Check engine light
09-19-2005, 03:33
Check engine light
I have a 1988 BB wbwl with 8v92 DDEC while riding along at 62- 65 mph
1700rpm my check engine light stop engine lights come on along with buzzer. All guages are in operating order and are in their normal ranges. Sometimes when I turn on the aux fan the light and buzzer go off. recently the coach decides that it needs a break and forces me to stop (engine stopping) momentarly turn key off wait not more than five minutes the start the coach and drive off. On a 265 mile trip this happen two to three times...... Any Ideas?? Jim RIordan |
09-19-2005, 05:55
Check engine light
Check the oil pressure sending unit just to the left of your a/c
compressore. See if the wire is shorting out or the unit is damaged. I had one that had been cut by a loose a/c belt and allowed water to get in to the top and short the unit. Have you checked your engine flash codes? Do that by pressing the check engine button and record the flashes, then get back on line and tell us what you see. I can then give you a better diagnosis. By the way, you do not have to have the coach out to get this information. It is stored there until cleared by a Detroit technician with a reader/programmer. R.E. (Ron) Marabito, Dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, "jqrjr" > I have a 1988 BB wbwl with 8v92 DDEC while riding along at 62- 65 mph > 1700rpm my check engine light stop engine lights come on along with > buzzer. All guages are in operating order and are in their normal > ranges. Sometimes when I turn on the aux fan the light and buzzer go > off. recently the coach decides that it needs a break and forces me to > stop (engine stopping) momentarly turn key off wait not more than five > minutes the start the coach and drive off. On a 265 mile trip this > happen two to three times...... > > Any Ideas?? > > > Jim RIordan |
09-19-2005, 11:25
Check engine light
Jim, Welcome to the loose connection club. We have the same coach and it was
doing the same thing. We even called the Detroit dealer out on a weekend to see what was going on and when he got there I fired the 8V up and ran great. When I got back home I had my detroit dealer look at it and they had to get out the old diagnostic equipment to find that I had a loose connection on one bank. They cleaned and made sure everything was tight and we have not had any further problem. I have alway had the check engine light come on going down hills but as soon as I touch the fuel pedal it goes out. It does not leave a code and the dealer thinks that this is a problem with the light system itself rather that the engine. Hope this helps.... Bryan Altier 88 WB 40 "Xanadu" Greenville, SC ----- Original Message ----- From: jqrjr To: WanderlodgeForum@yahoogroups.com Sent: Monday, September 19, 2005 11:33 AM Subject: [WanderlodgeForum] Check engine light I have a 1988 BB wbwl with 8v92 DDEC while riding along at 62- 65 mph 1700rpm my check engine light stop engine lights come on along with buzzer. All guages are in operating order and are in their normal ranges. Sometimes when I turn on the aux fan the light and buzzer go off. recently the coach decides that it needs a break and forces me to stop (engine stopping) momentarly turn key off wait not more than five minutes the start the coach and drive off. On a 265 mile trip this happen two to three times...... Any Ideas?? Jim RIordan ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] |
09-19-2005, 16:46
Check engine light
The check engine light is usualy triggered by a minor event. Multiple
minor events create major problems. Even if it is just a sensor error, repair or replace the sensor because you will not know if a "Check engine signal" is additional trouble. Like mass air restriction could make the fuel smoke and carbon out the sump oil. I paid $35.00 to have codes read on a Truck just today, The tec was able to pinpoint the reason and solution, money well spent. I wish the code reader was onboard like my newer diesel skidsteer tractors. with fuel as it is maybe a mobile mechanic is a cheaper route. be sure they have the proper reader for your engine ser# Greg O'Connor 94pt40 --- In WanderlodgeForum@yahoogroups.com, "jqrjr" > I have a 1988 BB wbwl with 8v92 DDEC while riding along at 62- 65 mph > 1700rpm my check engine light stop engine lights come on along with > buzzer. All guages are in operating order and are in their normal > ranges. Sometimes when I turn on the aux fan the light and buzzer go > off. recently the coach decides that it needs a break and forces me to > stop (engine stopping) momentarly turn key off wait not more than five > minutes the start the coach and drive off. On a 265 mile trip this > happen two to three times...... > > Any Ideas?? > > > Jim RIordan |
