LED when the button is pushed, and at times it may sound an alarm if it has not been actuated in some time. Also it can some times be cleared by blowing a short blast of air from the lungs into the hole next to the button to clear dust from the sensor. Hot water: Even though the 110 VAC breaker is on and you measure voltage coming out of the panel, that voltage goes to a relay located in a 4x4 electrical junction box, usually under the bed. This relay is a 12 vdc coil relay and is activated by a hot 12vdc presence on one side and the other side of the coil goes to a sensor located in the out side of the water heater and supplies a ground potential when water is present in the pipes. This ground wire does corrode up and break off from time to time. Point is, the relay has to be picked up to allow the 110VAC to pass through the contacts to the ECO and temp sensor then on to the heater coil. The above is the sequence of operation for that circuit, so next thing to do is locate the relay, then using am VOM check for 110VAC on the contacts of the relay, then follow it to the ECO then thermostat and finally the heater coil. This will tell you exactly where your missing the voltage. Once you get to the heater coil and you have voltage then you know the heating element needs replacing and that is not an easy chore in most cases. If you have an old water heater (original) now may be a good time to replace it with an Atwood EH-911, 11 gallon unit which will or should drop right in and some minor plumbing changes made and your set to go. Safe travels, Ralph and Charolette Fullenwider Ralph's RV Solutions, Duncan, Oklahoma http://home.swbell.net/rlf47/index.htm At 01:15 AM 9/4/2005 +0000, you wrote: >I have a 1983 fc-35, I bought after hearing so much about >wanderlodge. >Seems like I have more things not working than i do working. >I have several problems >1. No gas I gave narrowed it down to the sloenid valve, but can't get >it to reset, it won't move at all. Any ideas.? >2. no hot water i have voltage to the junction box, but no amp draw, >any one ever replace an heating element in one of these heaters> >3. someone said run two air intake lines out the front to get cool >intake air and more volume.How? >4. Whats the larest on the backup camera? anyone got one fixed or >replaced recently > >thanks for your help >re brake > > |
09-04-2005, 07:39
By now, you realize that you get a lot more responses when you
actually post your questions on the forum. Doesn't seem fair to complain until then. Since you have gotten several answers on the first three questions, I will comment on the backup camera. You didn't realy indicate what's wrong, so we'll start at ground zero. As Tom said, do you get a television picture on the monitor when the key is off, but the monitor is on? If so, then the monitor is functioning. If not, then it could be either the tuner section or the tube section, which may be repairable or not, but more probably time for a whole assembly change to new system. Based on the way you phrased your question, I'll assume that the monitor works on TV but not on the backup camera when the key is on. You can start debugging from the camera end or monitor end, but the best first step might be to make sure you have 12V power at the camera. If not, there's the first problem to fix. Once you have 12v at the camera, see if you have a picture upfront. If not take the output feed from the camera directly into the video input of a known good TV to double check the camera. You will need a twist lock coax connector (ethernet thin net?) to RCA converter plug for this connection. Switch the TV to video input and see if you get a picture. If not, bad camera. You can replace with virtually any 12v powered camera, B/w or color as you wish - the monitor upfront is a color TV. One caution on replacing the camera: if you get a very low light camera with auto iris, you could get "white flaring" when exposed to very bright sunlight. You then might need a polarizing filter to allow the auto iris to compensate for the bright sunlight. If you get a picture directly off the camera test, then you need to test the coax run from the camera and the tuner input section. At the front end, you can test the camera input to the tuner section in the overhead bay over the driver by unscrewing the coax connector from the camera in the back (that is on the upper right side of the tuner unit) and directly feeding in a feed from a camcorder. You will need a RCA to screw on coax converter plug. If you get a picture on the screen from the camcorder with the key on and the tuner on, then the tuner portion is OK. If not, then the coax input board on the tuner will need need repair. Again, this assumes that the TV monitor worked in the first step. If everything worked up to now, the it is narrowed down to a bad coax cable. At this point, you can test the coax run in two ways. You can hook the camcorder into the camera end of the coax or hook up the original camera