basement door strut part number
11-06-2005, 12:12
Does anyone have a part number for the basement compartment doors,
both the large front door(PT40) and the smaller rear compartment(PT40)?
I had replaced the struts on the front compoartment door on the curb
side. The numbers on the gas springs don't jive with anything at Orr &
Orr.
If you have part numbers for these 2 different doors, would appreciate
that information.
Thanks
Jay Darst
85PT40
Springfield, IL
11-06-2005, 14:15
Jay,
Are you looking for the gas struts are for doors.
Howard truitt
Camilla, Ga.
86 8V92 PT40
Sent: Sunday, November 06, 2005 7:12 PM
Subject: [WanderlodgeForum] basement door strut part number
Orr.
that information.
Thanks
Jay Darst
85PT40
Springfield, IL
SPONSORED LINKS Recreational vehicles Automotive maintenance
YAHOO! GROUPS LINKS
11-06-2005, 14:28
I need the gas springs or struts that hold the doors open.
Thanks
Jay Darst
85PT40
Springfield, IL
--- In WanderlodgeForum@yahoogroups.com, "Howard O. Truitt"
> Jay,
> Howard truitt
> Camilla, Ga.
> 86 8V92 PT40
> From: Jay Darst
doors,
(PT40)?
curb
Orr &
> Orr.
appreciate
> that information.
> Thanks
> Jay Darst
> 85PT40
> Springfield, IL
> YAHOO! GROUPS LINKS
of Service.
11-06-2005, 15:06
Jay,
Every strut on my coach is bad. I priced replacements at a local auto parts
store
they were about $40.00 per set.
I use bungie cords to hold them open works great
cost $4.74 for all I needed at Wal Mart. If you want to make something that will
hold them up get you some heavy or thick wall PVC or Copper Pipe and cut it the
length of the extended ram. Unfasten one end of the strut and slide the pipe
over the strut and reattach the strut. If you have it cut to the right length
when you open the door the ram pulls out from the strut and the pipe drops under
the edge of the strut and holds the door open. When you get ready to close the
door push up on the door, push in slightly on the pipe so the strut can slide
down inside the pipe. You only need one pipe per door and put it on the right
side if you are right handed. You will never have to worry about struts again.
I have a more elaborate one on the rear engine access door. I guess it was OE.
Howard O. Truitt
Camilla, Ga.
86 8V92 PT40
Sent: Sunday, November 06, 2005 9:28 PM
Subject: [WanderlodgeForum] Re: basement door strut part number
Thanks
Jay Darst
85PT40
Springfield, IL
> Jay,
> Howard truitt
> Camilla, Ga.
> 86 8V92 PT40
> From: Jay Darst
doors,
(PT40)?
curb
Orr &
> Orr.
appreciate
> that information.
> Thanks
> Jay Darst
> 85PT40
> Springfield, IL
> YAHOO! GROUPS LINKS
of Service.
YAHOO! GROUPS LINKS
11-06-2005, 16:47
Jay
get hold of Curt Sprenger he has the ppropriate numbers for the Gas
Springs
Stephen 77gc35 still using strings and chains
--- In WanderlodgeForum@yahoogroups.com, "Jay Darst"
> Thanks
> Jay Darst
> 85PT40
> Springfield, IL
> > Jay,
> > Howard truitt
> > Camilla, Ga.
> > 86 8V92 PT40
> > From: Jay Darst
> doors,
> (PT40)?
> curb
> Orr &
> > Orr.
> appreciate
> > that information.
> > Thanks
> > Jay Darst
> > 85PT40
> > Springfield, IL
> > YAHOO! GROUPS LINKS
> of Service.
11-07-2005, 00:32
Howard, that is what I have on my engine compartment. It has held that heavy
door for years. I'm going to add those pipes to the rest of the lower
compartments. Ernie-83pt40- on my way out of town,again.
-----Original Message-----
From: Howard O. Truitt To: WanderlodgeForum@yahoogroups.com
Sent: Sun, 6 Nov 2005 22:06:11 -0500
Subject: Re: [WanderlodgeForum] Re: basement door strut part number
Jay,
store
Howard O. Truitt
Camilla, Ga.
86 8V92 PT40
Thanks
Jay Darst
85PT40
Springfield, IL
> Jay,
> Howard truitt
> Camilla, Ga.
> 86 8V92 PT40
> From: Jay Darst
doors,
(PT40)?
curb
Orr &
> Orr.
appreciate
> that information.
