Powertech Generator Owner's Manual
02-28-2013, 16:59
PTSMH-15
PTSMH-17.5
PTSMH-20
.pdf  PowertechManual.pdf (Size: 5.2 MB / Downloads: 1569)
03-01-2013, 16:29
RE: Powertech Generator Owner's Manual
This is the newer version of the manual-and much better- It was changed after Bluebirds first 20+ failed generator moves. Changed installation requirements to 2 fans , each with 465 cfm capacity. Also interestingly ,more clearly dictates sizes, measurements and refers to ambient air high temp shutdown switch which was removed. The original manual suggested the minimal requirement of 500 cfm through the enclosure. Because no engineering was done, Bluebird used a 500 cfm rated fan and then pushed/sucked the air though 30+ feet of 6 inch ducts and elbows. Obviously that failed.
The move did succeed in moving 500 pounds from the right front to the left rear.Angel
Ross
2006 450 LXi
(03-01-2013 13:14)Bird Owner Wrote:  Thanks, David. I downloaded a copy for my file, didn't have one.
Getting near 100% digital for the M450. Backed up to Carbonite so accessable from iPad or notebook from anywhere. Hard copies of all will soon be able to stay home.