again. Feed the coax end at the tuner into the video of the small TV you were testing the camera with. Hooking it back up to the known good monitor is also an option. With everything else working, it almost has to be a bad coax run. If you get a picture on this test, then there may have been some corrosion on the connectors that has now been cleaned off by the various testing. If not, then it is in fact the coax that is bad and needs to be replaced. Good luck Mike Bulriss 83 PT40 "Stagecoach" - For Sale 91 PT40 "Texas Minivan" - currently at Buckhorn Lake Resort in Kerrville, TX --- In WanderlodgeForum@yahoogroups.com, "putneyflash" > I have a 1983 fc-35, I bought after hearing so much about > wanderlodge. > Seems like I have more things not working than i do working. > I have several problems > 1. No gas I gave narrowed it down to the sloenid valve, but can't get > it to reset, it won't move at all. Any ideas.? > 2. no hot water i have voltage to the junction box, but no amp draw, > any one ever replace an heating element in one of these heaters> > 3. someone said run two air intake lines out the front to get cool > intake air and more volume.How? > 4. Whats the larest on the backup camera? anyone got one fixed or > replaced recently > > thanks for your help > re brake |
09-04-2005, 08:02
---MIKE:
I see you are a member of the two bird club. I have been there! No worry..all birds sell, just takes a bit of time. Someone will come along out of the blue and bam..it will be sold! Good luck. Hank 90SP36 sold 77FC33 after a bit of time also...thanks to TOM if reading this. In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@y...> wrote: > By now, you realize that you get a lot more responses when you > actually post your questions on the forum. Doesn't seem fair to > complain until then. > > Since you have gotten several answers on the first three questions, I > will comment on the backup camera. You didn't realy indicate what's > wrong, so we'll start at ground zero. As Tom said, do you get a > television picture on the monitor when the key is off, but the monitor > is on? If so, then the monitor is functioning. If not, then it could > be either the tuner section or the tube section, which may be > repairable or not, but more probably time for a whole assembly change > to new system. > > Based on the way you phrased your question, I'll assume that the > monitor works on TV but not on the backup camera when the key is on. > You can start debugging from the camera end or monitor end, but the > best first step might be to make sure you have 12V power at the > camera. If not, there's the first problem to fix. Once you have 12v > at the camera, see if you have a picture upfront. If not take the > output feed from the camera directly into the video input of a known > good TV to double check the camera. You will need a twist lock coax > connector (ethernet thin net?) to RCA converter plug for this > connection. Switch the TV to video input and see if you get a picture. > If not, bad camera. You can replace with virtually any 12v powered > camera, B/w or color as you wish - the monitor upfront is a color TV. > One caution on replacing the camera: if you get a very low light > camera with auto iris, you could get "white flaring" when exposed to > very bright sunlight. You then might need a polarizing filter to > allow the auto iris to compensate for the bright sunlight. > > If you get a picture directly off the camera test, then you need to > test the coax run from the camera and the tuner input section. At the > front end, you can test the camera input to the tuner section in the > overhead bay over the driver by unscrewing the coax connector from the > camera in the back (that is on the upper right side of the tuner unit) > and directly feeding in a feed from a camcorder. You will need a RCA > to screw on coax converter plug. If you get a picture on the screen > from the camcorder with the key on and the tuner on, then the tuner > portion is OK. If not, then the coax input board on the tuner will > need need repair. Again, this assumes that the TV monitor worked in > the first step. > > If everything worked up to now, the it is narrowed down to a bad coax > cable. At this point, you can test the coax run in two ways. You can > hook the camcorder into the camera end of the coax or hook up the > original camera again. Feed the coax end at the tuner into the video > of the small TV you were testing the camera with. Hooking it back up > to the known good monitor is also an option. With everything else > working, it almost has to be a bad coax run. If you get a picture on > this test, then there may have been some corrosion on the connectors > that has now been cleaned off by the various testing. If not, then it > is in fact the coax that is bad and needs to be replaced. > > Good luck > Mike Bulriss > 83 PT40 "Stagecoach" - For Sale > 91 PT40 "Texas Minivan" - currently at Buckhorn Lake Resort in > Kerrville, TX > > --- In WanderlodgeForum@yahoogroups.com, "putneyflash" > > > I have a 1983 fc-35, I bought after hearing so much about > > wanderlodge. > > Seems like I have more things not working than i do working. > > I have several problems > > 1. No gas I gave narrowed it down to the sloenid valve, but can't get > > it to reset, it won't move at all. Any ideas.? > > 2. no hot water i have voltage to the junction box, but no amp draw, > > any one ever replace an heating element in one of these heaters> > > 3. someone said run two air intake lines out the front to get cool > > intake air and more volume.How? > > 4. Whats the larest on the backup camera? anyone got one fixed or > > replaced recently > > > > thanks for your help > > re brake |