> Thanks
> Jay Darst
> 85PT40
> Springfield, IL
> YAHOO! GROUPS LINKS
of Service.
YAHOO! GROUPS LINKS
Yahoo! Groups Links
11-07-2005, 05:33
Jay, I have replaced all the gas springs on my Bird. Used SOSPA a
manufacture here in Mi. all were under $20. If you would like I can
get the #'s for you.
Oene
(PT40)?
curb
Orr &
> Orr.
appreciate
> that information.
> Thanks
> Jay Darst
> 85PT40
> Springfield, IL
11-07-2005, 06:00
> Thanks
> Jay Darst
> 85PT40
> Springfield, IL
> > Jay,
> > Howard truitt
> > Camilla, Ga.
> > 86 8V92 PT40
> > From: Jay Darst
> doors,
compartment
> (PT40)?
> curb
at
> Orr &
> > Orr.
> appreciate
> > that information.
> > Thanks
> > Jay Darst
> > 85PT40
> > Springfield, IL
> > Jay, I also replaced my gas springs. Ordered from orrorr.com-- I
thing the shorter ones were around $12, and the longer ones were
$20. hope this helps
ED GARDELS 89SP
ARLINGTON TEXAS
> > YAHOO! GROUPS LINKS
Terms
> of Service.
11-07-2005, 06:00
> Thanks
> Jay Darst
> 85PT40
> Springfield, IL
> > Jay,
> > Howard truitt
> > Camilla, Ga.
> > 86 8V92 PT40
> > From: Jay Darst
> doors,
compartment
> (PT40)?
> curb
at
> Orr &
> > Orr.
> appreciate
> > that information.
> > Thanks
> > Jay Darst
> > 85PT40
> > Springfield, IL
ED GARDELS 89SP
ARLINGTON TEXAS
> > YAHOO! GROUPS LINKS
Terms
> of Service.
11-07-2005, 06:06
Jay,
I did a quick search on the archives and here are some relevant posts:
Date: Sun, 11 Jan 2004 20:00:24 -0000
Subj: gas struts - help w/ part numbers & source
I located my receipt for the struts.
H9412-35, gas prop - 35 lb (I used these for inside overhead
cabinets), $10.05 each (ordered March 2002).
FBN12G, Gas spring - 90 lb (I used for outside compartments. "Very
Strong" spring, consider replacing in pairs to avoid chancing
warping the door. If they have a lighter pound spring consider
it.) $22.55 each, in March 2002.
Free catalog, part no MH2000/20 .
http://www.orrorr.com Orr & Orr, 3520 S. Morgan St. Chicago, IL
60609-1524 (773)254-0022
Dan, 83 FC35
Date: Thu, 11 Mar 2004 09:19:02 -0700
Subj: Orr & Orr Door Strut Part Numbers
>From Orr & Orr I used the 35lb strut inside (H9412-35) and the 80lb strut
outside (FBN12E). On the inside units, there's a metal retaining clip that
you have to pry out to release the old strut (new ones pop right in).
On the
outside struts, you can just twist off the old old ones, and pop the new
ones in place. Try to prop open the door with some wood so you don't
have to
hold the door on your head while you try to wrestle the new strut into
place. A paint stirring stick works good for the inside doors; a 2X4
for the
outside doors.
Alb. Rick (1985 FC-31)
>I threw this one in just incase someone else needs this info<
Date: Fri, 29 Aug 2003 01:53:21 -0000
Subj: gas struts
Jay, I have an 86PT40, but have that side door. I don't have the
Stabilus number but the number on my struts is SPO-5200-60A from
Service Parts Distributors, Inc., Bensalen, PA 19020 215.639.7810.
This info is as old as my coach, so it may not be good anymore.
Good luck,
John Ely, San Jose, CA 86PT40
--- In Wanderlodge@yahoogroups.com, "jdarstpt40" wrote:
> Can anyone give me a Stabilus part # for gas struts for the curb
> side engine access panel(battery, air cleaner, Raycor) on 1985 40PT?
> I called Bluebird, they gave me a part number and I now have struts
> for the rear engine door.
> Any help is appreciated...
> Jay Darst
> 1985 40PT 6V92
There you go. Hope these help.
83 PT40 "Stagecoach" - For Sale - Now with Financing!
91 PT40 "Texas Minivan
> Orr.
> that information.
> Thanks
> Jay Darst
> 85PT40
> Springfield, IL
