Teleflex Tachometer
10-02-2005, 03:04
Teleflex Tachometer
Hello,
I am looking for a replacement for my tach it sticks. When it sticks I can tap on the face rim and it will break loose and work. I talked to Bennie and Earl at BB and described how it was doing and they felt it was in the Tach. The cost from BB is $312.00. Has anyone else had to replace their Tach, from what source and price. Thanks, Howard Truitt Camilla, Ga. 86, PT40, 8V92 |
10-02-2005, 03:46
Teleflex Tachometer
Howard:
I have a box full of original dash instruments and I believe I have a tach. Let me check, I also need to hook it up to be sure it is working. Will do that this next week when I get caught up in the shop with the Bird I have in now. Safe travels, Ralph and Charolette Fullenwider Ralph's RV Solutions, Duncan, Oklahoma http://home.swbell.net/rlf47/index.htm At 03:04 PM 10/2/2005 +0000, you wrote: >Hello, > >I am looking for a replacement for my tach it sticks. When it sticks I >can tap on the face rim and it will break loose and work. I talked to >Bennie and Earl at BB and described how it was doing and they felt it >was in the Tach. The cost from BB is $312.00. Has anyone else had to >replace their Tach, from what source and price. >Thanks, >Howard Truitt >Camilla, Ga. >86, PT40, 8V92 > > > |
10-02-2005, 04:15
Teleflex Tachometer
From: Howard O. Truitt To: WanderlodgeForum@yahoogroups.com Sent: Sunday, October 02, 2005 10:04 AM Subject: [WanderlodgeForum] Try this one http://www.teltekusa.com/teltekusa/ Bob Loomas 85 PT 36 Grand Forks ND Hello, I am looking for a replacement for my tach it sticks. When it sticks I can tap on the face rim and it will break loose and work. I talked to Bennie and Earl at BB and described how it was doing and they felt it was in the Tach. The cost from BB is $312.00. Has anyone else had to replace their Tach, from what source and price. Thanks, Howard Truitt Camilla, Ga. 86, PT40, 8V92 SPONSORED LINKS Recreational vehicles Wanderlodge Automotive maintenance Recreational vehicle dealer Used recreational vehicles Automotive radiators ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] |
10-02-2005, 04:22
Teleflex Tachometer
Hello Howard, I was just thinking about your post and I remember the
same thing happening to the tach on our coach. I "accidentally" touched the side of the tach and it worked much better.. hmm..Got behing the tach and cleaned the contacts and retightened..and working good now ..not sure if this had anything to do with it or not..I was thinking I was cleaning the ground. Not sure ..Ralph?? Scott B 86FC35 Murrells Inlet SC "right next to heaven" --- In WanderlodgeForum@yahoogroups.com, "Howard O. Truitt" > Hello, > > I am looking for a replacement for my tach it sticks. When it sticks I > can tap on the face rim and it will break loose and work. I talked to > Bennie and Earl at BB and described how it was doing and they felt it > was in the Tach. The cost from BB is $312.00. Has anyone else had to > replace their Tach, from what source and price. > Thanks, > Howard Truitt > Camilla, Ga. > 86, PT40, 8V92 |
10-02-2005, 04:26
Teleflex Tachometer
Hi Scott:
Glad to see you, hope the new genny is working out ok? Your right, the grounds under the lower and upper dash area were way under wired. And checking the ground on the instrument studs on the back does help. Also everyone one of the gauges go through a black amphenol and it being plastic and having amperage pass though it will tend to cause a build up of electrolysis that will make things flaky as well. Safe travels, Ralph and Charolette Fullenwider Ralph's RV Solutions, Duncan, Oklahoma http://home.swbell.net/rlf47/index.htm At 04:22 PM 10/2/2005 +0000, you wrote: >Hello Howard, I was just thinking about your post and I remember the >same thing happening to the tach on our coach. I "accidentally" >touched the side of the tach and it worked much better.. hmm..Got >behing the tach and cleaned the contacts and retightened..and working >good now ..not sure if this had