Which Battery or Batteries start the Generator?
10-27-2005, 05:19
Howdy, Y'all.
We have a 15KW PowerTek generator in our 1993 Wanderlodge. Jack would like to know which battery or batteries supply power to the genset in the starting procedure. Is it the house batteries or the engine batteries? Thanks, Jack Regards, Jack and Liz Pearce Fulltiming in a 1993 Wanderlodge WB40 Homesick Texans in SE. FL |
10-27-2005, 10:02
Jack & Liz...On my 93 the house battery's are used for generator
starting....Bob 93pt Illinois |
10-27-2005, 12:05
> From: "Jack and Liz Pearce" > Date: 2005/10/27 Thu PM 02:19:46 ART > To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] Which Battery or Batteries start the Generator? > > Jack, On my '90 & '97 BB the battery for the powertech was in the driver's side front compartment. Dale '97wb41' Adventure Bird Pinckney, Mi. [Non-text portions of this message have been removed] |
10-27-2005, 12:24
--- In WanderlodgeForum@yahoogroups.com, "Bob & Carol Howald`"
> > Jack & Liz...On my 93 the house battery's are used for generator > starting....Bob 93pt Illinois Ah hah!!! Jack wants to know how you found that out. Thanks, Liz Regards, Jack and Liz Pearce Fulltiming in a 1993 Wanderlodge WB40 Homesick Texans in SE. FL |
10-27-2005, 12:26
> > Jack, On my '90 & '97 BB the battery for the powertech was in the driver's side front compartment. > > Dale '97wb41' > Adventure Bird > Pinckney, Mi. >> OK. Thanks. ![]() Regards, Liz > > [Non-text portions of this message have been removed] > [Non-text portions of this message have been removed] |
10-27-2005, 13:49
Jack & Liz......If you want to check on your coach which battery is
responsible for what system, just disconnect the ground on the engine battery's and see if the generator will start. I've had my battery's in and out numerous time's. I've redone the house tray's and also made new hold down tie's for the engine start battery's. I have a full 8 battery house bank and 3 battery engine start bank. Iam in the process now of replacing my house battery's with new one's. What type battery are you using for house deep cycle battery's I want to replace my 8 battery bank. Thank's Bob 93pt. Illinois |
10-28-2005, 03:01
> There is a lot info out there on battery's. there are a lot of choices to make, what type,lead acid or AGM, 6 volt or 12 volt, what group size, how much do you want to spend, do you mind doing maintenace? One thing is a for sure, if you never discharge your battery's over 50%, they will cycle twice as many times. Good luck Marty 95 BMC > Jack & Liz......If you want to check on your coach which battery is > responsible for what system, just disconnect the ground on the engine > battery's and see if the generator will start. I've had my battery's in > and out numerous time's. I've redone the house tray's and also made new > hold down tie's for the engine start battery's. I have a full 8 battery > house bank and 3 battery engine start bank. Iam in the process now of > replacing my house battery's with new one's. What type battery are you > using for house deep cycle battery's I want to replace my 8 battery > bank. Thank's Bob 93pt. Illinois > |
10-28-2005, 07:16
wrote: > > Jack & Liz......If you want to check on your coach which battery is > responsible for what system, just disconnect the ground on the engine > battery's and see if the generator will start. I've had my battery's in > and out numerous time's. I've redone the house tray's and also made new > hold down tie's for the engine start battery's. I have a full 8 battery > house bank and 3 battery engine start bank. Iam in the process now of > replacing my house battery's with new one's. What type battery are you > using for house deep cycle battery's I want to replace my 8 battery > bank. Thank's Bob 93pt. Illinois > Thanks for writing, Bob. Jack prefers lead acid batteries. His portable x-ray units use lead acids exclusively. Do you use your inverter? If so, how long can you run on your inverter before it is necessary to charge your coach's batteries? Thanks, Liz |