09-04-2005, 08:37
Hank,
Thanks for the encouragement on getting out of the Two Bird Club. I'm ready to let Guereasko become the new president of the club! I know you have seen Stagecoach and as someone else told me, the first person that comes and looks at Stagecoach, it will be gone. I just listed it about ten days ago on VintageBrds and I have had 4 calls on it from people that want to come and see it, so I expect it to be gone soon. By the way, you need to go to http://photos.yahoo.com/mbulriss where I have photos on Stagecoach and the new Bird. John Benham says our new one looks identical to your new SP. Check it out in the photos. When are we going to see you and Naty at another Lone Star Birds rally? There's one in October and December, hint, hint. Mike Bulriss 83 PT40 "Stagecoach" - For Sale 91 PT40 "Texas Minivan" - Looks like Hank's! at Buckhorn Lake Resort, Kerrville, TX --- In WanderlodgeForum@yahoogroups.com, "Henry Jay Hannigan" > ---MIKE: > I see you are a member of the two bird club. I have been there! No > worry..all birds sell, just takes a bit of time. Someone will come > along out of the blue and bam..it will be sold! Good luck. > Hank > 90SP36 > sold 77FC33 after a bit of time > also...thanks to TOM if reading this. > In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@y...> > wrote: > > By now, you realize that you get a lot more responses when you > > actually post your questions on the forum. Doesn't seem fair to > > complain until then. > > > > Since you have gotten several answers on the first three > questions, I > > will comment on the backup camera. You didn't realy indicate > what's > > wrong, so we'll start at ground zero. As Tom said, do you get a > > television picture on the monitor when the key is off, but the > monitor > > is on? If so, then the monitor is functioning. If not, then it > could > > be either the tuner section or the tube section, which may be > > repairable or not, but more probably time for a whole assembly > change > > to new system. > > > > Based on the way you phrased your question, I'll assume that the > > monitor works on TV but not on the backup camera when the key is > on. > > You can start debugging from the camera end or monitor end, but the > > best first step might be to make sure you have 12V power at the > > camera. If not, there's the first problem to fix. Once you have > 12v > > at the camera, see if you have a picture upfront. If not take the > > output feed from the camera directly into the video input of a > known > > good TV to double check the camera. You will need a twist lock > coax > > connector (ethernet thin net?) to RCA converter plug for this > > connection. Switch the TV to video input and see if you get a > picture. > > If not, bad camera. You can replace with virtually any 12v > powered > > camera, B/w or color as you wish - the monitor upfront is a color > TV. > > One caution on replacing the camera: if you get a very low light > > camera with auto iris, you could get "white flaring" when exposed > to > > very bright sunlight. You then might need a polarizing filter to > > allow the auto iris to compensate for the bright sunlight. > > > > If you get a picture directly off the camera test, then you need to > > test the coax run from the camera and the tuner input section. At > the > > front end, you can test the camera input to the tuner section in > the > > overhead bay over the driver by unscrewing the coax connector from > the > > camera in the back (that is on the upper right side of the tuner > unit) > > and directly feeding in a feed from a camcorder. You will need a > RCA > > to screw on coax converter plug. If you get a picture on the > screen > > from the camcorder with the key on and the tuner on, then the tuner > > portion is OK. If not, then the coax input board on the tuner will > > need need repair. Again, this assumes that the TV monitor worked > in > > the first step. > > > > If everything worked up to now, the it is narrowed down to a bad > coax > > cable. At this point, you can test the coax run in two ways. You > can > > hook the camcorder into the camera end of the coax or hook up the > > original camera again. Feed the coax end at the tuner into the > video > > of the small TV you were testing the camera