Low air buzzer stays on
09-06-2005, 06:44
After I air up the the low air light and buzzer stays on. I drove it
home(40 miles) and the buzzer and light never went off. Any help would be appreciated. We have a 86PT38. Many Thanks, Rick Mcintire 86PT38 Patillo,Tx |
09-06-2005, 07:31
Rick,
On my 81 there is a switch at the auxilliary tank with one wire that got corroded after years of use and when replaced fixed the problem. It was located right at the outlet for the tank and was an easy repair about $10.00 for the switch. Be sure the air is out of the tank before trying to replace. Thaks for keeeping us up-dated on Stephen and Patty. Chet Geist 1981 FC33, Austin, Texas -----Original Message----- From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com]On Behalf Of ricmcintire Sent: Tuesday, September 06, 2005 1:45 PM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Low air buzzer stays on After I air up the the low air light and buzzer stays on. I drove it home(40 miles) and the buzzer and light never went off. Any help would be appreciated. We have a 86PT38. Many Thanks, Rick Mcintire 86PT38 Patillo,Tx SPONSORED LINKS Recreational vehicles Wanderlodge Automotive maintenance Recreational vehicle dealer Used recreational vehicles Automotive radiators ---------------------------------------------------------------------------- -- YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ---------------------------------------------------------------------------- -- [Non-text portions of this message have been removed] |
09-06-2005, 07:43
What do the front and rear air gauges indicate?
tom 1982 FC35 Vernon Center,NY At 06:44 PM 9/6/2005 +0000, you wrote: >After I air up the the low air light and buzzer stays on. I drove it >home(40 miles) and the buzzer and light never went off. Any help would >be appreciated. We have a 86PT38. >Many Thanks, >Rick Mcintire >86PT38 Patillo,Tx |
09-06-2005, 07:53
-Chet, Thank you for the info. I will check it out tonight. Buzzer
drove me crazy on the home Saturday night. Thanks, Rick Mcintire 86PT38 Patillo,TX Fulling timing on the ranch -- In WanderlodgeForum@yahoogroups.com, "Chet Geist" wrote: > Rick, > > On my 81 there is a switch at the auxilliary tank with one wire that got > corroded after years of use and when replaced fixed the problem. It was > located right at the outlet for the tank and was an easy repair about $10.00 > for the switch. Be sure the air is out of the tank before trying to > replace. Thaks for keeeping us up-dated on Stephen and Patty. > > Chet Geist > 1981 FC33, Austin, Texas > -----Original Message----- > From: WanderlodgeForum@yahoogroups.com > [mailto:WanderlodgeForum@yahoogroups.com]On Behalf Of ricmcintire > Sent: Tuesday, September 06, 2005 1:45 PM > To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] Low air buzzer stays on > > > After I air up the the low air light and buzzer stays on. I drove it > home(40 miles) and the buzzer and light never went off. Any help would > be appreciated. We have a 86PT38. > Many Thanks, > Rick Mcintire > 86PT38 Patillo,Tx > > > > > SPONSORED LINKS Recreational vehicles Wanderlodge Automotive maintenance > Recreational vehicle dealer Used recreational vehicles Automotive > radiators > > > ------------------------------------------------------------------- --------- > -- > YAHOO! GROUPS LINKS > > a.. Visit your group "WanderlodgeForum" on the web. > > b.. To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of > Service. > > > ------------------------------------------------------------------- --------- > -- > > > > [Non-text portions of this message have been removed] |
09-06-2005, 08:19
Hi Rick,
Our prior 86PT40 was wired so that the low air light and buzzer also "lit and buzzed" when a jack was not fully retracted (or when a jack switch was defective). Don't want to send you down the wrong trail but it might not be too hard to start the engine, examine the dash air gauge, drop a jack or two, and see if any additional buzzers and/or lights become lit. Also, if I recall correctly, the annoying buzzer control breaker was located in the #1 position (top left) of the inside front panel just ahead of the passenger seat where it can be pulled temporarily so as not to drive you nuts while you drive; the buzzer will stop and the dash light will remain on. John Suter --- ricmcintire > After I air up the the low air light and buzzer > stays on. I drove it > home(40 miles) and the buzzer and light never went > off. Any help would > be appreciated. We have a 86PT38. > Many Thanks, > Rick Mcintire > 86PT38 Patillo,Tx > > > __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com |
09-06-2005, 08:25
Rick:
