House Heating Systems Questions
10-28-2005, 03:19
We are in beautiful Zion National Park on 30 amps. On our '86 PT, only the
electric heater in the bathroom works. The heaters in the front and kitchen
don't do anything when I turn their knob. I have flipped the circuit breakers
in
the closet, played with the thermostats, and switched the inputs for the shore
power (water heater vs convertor). Is there anything else I need to do before
I start checking voltages, etc?
The front propane heater doesn't put out heat either. The fan turns though.
Is there a reset button? What is the ignitions source for these heaters? BTW,
the LPG line is turned on at the heater, and the thermostat over the sofa is
on.
After almost tearing the refrigerator apart, because I couldn't get it to run
on propane, then discovering the propane detector needs to be on for propane
to flow, I'm leary of taking apart anything without checking with you guys
first! I was running around for 15 minutes trying to get the other LP heaters
to
work, until I remembered the switch on the dash:-)
Steve & Jane Harrie
St. George, UT
10-28-2005, 07:42
Steve, Have youe flipped on the appropriate switch (air
conditioning) in the control cluster above the drivers left, they
are dual purpose?
Roy Anderson
Springfield VA
1986 PT-40
only the
and kitchen
circuit breakers in
for the shore
to do before
turns though.
heaters? BTW,
the sofa is
> on.
get it to run
for propane
you guys
other LP heaters to
> Steve & Jane Harrie
> St. George, UT
10-28-2005, 07:51
What year and model BB do you have?a
tom warner
1982 FC35
>circuit breakers in
>the shore
>on.
>LP heaters to
>Steve & Jane Harrie
>St. George, UT
>YAHOO! GROUPS LINKS
> * Visit your group
Wanderl\
10-28-2005, 07:52
Oooops bad question guess I had a brain burp.
tom warner
1982 FC35
Vernon Center,NY
>tom warner
>1982 FC35
> >circuit breakers in
> >the shore
> to do before
> heaters? BTW,
> >on.
> get it to run
> >LP heaters to
> >Steve & Jane Harrie
> >St. George, UT
> >YAHOO! GROUPS LINKS
> > * Visit your group
"<<http://groups.yahoo.com/group/WanderlodgeForum>http://groups.yahoo.com/group/\
> on the web.
Wanderl\
> <<http://docs.yahoo.com/info/terms/>http://docs.yahoo.com/info/terms/>Yahoo!
> Terms of Service.
>SPONSORED LINKS
><http://groups.yahoo.com/gads?t=ms&k=Recr...;vehi\
Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzhn_\
ObWmSYTw>Recreational
>vehicles
><http://groups.yahoo.com/gads?t=ms&k=Wand...w2=Wa\
nderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recre\
ational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLPj9U0JvqYQ>W\
anderlodge
><http://groups.yahoo.com/gads?t=ms&k=Auto...3;veh\
icles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5\
=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pmy3\
4cC1O9CxA>Automotive
>maintenance
><http://groups.yahoo.com/gads?t=ms&k=Recr...tiona\
l+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deal\
er&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_Xahae\
YHfELr6o72IW1A>Recreational
>vehicle dealer
><http://groups.yahoo.com/gads?t=ms&k=Used...ional\
+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deale\
r&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km4L\
-kXbDI4ZSadEw>Used
>recreational vehicles
><http://groups.yahoo.com/gads?t=ms&k=Auto...vehic\
les&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=U\
sed+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgTnM\
q_4GlXA>Automotive
>radiators
>YAHOO! GROUPS LINKS
> * Visit your group
Wanderl\
10-29-2005, 03:31
>Have you flipped on the appropriate switch (air conditioning) in the control
Bingo!
Thanks Roy. The front electric heater came on. The center and rear didn't,
but they may be on a different leg, and it is still too dark here. I'll check it
out after the sun comes up.
Steve Harrie
'86 PT38 in Zion NP
10-29-2005, 07:57
Steve, On my PT-40 the switchs control front, middle, and back air
and heaters, but they are on different legs, good luck.
the control
> Bingo!
didn't,
I'll check it
> Steve Harrie
> '86 PT38 in Zion NP
10-29-2005, 11:27
> control
>Bingo!
Steve, if you had paid attention and listened while here, you would have
known that. Of course, all you did was sleep and eat Lynn's cooking, so
I really can't blame you a bit.......see you in January....Blair
10-30-2005, 16:21
have known that.
Jeez, I forget one little thing out of a 3 day lecture!
Maybe I forgot 2...is there a switch to turn the LPG heater on under
the sofa? The fan only blows cool air.
Steve Harrie
'86 PT38
10-30-2005, 20:31
Steve- do you hear the ignitin sequence when you turn your heater on? There
should be a valve in your outside refer access panel. Ernie-83pt40 in 28
degree montana
10-31-2005, 03:02
>have known that.
>Steve Harrie
>'86 PT38
Steve.....laughter is good for the soul...the heater needs to be
cleaned....Blair