with. Hooking it back > up > > to the known good monitor is also an option. With everything else > > working, it almost has to be a bad coax run. If you get a > picture on > > this test, then there may have been some corrosion on the > connectors > > that has now been cleaned off by the various testing. If not, > then it > > is in fact the coax that is bad and needs to be replaced. > > > > Good luck > > Mike Bulriss > > 83 PT40 "Stagecoach" - For Sale > > 91 PT40 "Texas Minivan" - currently at Buckhorn Lake Resort in > > Kerrville, TX > > > > --- In WanderlodgeForum@yahoogroups.com, "putneyflash" > > > > > I have a 1983 fc-35, I bought after hearing so much about > > > wanderlodge. > > > Seems like I have more things not working than i do working. > > > I have several problems > > > 1. No gas I gave narrowed it down to the sloenid valve, but > can't get > > > it to reset, it won't move at all. Any ideas.? > > > 2. no hot water i have voltage to the junction box, but no amp > draw, > > > any one ever replace an heating element in one of these heaters> > > > 3. someone said run two air intake lines out the front to get > cool > > > intake air and more volume.How? > > > 4. Whats the larest on the backup camera? anyone got one fixed > or > > > replaced recently > > > > > > thanks for your help > > > re brake |
09-04-2005, 08:47
FYI, there is a bunch of information on 3208 topics in the Files
section of the WandelodgeForum that may be of use to you. There is one on increasing airflow on a 3208 that you might get some hints for your airflow question. Mike Bulriss 83 PT40 "Stagecoach" - For Sale 91 PT40 "Texas Minivan" on the road in Texas --- In WanderlodgeForum@yahoogroups.com, "putneyflash" > I have a 1983 fc-35, I bought after hearing so much about > wanderlodge. > Seems like I have more things not working than i do working. > I have several problems > 1. No gas I gave narrowed it down to the sloenid valve, but can't get > it to reset, it won't move at all. Any ideas.? > 2. no hot water i have voltage to the junction box, but no amp draw, > any one ever replace an heating element in one of these heaters> > 3. someone said run two air intake lines out the front to get cool > intake air and more volume.How? > 4. Whats the larest on the backup camera? anyone got one fixed or > replaced recently > > thanks for your help > re brake |
09-04-2005, 09:08
---MIKE:
Your new coach looks 100times better than mine. I love that dining couch, always wanted one like that. Yea, John Benham was too kind about my coach, yours really looks great! I was also impressed looking at your old coach. You are right, as soon as someone visits it, they will buy it!! Sorry about the Texas rally as we will be gone over yonder by October & December..We really enjoyed the last Texas rally we attended near Padre Island a few years ago. Heck, I'm part Texan as I graduated from UT Austin years ago!!! Naty says hello to all the Texans. She said something about everything being big in Texas. Oh well good luck on the BIRDS. They both look great. regards, Hank 90SP36 In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@y...> wrote: > Hank, > > Thanks for the encouragement on getting out of the Two Bird Club. I'm > ready to let Guereasko become the new president of the club! > > I know you have seen Stagecoach and as someone else told me, the first > person that comes and looks at Stagecoach, it will be gone. I just > listed it about ten days ago on VintageBrds and I have had 4 calls on > it from people that want to come and see it, so I expect it to be gone > soon. > > By the way, you need to go to http://photos.yahoo.com/mbulriss where I > have photos on Stagecoach and the new Bird. John Benham says our new > one looks identical to your new SP. Check it out in the photos. > > When are we going to see you and Naty at another Lone Star Birds > rally? There's one in October and December, hint, hint. > > > Mike Bulriss > 83 PT40 "Stagecoach" - For Sale > 91 PT40 "Texas Minivan" - Looks like Hank's! > at Buckhorn Lake Resort, Kerrville, TX > > > > > --- In WanderlodgeForum@yahoogroups.com, "Henry Jay Hannigan" > > > ---MIKE: > > I see you are a member of the two bird club. I have been there! No > > worry..all birds sell, just takes a bit of time. Someone will come > > along out of the blue and bam..it will be sold! Good luck. > > Hank > > 90SP36 > > sold 77FC33 after a bit of time > > also...thanks to TOM if reading this. > > In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@y...