There are a couple of switches that mount on the front axle and the tag axle that activate the light and buzzer. I had the same problem the other day, but it straightened itself out. Call Ralph and he can tell you exactly what to look for. You might just have some dust in this switch. R.E. (Ron) Marabito, Dallas, TX 92WB40 Moderator --- In WanderlodgeForum@yahoogroups.com, "ricmcintire" > After I air up the the low air light and buzzer stays on. I drove it > home(40 miles) and the buzzer and light never went off. Any help would > be appreciated. We have a 86PT38. > Many Thanks, > Rick Mcintire > 86PT38 Patillo,Tx |
09-06-2005, 09:39
-Tom, The main air gauge shows 120 psi and the tag shows about 70 to
75 psi. Thanks for any help Rick Mcintire -- In WanderlodgeForum@yahoogroups.com, Tom Warner wrote: > What do the front and rear air gauges indicate? > > tom > 1982 FC35 > Vernon Center,NY > > At 06:44 PM 9/6/2005 +0000, you wrote: > >After I air up the the low air light and buzzer stays on. I drove it > >home(40 miles) and the buzzer and light never went off. Any help would > >be appreciated. We have a 86PT38. > >Many Thanks, > >Rick Mcintire > >86PT38 Patillo,Tx |
09-06-2005, 09:41
Ron, Thanks for the info. I will check those switches. I do get a lot dust out in the country. Tried to call Ralph and no answer, will try tonight. Rick Mcintire 86PT38 Patillo,Tx. -- In WanderlodgeForum@yahoogroups.com, "ronmarabito2002" > Rick: > > There are a couple of switches that mount on the front axle and > the tag axle that activate the light and buzzer. I had the same > problem the other day, but it straightened itself out. Call Ralph and > he can tell you exactly what to look for. You might just have some > dust in this switch. > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > Moderator > > > --- In WanderlodgeForum@yahoogroups.com, "ricmcintire" > > > After I air up the the low air light and buzzer stays on. I drove it > > home(40 miles) and the buzzer and light never went off. Any help > would > > be appreciated. We have a 86PT38. > > Many Thanks, > > Rick Mcintire > > 86PT38 Patillo,Tx |
09-06-2005, 09:42
How about the front gauge air pressure Rick?
tom At 09:39 PM 9/6/2005 +0000, you wrote: >-Tom, The main air gauge shows 120 psi and the tag shows about 70 to >75 psi. >Thanks for any help >Rick Mcintire > > > >-- In WanderlodgeForum@yahoogroups.com, Tom Warner >wrote: > > What do the front and rear air gauges indicate? > > > > tom > > 1982 FC35 > > Vernon Center,NY > > > > At 06:44 PM 9/6/2005 +0000, you wrote: > > >After I air up the the low air light and buzzer stays on. I drove it > > >home(40 miles) and the buzzer and light never went off. Any help >would > > >be appreciated. We have a 86PT38. > > >Many Thanks, > > >Rick Mcintire > > >86PT38 Patillo,Tx > > > > > >SPONSORED LINKS ><http://groups.yahoo.com/gads?t=ms&k=Recr...;vehi\ cles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=\ Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzhn_\ ObWmSYTw>Recreational >vehicles ><http://groups.yahoo.com/gads?t=ms&k=Wand...w2=Wa\ nderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recre\ ational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLPj9U0JvqYQ>W\ anderlodge ><http://groups.yahoo.com/gads?t=ms&k=Auto...3;veh\ icles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5\ =Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pmy3\ 4cC1O9CxA>Automotive >maintenance ><http://groups.yahoo.com/gads?t=ms&k=Recr...tiona\ l+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deal\ er&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_Xahae\ YHfELr6o72IW1A>Recreational >vehicle dealer ><http://groups.yahoo.com/gads?t=ms&k=Used...ional\ +vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deale\ r&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km4L\ -kXbDI4ZSadEw>Used >recreational vehicles ><http://groups.yahoo.com/gads?t=ms&k=Auto...vehic\ les&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=U\ sed+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgTnM\ q_4GlXA>Automotive >radiators > > >---------- >YAHOO! GROUPS LINKS > > * Visit your group > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. > * > * To unsubscribe from this group, send an email to: > * > odgeForum-unsubscribe@yahoogroups.com > > * > * Your use of Yahoo! Groups is subject to the > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > >---------- |
09-06-2005, 14:05
If u are unable to get your answer from one of these guys, give a call to Bennie
Collier at BB. He will have the answer for you. His # is 800-992-6337 ricmcintire and buzzer stays on. I drove it home(40 miles) and the buzzer and light never went off. Any help would be appreciated. We have a 86PT38. Many Thanks, Rick Mcintire 86PT38 Patillo,Tx SPONSORED LINKS Recreational vehicles Wanderlodge Automotive maintenance Recreational vehicle dealer Used recreational vehicles Automotive radiators --------------------------------- YAHOO! GROUPS LINKS Visit your group "WanderlodgeForum" on the web. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. --------------------------------- __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com [Non-text portions of this message have been removed] |