anything to do with it or not..I was >thinking I was cleaning the ground. Not sure ..Ralph?? >Scott B >86FC35 >Murrells Inlet SC "right next to heaven" >--- In WanderlodgeForum@yahoogroups.com, "Howard O. Truitt" > > > Hello, > > > > I am looking for a replacement for my tach it sticks. When it sticks >I > > can tap on the face rim and it will break loose and work. I talked >to > > Bennie and Earl at BB and described how it was doing and they felt >it > > was in the Tach. The cost from BB is $312.00. Has anyone else had to > > replace their Tach, from what source and price. > > Thanks, > > Howard Truitt > > Camilla, Ga. > > 86, PT40, 8V92 > > |
10-02-2005, 04:32
Teleflex Tachometer
Teleflex web site is http://www.tflx.com/
West Marine sells Teleflex gages. Bill 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, "Howard O. Truitt" > Hello, > > I am looking for a replacement for my tach it sticks. When it sticks I > can tap on the face rim and it will break loose and work. I talked to > Bennie and Earl at BB and described how it was doing and they felt it > was in the Tach. The cost from BB is $312.00. Has anyone else had to > replace their Tach, from what source and price. > Thanks, > Howard Truitt > Camilla, Ga. > 86, PT40, 8V92 |
10-02-2005, 09:32
Teleflex Tachometer
Thanks Bill
----- Original Message ----- From: pattypape To: WanderlodgeForum@yahoogroups.com Sent: Sunday, October 02, 2005 12:32 PM Subject: [WanderlodgeForum] Re: Teleflex Tachometer Teleflex web site is http://www.tflx.com/ West Marine sells Teleflex gages. Bill 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, "Howard O. Truitt" > Hello, > > I am looking for a replacement for my tach it sticks. When it sticks I > can tap on the face rim and it will break loose and work. I talked to > Bennie and Earl at BB and described how it was doing and they felt it > was in the Tach. The cost from BB is $312.00. Has anyone else had to > replace their Tach, from what source and price. > Thanks, > Howard Truitt > Camilla, Ga. > 86, PT40, 8V92 ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] |
10-02-2005, 13:28
Teleflex Tachometer
Ralph,
Thanks for the offer and I will await your reply. Howard Truitt Camilla, Ga. 86 PT40 8V92 --- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" > Howard: > > I have a box full of original dash instruments and I believe I have a tach. > Let me check, I also need to hook it up to be sure it is working. Will do > that this next week when I get caught up in the shop with the Bird I have > in now. > > Safe travels, > > Ralph and Charolette Fullenwider > Ralph's RV Solutions, Duncan, Oklahoma > http://home.swbell.net/rlf47/index.htm > > > At 03:04 PM 10/2/2005 +0000, you wrote: > >Hello, > > > >I am looking for a replacement for my tach it sticks. When it sticks I > >can tap on the face rim and it will break loose and work. I talked to > >Bennie and Earl at BB and described how it was doing and they felt it > >was in the Tach. The cost from BB is $312.00. Has anyone else had to > >replace their Tach, from what source and price. > >Thanks, > >Howard Truitt > >Camilla, Ga. > >86, PT40, 8V92 > > > > > > |
10-03-2005, 02:58
Teleflex Tachometer
Here is a link to a place that can repair guages
http://www.gaugeguys.com/contacts.htm I stopped in and had my tach tested, no problems found. Guy was very nice. It is a small shop run out of the garage. Another place : http://www.dashusa.com/index.htm This site has a nice selection of guages : http://www.egauges.com// Troy Tikalsky Waconia, MN 1983 FC 33 --- In WanderlodgeForum@yahoogroups.com, "Howard O. Truitt" > Hello, > > I am looking for a replacement for my tach it sticks. When it sticks I > can tap on the face rim and it will break loose and work. I talked to > Bennie and Earl at BB and described how it was doing and they felt it > was in the Tach. The cost from BB is $312.00. Has anyone else had to > replace their Tach, from what source and price. > Thanks, > Howard Truitt > Camilla, Ga. > 86, PT40, 8V92 |