09-19-2005, 20:14
Check engine light
was the light system a bluebird addition- or detroit? I was led to believe
that bluebird added it. ernie-83pt40 in montana [Non-text portions of this message have been removed] |
09-19-2005, 21:36
Check engine light
Since purchase my PT38, I've gone back and read all the past posts. I have
kept tips on different topics. Here is what I have read concerning the Check Engine Light: BTW, are the 50,000 posts accessible yet. I haven't been able to access them. Steve Harrie, St. George, UT "I also have a 1988 pt40 with the check engine light that comes on when I pull a long hill, this has been constant for four years, The code say low coolant when the tank is full. I have been into William Detroit in Georgia and Phoenix, Detroit diesel shops in North Dakota, Kansas, Missouri, Michigan, and more. The suggestions and cures have ranged from poor ground, bad injectors, bad sender, to duck tape over the lite. I now believe it must be a fault in the computer or wiring or other magical places. But, if other 88 pt40 owners have the same problem it probably is a manufacturing flaw. If anyone finds a cure please post it. 2) I also have a 88 PT40 WB with the exact symptoms, must be a manufactured problem. 3) My 1988 PT40 does the same." [Non-text portions of this message have been removed] |
12-31-2006, 08:24
Check engine light
Steve- as usual, I don't have a clue what your fix might be, but glad to
hear from you. Happy New Year Ernie Ekberg and Brenda 83PT40 Weatherford, tx [Non-text portions of this message have been removed] |
12-31-2006, 13:03
Check engine light
1991 8V92 DDEC II. "Check engine" light does not go out after 5 seconds
when ignition turned on ... tachometer inoperative. Engine runs fine but speed restricted to 37 mph (computer I assume). Problem is intermittent. After coach sits a few hours when the ignition switch is turned on both the "stop engine" & "check engine" lights will go out (normal sequence) & tach works & engine operation & speed are normal. Then when switched off & re-started only the "check engine" light comes on constantly ... "stop engine" light never comes on ... tach inop ... speed restricted. I am suspect of a ground problem but don't have a clue where to start the search. I'm also suspect of the DDEC II unit but want it to be something much more simple ($$$$). All fluids normal, no noises, leaks, or performance issues when "check engine" light is off ... but as you can imagine ... 37 mph is very restrictive for most travels. Steve & Kathy Enfinger '91 WBSA PT40 |
12-31-2006, 14:07
Check engine light
Wild guess: Is it cold and or wet at your location? Perhaps a
sensor on the Allison and or 8V92 needs cleaned/dried, and then di- electric protected? Dan 94 BMC 37' --- In WanderlodgeForum@yahoogroups.com, "Steve & Kathy Enfinger" > > 1991 8V92 DDEC II. "Check engine" light does not go out after 5 seconds > when ignition turned on ... tachometer inoperative. Engine runs fine > but speed restricted to 37 mph (computer I assume). Problem is > intermittent. After coach sits a few hours when the ignition switch is > turned on both the "stop engine" & "check engine" lights will go out > (normal sequence) & tach works & engine operation & speed are normal. > Then when switched off & re-started only the "check engine" light comes > on constantly ... "stop engine" light never comes on ... tach inop ... > speed restricted. > > I am suspect of a ground problem but don't have a clue where to start > the search. I'm also suspect of the DDEC II unit but want it to be > something much more simple ($$$$). > > All fluids normal, no noises, leaks, or performance issues when "check > engine" light is off ... but as you can imagine ... 37 mph is very > restrictive for most travels. > > Steve & Kathy Enfinger > '91 WBSA PT40 > |
12-31-2006, 16:25
Check engine light
Another wild guess! Check the pins going into the DDEC, if not
covered or coated, possible moisture- shorting them, at times! Steve Gureasko 90WB40 Jus Chillin Ponchatoula, La. Celebrating New Year on South Padre Island, Tx. |
User(s) browsing this thread: 9 Guest(s)