> > > wrote: > > > By now, you realize that you get a lot more responses when you > > > actually post your questions on the forum. Doesn't seem fair to > > > complain until then. > > > > > > Since you have gotten several answers on the first three > > questions, I > > > will comment on the backup camera. You didn't realy indicate > > what's > > > wrong, so we'll start at ground zero. As Tom said, do you get a > > > television picture on the monitor when the key is off, but the > > monitor > > > is on? If so, then the monitor is functioning. If not, then it > > could > > > be either the tuner section or the tube section, which may be > > > repairable or not, but more probably time for a whole assembly > > change > > > to new system. > > > > > > Based on the way you phrased your question, I'll assume that the > > > monitor works on TV but not on the backup camera when the key is > > on. > > > You can start debugging from the camera end or monitor end, but the > > > best first step might be to make sure you have 12V power at the > > > camera. If not, there's the first problem to fix. Once you have > > 12v > > > at the camera, see if you have a picture upfront. If not take the > > > output feed from the camera directly into the video input of a > > known > > > good TV to double check the camera. You will need a twist lock > > coax > > > connector (ethernet thin net?) to RCA converter plug for this > > > connection. Switch the TV to video input and see if you get a > > picture. > > > If not, bad camera. You can replace with virtually any 12v > > powered > > > camera, B/w or color as you wish - the monitor upfront is a color > > TV. > > > One caution on replacing the camera: if you get a very low light > > > camera with auto iris, you could get "white flaring" when exposed > > to > > > very bright sunlight. You then might need a polarizing filter to > > > allow the auto iris to compensate for the bright sunlight. > > > > > > If you get a picture directly off the camera test, then you need to > > > test the coax run from the camera and the tuner input section. At > > the > > > front end, you can test the camera input to the tuner section in > > the > > > overhead bay over the driver by unscrewing the coax connector from > > the > > > camera in the back (that is on the upper right side of the tuner > > unit) > > > and directly feeding in a feed from a camcorder. You will need a > > RCA > > > to screw on coax converter plug. If you get a picture on the > > screen > > > from the camcorder with the key on and the tuner on, then the tuner > > > portion is OK. If not, then the coax input board on the tuner will > > > need need repair. Again, this assumes that the TV monitor worked > > in > > > the first step. > > > > > > If everything worked up to now, the it is narrowed down to a bad > > coax > > > cable. At this point, you can test the coax run in two ways. You > > can > > > hook the camcorder into the camera end of the coax or hook up the > > > original camera again. Feed the coax end at the tuner into the > > video > > > of the small TV you were testing the camera with. Hooking it back > > up > > > to the known good monitor is also an option. With everything else > > > working, it almost has to be a bad coax run. If you get a > > picture on > > > this test, then there may have been some corrosion on the > > connectors > > > that has now been cleaned off by the various testing. If not, > > then it > > > is in fact the coax that is bad and needs to be replaced. > > > > > > Good luck > > > Mike Bulriss > > > 83 PT40 "Stagecoach" - For Sale > > > 91 PT40 "Texas Minivan" - currently at Buckhorn Lake Resort in > > > Kerrville, TX > > > > > > --- In WanderlodgeForum@yahoogroups.com, "putneyflash" > > > > > > > I have a 1983 fc-35, I bought after hearing so much about > > > > wanderlodge. > > > > Seems like I have more things not working than i do working. > > > > I have several problems > > > > 1. No gas I gave narrowed it down to the sloenid valve, but > > can't get > > > > it to reset, it won't move at all. Any ideas.? > > > > 2. no hot water i have voltage to the junction box, but no amp > > draw, > > > > any one ever replace an heating element in one of these heaters> > > > > 3. someone said run two air intake lines out the front to get > > cool > > > > intake air and more volume.How? > > > > 4. Whats the larest on the backup camera? anyone got one fixed > > or > > > > replaced recently > > > > > > > > thanks for your help > > > > re brake |
09-04-2005, 13:23
Not sure if it has been said before, but for hot water heater check red
switch at the end of the bed, it must be on. For the additional air intake check file section for modification pictures. Thanks Bruce Campbell Clearwater, FL 83'FC 35 SB "Blue Skies" --- In WanderlodgeForum@yahoogroups.com, "putneyflash" > I have a 1983 fc-35, I bought after hearing so much about > wanderlodge. > Seems like I have more things not working than i do working. > I have several problems > 1. No gas I gave narrowed it down to the sloenid valve, but can't get > it to reset, it won't move at all. Any ideas.? > 2. no hot water i have voltage to the junction box, but no amp draw, > any one ever replace an heating element in one of these heaters> > 3. someone said run two air intake lines out the front to get cool > intake air and more volume.How? > 4. Whats the larest on the backup camera? anyone got one fixed or > replaced recently > > thanks for your help > re brake |
