Oil Pressure Switch
09-23-2005, 01:18
Oil Pressure Switch
Greetings,
I replaced my oil pressure sending unit about a year ago, Pretty tough finding the correct one, but luckily I found it relatively local here in So Cal (Carson, CA). If you have TeleFlex gauges, I believe the sending unit for the gauge (8V92) is #1507377D if the gauge goes up to 120 PSI (according to the Teleflex webpage) I found the sending unit at: _http://www.custominstrumentpanels.com/_ (http://www.custominstrumentpanels.com/) Give 'em a call...they do nice work, and should sell you the correct sending unit. Let us know if it works out. Kevin McKeown Yorba Linda, CA 1986 39' PT 8V92 [Non-text portions of this message have been removed] |
09-23-2005, 02:43
Oil Pressure Switch
I have a 1988 WBWL 8V92 I am trying to find an oil pressure sending
switch for my bus...it it a KYSOR of Cadallic model # 24900-03 |
