A259972 Kohler Control Box
10-31-2005, 16:15
Tom,
Your pictures indicate you took the guts out to the bare metal then painted the chassis gold. Nice job, pretty, looks rugged enough, any moddifications to the original? Lastly, have you tried it, and, does it work better than before? Bob Janes, 77fc31, Greenville, SC |
10-31-2005, 17:41
Yes I made some changes. Added new relays and sockets for the 3
relays. Added an aluminum pad extension under the KUP14A55-120 relay (in the center) so that I could remove everything from the top instead of taking the rubber shock absorbers loose and raising the box to get access under it. Also changed the ITS relay since the original was no longer available. The substitute is Airpax APGN1-1REC2 and costs $112.00. Actually the gold paint is the original color I just stripped the chassis, primed it with metal etching primer and repainted. I have it installed in the chassis now but did not start it today. I am sure it will work though. tom Warner 1982 FC35 Vernon center,NY At 11:15 PM 10/31/2005, you wrote: >Tom, >Your pictures indicate you took the guts out to the bare >metal then painted the chassis gold. Nice job, pretty, looks >rugged enough, any moddifications to the original? > >Lastly, have you tried it, and, does it work better than >before? > >Bob Janes, 77fc31, Greenville, SC > > > > > > >---------- >YAHOO! GROUPS LINKS > > * Visit your group > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. > * > * To unsubscribe from this group, send an email to: > * > odgeForum-unsubscribe@yahoogroups.com > > * > * Your use of Yahoo! Groups is subject to the > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > >---------- |
