Perkins Generator Starter wiring
09-04-2005, 13:13
I have My 83 bird with my generator starter replaced but they forgot
where the wire are to be connected. It is a perkins 12.5 KW Deisel. I was able to get it started by connecting the wires the way I thought they should go. But the generator stopped and would not start again. I need to know the connections of the control wires, if someone can help it would be appreciated. Thankyou in advance Larry cell 914 227-4520 |
09-04-2005, 15:42
I havent got the drawings here for the generator but from what you told me
during our telephone conversation it appears that you have it connected correctly since you started and stopped the generator more then once. I would check the reset button on the control box and then try and start it. Send me the color code of the wires that connect your starter solenoid and where each is connected and I will check it against mine. tom Warner 1982 FC35 Vernon Center,NY At 01:13 AM 9/5/2005 +0000, you wrote: >I have My 83 bird with my generator starter replaced but they forgot >where the wire are to be connected. > >It is a perkins 12.5 KW Deisel. I was able to get it started by >connecting the wires the way I thought they should go. But the >generator stopped and would not start again. I need to know the >connections of the control wires, if someone can help it would be >appreciated. > >Thankyou in advance > >Larry >cell 914 227-4520 > > > > > > >SPONSORED LINKS ><http://groups.yahoo.com/gads?t=ms&k=Recr...;vehi\ cles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=\ Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzhn_\ ObWmSYTw>Recreational >vehicles ><http://groups.yahoo.com/gads?t=ms&k=Wand...w2=Wa\ nderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recre\ ational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLPj9U0JvqYQ>W\ anderlodge ><http://groups.yahoo.com/gads?t=ms&k=Auto...3;veh\ icles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5\ =Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pmy3\ 4cC1O9CxA>Automotive >maintenance ><http://groups.yahoo.com/gads?t=ms&k=Recr...tiona\ l+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deal\ er&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_Xahae\ YHfELr6o72IW1A>Recreational >vehicle dealer ><http://groups.yahoo.com/gads?t=ms&k=Used...ional\ +vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deale\ r&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km4L\ -kXbDI4ZSadEw>Used >recreational vehicles ><http://groups.yahoo.com/gads?t=ms&k=Auto...vehic\ les&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=U\ sed+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgTnM\ q_4GlXA>Automotive >radiators > > >---------- >YAHOO! GROUPS LINKS > > * Visit your group > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. > * > * To unsubscribe from this group, send an email to: > * > odgeForum-unsubscribe@yahoogroups.com > > * > * Your use of Yahoo! Groups is subject to the > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > >---------- |
09-05-2005, 01:59
Larry, I forewarded ur message to George. His phone is 478-956-2908., and e-mail
is dog2005@... Eric "Albert L (Larry) Brehmer" I have My 83 bird with my generator starter replaced but they forgot where the wire are to be connected. It is a perkins 12.5 KW Deisel. I was able to get it started by connecting the wires the way I thought they should go. But the generator stopped and would not start again. I need to know the connections of the control wires, if someone can help it would be appreciated. Thankyou in advance Larry cell 914 227-4520 SPONSORED LINKS Recreational vehicles Wanderlodge Automotive maintenance Recreational vehicle dealer Used recreational vehicles Automotive radiators --------------------------------- YAHOO! GROUPS LINKS Visit your group "WanderlodgeForum" on the web. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. --------------------------------- --------------------------------- Click here to donate to the Hurricane Katrina relief effort. [Non-text portions of this message have been removed] |
09-05-2005, 02:28
Larry:
I have the wiring schmatics for several of the models of Perkins/Kohler. Need to know which model that you have. That information is on a data plate on the slant bracket behind the engine to the Kohler. It should be a CCOP or CCOPY with a modification number following like CCOPY-67. Let me know which it is and I can copy the correct schematic and send it to via e-mail as a .jpeg for you to print out. This will show you point to point wiring. Safe travels, Ralph and Charolette Fullenwider Ralph's RV Solutions, Duncan, Oklahoma http://home.swbell.net/rlf47/index.htm At 01:13 AM 9/5/2005 +0000, you wrote: >I have My 83 bird with my generator starter replaced but they forgot >where the wire are to be connected. > >It is a perkins 12.5 KW Deisel. I was able to get it started by >connecting the wires the way I thought they should go. But the >generator stopped and would not start again. I need to know the >connections of the control wires, if someone can help it would be >appreciated. > >Thankyou in advance > >Larry >cell 914 227-4520 > > > > |
09-05-2005, 03:15
I would check the fuel shut off electric valve if any? If you wired
it up ok the first time and it started ;just clean the wires and check for damage and ground outs in those wires. If it turns over strong and does not start I think it is fuel shut off; hot wire the fuel shutoff from the battery and try to start it. Or hotwire the fuelshutoff from a Portable battery jumper by grounding the neg. to the block and running the hot to the Fuelshutoff If it has a full amp battery and turns over slow, could be the new/rebuilt starter is no good. remove the starter and have it load tested at Pepboys. more info-- Fuel shut off if electric takes high power to open but little to keep open, when you turn the on button you may hear the fuleshutoff click open. when the starter is activated some times the fuelshut off is robbed of power and closes due to weak wires , battry or poor connections. when you stack wires on a post both sides of the wires must be clean I use a razor blade and sand paper Greg O'Connor pt40 Romoland California --- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" > Larry: > > I have the wiring schmatics for several of the models of Perkins/Kohler. > Need to know which model that you have. That information is on a data plate > on the slant bracket behind the engine to the Kohler. It should be a CCOP > or CCOPY with a modification number following like CCOPY-67. Let me know > which it is and I can copy the correct schematic and send it to via > as a .jpeg for you to print out. This will show you point to point wiring. > > Safe travels, > > Ralph and Charolette Fullenwider > Ralph's RV Solutions, Duncan, Oklahoma > http://home.swbell.net/rlf47/index.htm > > At 01:13 AM 9/5/2005 +0000, you wrote: > >I have My 83 bird with my generator starter replaced but they forgot > >where the wire are to be connected. > > > >It is a perkins 12.5 KW Deisel. I was able to get it started by > >connecting the wires the way I thought they should go. But the > >generator stopped and would not start again. I need to know the > >connections of the control wires, if someone can help it would be > >appreciated. > > > >Thankyou in advance > > > >Larry > >cell 914 227-4520 > > > > > > > > |
